The WorkCentre 3615 multifunction printer offers a full productivity toolbox in one device, so you're more efficient every day.
Productivity and Paper Handling
- A 60-sheet Duplex Automatic Document Feeder scans two-sided originals for copy, scan and fax jobs.
- The WorkCentre 3615 includes a 109 mm (4.3-inch) colour touch screen with easily understood instructions and help screens to streamline walkup operations.
- An easily accessible USB port allows users to quickly print from or scan to any standard USB memory device.
- 250-sheet output tray with tray-full sensor.
- 150-sheet Multipurpose Tray handles media sizes from 76 x 127 mm to 216 x 356 mm (3 x 5 in. to 8.5 x 14 in.).
- With the 550-sheet paper tray, standard paper capacity for the WorkCentre 3615 totals 700 sheets.
- Up to three optional 550-sheet paper trays increase total paper capacity to 2,350 sheets.
- Optional stand provides storage for toner cartridges, paper and other supplies.
- Place the WorkCentre 3615 anywhere you need it with the optional Wi-Fi Network Adapter.
Speed, Scanning and Print Quality
With best-in-class speed*, print resolution and media capacity, your busy office can deliver professional-looking prints, without waiting.
Built for speed.
Print up to 45 pages per minute (ppm) - the fastest monochrome print speed in its class*. Your first page prints in as few as 6.5 seconds.
True multifunction capability.
The intuitive 109 mm (4.3-inch) colour touch screen on the WorkCentre 3615 lets you program your next job while another is in progress.
Digitize...and simplify.
Easily turn cumbersome hard copy forms and documents into portable, digital files. Enjoy the added convenience of sharing your digital files automatically via email. You can even send your files to an established network folder or export them to any USB memory device.
Crisp details.
Bring definition and clarity to your documents with true print resolution of up to 1200 x 1200 dpi. Your printed communications never looked better.
* When compared to similar products as of September 2013.
Powerful Capabilities Built for Savings
Advanced tools improve security and save paper, power and time.
Reduce paper usage.
You'll dramatically lower your paper usage and related costs thanks to automatic two-sided printing. Plus, N-up printing enables you to print multiple pages on one sheet - a useful option when sharing presentations.
Increase efficiency.
Extra-high capacity toner cartridges allow you spend less time loading supplies and more time getting work done.
Keep information safe.
Secure Print keeps your sensitive documents out of the wrong hands by requiring users to enter a personal identification number at the device to print documents.
Use less power.
Unique Xerox® EA Toner fuses at a much lower temperature, reducing power consumption by up to 20% and CO2 emissions by up to 35%, compared to conventional toner.
All-in-one savings.
The WorkCentre 3615 combines the functions of a copier, printer, scanner and fax machine into a single, value-packed unit that can generate savings on energy and supplies costs.
Work From Anywhere.
When you're on the go, you can still print to the WorkCentre 3615, and manage it remotely from a web browser.
Print when and where you want.
With Apple® AirPrint™, you can print email, and important office documents, directly from your mobile iOS device when connected to your office Wi-Fi network.
And when working offsite, you can rely on Xerox® PrintBack to print documents back at the office so they are waiting for you when you return.
Freedom, unplugged.
With optional Wi-Fi capabilities, the WorkCentre 3615 is ready to go to work wherever it's needed.
Manage from a web browser.
Handle device administration remotely from any networked computer with Xerox® CentreWare® IS.
Efficient connectivity
With interfaces for LAN, USB 2.0, and USB host, alongside robust security protocols including 802.1x, IP filtering, IPsec, LDAP, and SSL, this device ensures secure and versatile connectivity options for all office environments. -
Efficient performance
Boasting a first print out time of just 6.5 seconds and speeds up to 47 ppm for B/W printing, the Xerox WorkCentre 3615/DN is designed to boost productivity. Automatic duplexing in both printing and scanning streamlines operations and conserves resources. -
Advanced copying features
Features such as Edge Erase, ID Card Copy, Job Build, fit to page, and photo mode, combined with a first copy out time of 8.5 seconds and a maximum copying resolution of 600 x 600 DPI, enhance the copying experience, offering flexibility and high-quality outputs. -
Comprehensive media handling
Supports a wide range of media sizes and types, including envelopes, card stock, and labels, with a maximum media capacity of 2350 sheets. This versatility meets various business needs, from daily documents to specialized prints. -
Eco-friendly design
ENERGY STAR certified and EPEAT Silver compliant, the Xerox WorkCentre 3615/DN is designed with environmental standards in mind, ensuring energy efficiency and a reduced carbon footprint for your office.
