Wireless wonders
Internal Wi-Fi connectivity comes standard for untethered mobility and the freedom to put your printer or multifunction device right where you need it. -
Upwardly mobile
With support for Apple AirPrint, Google Cloud Print, Xerox Print Service Plug in for Android and Mopria, you can print emails, photos and important documents from a wide range of mobile devices, instantly, and without complicated setup. -
Increase security and control
With USB card readers, you can enhance your office security and control costs by integrating with many popular pull print and authentication solutions. -
Ready to pair
Now workers can easily print from Android-based mobile phone and tablets with Near Field Communication (NFC) tap-to-pair. -
Multifunction productivity
The space saving WorkCentre 3345 Multifunction Printer (MFP) helps you conserve energy and reduce supplies costs by combining the functions of a copier, printer, color scanner and fax into one affordable device. -
Outstanding performance
With hefty processing power and standard memory, you'll see your first print faster and get print speeds up to 42 ppm. -
Print more for longer
A second paper tray lets you load an extra 550 sheets at one time for extended interruption-free printing. -
Economic efficiency
Available high-capacity print cartridges reduce your total cost of ownership and demand less frequent replacement. -
Touch and go
The WorkCentre 3345 multifunction printer takes walkup simplicity to a new level, with a larger 4.3-inch color touchscreen interface. -
Wherever, whenever, and however
Scan to email, or scan-to and print-from from a USB memory drive right at the device. You can even print directly from the cloud with a few simple steps. -
Easy management
With Xerox CentreWare Internet services, remote device administration is handled with ease right from your computer's browser.
- Xerox WorkCentre 3345V/DNI - multifunction printer - B/W
- Multifunction printer
- Fax Type
- Plain paper
- Printing Technology
- Laser (monochrome)
- Monthly Duty Cycle (max)
- 80000 images
- Recommended Monthly Volume
- 4500 pages
- Max Copying Resolution
- Up to 600 x 600 dpi
- Max Printing Speed
- Up to 40 ppm
- Max Printing Resolution
- Data Compression System
- MH, MR, MMR, JBIG, JPEG
- Original Size
- Legal (216 x 356 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 50 sheets
- Media Size
- 76 x 127 mm (min) - Legal (216 x 356 mm) (max)
- Standard Media Capacity
- 300 sheets
- Automatic Duplexing
- Yes (copying) Yes (printing)
- Connection Availability
- Interface
- USB, LAN, Wi-Fi
- Office Machine Features
- Save to USB flash drive, scan to e-mail, scan to folder, scan to network
- 1-year warranty
- Fax Type
- Plain paper
- Laser - monochrome
- 80000 images
- 4500 pages
- Interface
- USB, LAN, Wi-Fi
- Hard Disk Drive
- 1.5 GB
Copying
- Copying Features
- Booklet creation, ID Card Copy, Poster Copy, Job Build, Edge Erase, photo mode, margin shift, Book Copy
Printing
- Up to 40 ppm
- Printer Drivers / Emulations
- PCL 5e, PCL 6, PostScript 3, PDF, XPS
Fax Machine
- PC Faxing
Fax Machine Features
- Fax forwarding, automatic redialing, colour faxing, junk fax barrier, auto reduction, delayed sending, secure receive
Document & Media Handling
- Max Original Size
- Original Type
- Sheets
- 50 sheets
- Min Media Size
- 76 x 127 mm
- Max Media Size
- Legal
- 300 sheets
- ADF - 50 sheets size: 142 x 148 mm , Input tray - 250 sheets size: 76 x 127 mm
- 1 x USB , 1 x LAN
- LDAP, Secure Print, SSL, IPsec, 802.1x, IP filtering, MAC address filtering
- Warm-Up Time
- 13 sec
- Limited warranty - 1 year
Xerox Standard Capacity Black Toner Cartridge (2600 Pages) | In Stock | £119.63 |
Xerox High Capacity Black Toner Cartridge (8500 Pages) | In Stock | £207.10 |
Xerox Extra High Capacity Black Toner Cartridge (15000 Pages) | In Stock | £272.74 |
