Xerox WorkCentre 3335 Mono Laser Multifunction Printer
Quicklinx: CM62WS00 Mfr#: 3335V_DNI
£243.95 ex VAT
£292.74 inc VAT
The Xerox Workcentre 3335DNi is a mono multifunction printer offering speed, quality and resource savings in a compact package. This fully wireless printer can be used anywhere there is Internet signal and offers mobile printing as standard, including NFC, so you can tap and pair your Android devices.
  • Wireless wonders
    Internal Wi-Fi connectivity comes standard for untethered mobility and the freedom to put your printer or multifunction device right where you need it.
  • Upwardly mobile
    With support for Apple AirPrint, Google Cloud Print, Xerox Print Service Plug in for Android and Mopria, you can print emails, photos and important documents from a wide range of mobile devices, instantly, and without complicated setup.
  • Increase security and control
    With USB card readers, you can enhance your office security and control costs by integrating with many popular pull print and authentication solutions.
  • Ready to pair
    Now workers can easily print from Android-based mobile phone and tablets with Near Field Communication (NFC) tap-to-pair.
  • Multifunction productivity
    The space saving WorkCentre 3345 Multifunction Printer (MFP) helps you conserve energy and reduce supplies costs by combining the functions of a copier, printer, color scanner and fax into one affordable device.
  • Outstanding performance
    With hefty processing power and standard memory, you'll see your first print faster and get print speeds up to 42 ppm.
  • Print more for longer
    A second paper tray lets you load an extra 550 sheets at one time for extended interruption-free printing.
  • Economic efficiency
    Available high-capacity print cartridges reduce your total cost of ownership and demand less frequent replacement.
  • Touch and go
    The WorkCentre 3345 multifunction printer takes walkup simplicity to a new level, with a larger 4.3-inch color touchscreen interface.
  • Wherever, whenever, and however
    Scan to email, or scan-to and print-from from a USB memory drive right at the device. You can even print directly from the cloud with a few simple steps.
  • Easy management
    With Xerox CentreWare Internet services, remote device administration is handled with ease right from your computer's browser.
Xerox WorkCentre 3335V_DNI - multifunction printer - B/W
Multifunction printer
Fax Type
Plain paper
Printing Technology
Laser (monochrome)
Monthly Duty Cycle (max)
50000 images
Recommended Monthly Volume
2500 pages
Max Copying Resolution
Up to 600 x 600 dpi
Max Printing Speed
Up to 33 ppm
Max Printing Resolution
Up to 600 x 600 dpi
Data Compression System
MH, MR, MMR, JBIG, JPEG
Original Size
Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
50 sheets
Media Size
76 x 127 mm (min) - Legal (216 x 356 mm) (max)
Standard Media Capacity
300 sheets
Automatic Duplexing
Yes (copying) Yes (printing)
Connection Availability
USB, LAN, Wi-Fi
Office Machine Features
Save to USB flash drive, scan to e-mail, scan to folder, scan to network
1-year warranty
Fax Type
Plain paper
Printing Technology
Laser - monochrome
50000 images
2500 pages
USB, LAN, Wi-Fi
Hard Disk Drive
1.5 GB
Copying
Up to 600 x 600 dpi
Automatic Duplexing
Copying Features
Booklet creation, ID Card Copy, Poster Copy, Job Build, Edge Erase, photo mode, margin shift, Book Copy
Printing
Up to 600 x 600 dpi
Max Printing Speed
Up to 33 ppm
Printer Drivers / Emulations
PCL 5e, PCL 6, PostScript 3, PDF, XPS
Automatic Duplexing
Fax Machine
PC Faxing
Fax Machine Features
Fax forwarding, automatic redialing, colour faxing, junk fax barrier, auto reduction, delayed sending, secure receive
Document & Media Handling
Max Original Size
Original Type
Sheets
50 sheets
Min Media Size
76 x 127 mm
Max Media Size
Legal
300 sheets
ADF - 50 sheets size: 142 x 148 mm , Input tray - 250 sheets size: 76 x 127 mm
1 x USB , 1 x LAN
Security Protocols & Features
LDAP, Secure Print, SSL, IPsec, 802.1x, IP filtering, MAC address filtering
Warm-Up Time
13 sec
Limited warranty - 1 year
CM62 Xerox Standard Capacity Black Toner Cartridge (2600 Pages) In Stock £121.46
CM62 Xerox High Capacity Black Toner Cartridge (8500 Pages) In Stock £208.59
CM62 Xerox Extra High Capacity Black Toner Cartridge (15000 Pages) In Stock £258.96
Functionality: Printer
Functionality: Copier
Functionality: Fax
Functionality: Scanner
Brand: Xerox