- Xerox WorkCentre 3615/DN - multifunction printer - B/W
- Multifunction printer
- Fax Type
- Super G3 - plain paper
- Printing Technology
- Laser (monochrome)
- Monthly Duty Cycle (max)
- 110000 pages
- Recommended Monthly Volume
- 12000 pages
- Max Copying Resolution
- Up to 600 x 600 dpi
- Max Printing Speed
- Up to 45 ppm
- Max Printing Resolution
- Up to 1200 x 1200 dpi
- Max Fax Transmission Speed
- 33.6 Kbps
- Data Compression System
- MH, MR, MMR, JBIG
- Fax Resolutions
- 203 x 98 dpi, 203 x 196 dpi, 300 x 300 dpi, 400 x 400 dpi
- Scanning
- 1200 x 1200 dpi
- Original Size
- Legal (216 x 356 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 60 sheets
- Media Size
- 76 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Envelopes, plain paper, labels, heavy-weight paper, thick paper, card stock, light-weight paper
- Standard Media Capacity
- 700 sheets
- Max Media Capacity
- 2350 sheets
- Bypass Feeder Capacity
- 150 sheets
- Output Trays Capacity
- 250 sheets
- Automatic Duplexing
- Yes (copying) Yes (printing) Yes (scanning)
- Connection Availability
- Interface
- USB 2.0, LAN, USB host
- Office Machine Features
- Save to USB flash drive, scan to e-mail
- Power
- (50/60Hz)
- 49.5 cm x 49.2 cm x 54.9 cm
- 21.5 kg
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- EPEAT Silver, ENERGY STAR Qualified, Blue Angel
- Fax Type
- Plain paper
- Laser - monochrome
- 110000 pages
- 12000 pages
- Interface
- Standard Memory
- 1 GB
Copying
- Copying Features
- Fit to page, ID Card Copy, Job Build, Edge Erase, photo mode
Printing
- Up to 45 ppm
- Printer Drivers / Emulations
- PCL 5e, PCL 6, PostScript 3, PDF
- First Print Out Time B/W
- 6.5 sec
Scanning
- Optical Resolution
- 1200 x 1200 dpi
- Grayscale Depth
- 8-bit
- Colour Depth
- 24-bit
Fax Machine
- Compatibility
- Super G3
- Max Transmission Speed
- 33.6 Kbps
- MH, MR, MMR, JBIG
- Fax Resolutions
Fax Machine Features
- Speed Dialing
- 200 station(s)
- Broadcast Transmission
- 200 stations
- Fax forwarding, Distinctive Ring Pattern Detection (DRPD), e-mail function, colour faxing, junk fax barrier, group dialling
Document & Media Handling
- Max Original Size
- Original Type
- Sheets
- 60 sheets
- Min Media Size
- 76 x 127 mm
- Max Media Size
- A4/Legal
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 216 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), 76 x 127 mm, fanfold A5 (148 x 210 mm)
- 700 sheets
- 2350 sheets
- 150 sheets
- 250 sheets
- ADF - 60 sheets size: 140 x 140 mm - Legal (216 x 356 mm) weight: 50 g/m² - 125 g/m² , Bypass tray - 60 sheets size: 76 x 127 mm - Legal (216 x 356 mm) weight: 60 g/m² - 216 g/m² , Input tray - 550 sheets size: 148 x 210 mm - Legal (216 x 356 mm) weight: 60 g/m² - 216 g/m² , Output tray - 250 sheets
- Speed Details
- Printing: up to 47 ppm (Letter A) - B/W , Printing: up to 45 ppm (A4) - B/W , Printing: up to 38 ppm (Legal) - B/W , Printing: up to 29 ppm (Letter A) - B/W duplex , Printing: up to 28 ppm (A4) - B/W duplex , Printing: up to 25 ppm (Legal) - B/W duplex , Copying: up to 42 ppm (Letter A) - B/W , Copying: up to 40 ppm (A4) - B/W , Scanning: up to 40 ipm
- 1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A , 1 x LAN - RJ-45
- LDAP, SSL, IPsec, 802.1x, IP filtering
- Operating System Support
- MS Windows Server 2003, Sun Solaris 9, MS Windows 7, MS Windows XP SP1, openSUSE 11.0, MS Windows Vista, HP-UX 11.0, Red Hat Enterprise Linux 4, Sun Solaris 10, Ubuntu Linux, HP-UX 11i, MS Windows Server 2008, IBM AIX 5, MS Windows XP or later, Apple Mac OS X 10.5 or later, Red Hat Enterprise Linux 5, openSUSE 12, Red Hat Fedora Core 11-14, Red Hat Fedora Core 14-16
- Software Included
- Drivers & Utilities
- Voltage Required
- (50/60Hz)
- 698 Watt
- Power Consumption Standby
- 59 Watt
- Power Consumption Sleep
- 4 Watt
- Warm-Up Time
- 20 sec
- First Copy Out Time B/W
- 8.5 sec
- Included Accessories
- Phone cable
- Consumables Included
- 1 x toner cartridge (black) - up to 5900 pages , 1 x drum
- CSA, EN55022 Class B, EMC, ICES-003 Class A, RoHS, UL 60950-1, EN 60950-1, WEEE, FCC Part 15 A, FDA, EN 60825-1
- EPEAT Compliant
- EPEAT Silver
- ENERGY STAR Certified
- Blue Angel Compliant
- 49.5 cm
- 49.2 cm
- 54.9 cm
- 21.5 kg
- Shipping Width
- 62.6 cm
- Shipping Depth
- 61.8 cm
- Shipping Height
- 70.3 cm
- Shipping Weight
- 26.6 kg
- Sound Emission
- 30 dBA (idle) / 56 dBA (operating)
- 15 °C
- 28 °C
- 20 - 70%
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £3.67 |
C2G 10m Cat6 550 MHz Snagless Patch Cable - Black | In Stock | £9.82 |
