The Xerox Workcentre 3335DNi is a mono multifunction printer offering speed, quality and resource savings in a compact package. This fully wireless printer can be used anywhere there is Internet signal and offers mobile printing as standard, including NFC, so you can tap and pair your Android devices.
Wireless wonders
Internal Wi-Fi connectivity comes standard for untethered mobility and the freedom to put your printer or multifunction device right where you need it. -
Upwardly mobile
With support for Apple AirPrint, Google Cloud Print, Xerox Print Service Plug in for Android and Mopria, you can print emails, photos and important documents from a wide range of mobile devices, instantly, and without complicated setup. -
Increase security and control
With USB card readers, you can enhance your office security and control costs by integrating with many popular pull print and authentication solutions. -
Ready to pair
Now workers can easily print from Android-based mobile phone and tablets with Near Field Communication (NFC) tap-to-pair. -
Multifunction productivity
The space saving WorkCentre 3345 Multifunction Printer (MFP) helps you conserve energy and reduce supplies costs by combining the functions of a copier, printer, color scanner and fax into one affordable device. -
Outstanding performance
With hefty processing power and standard memory, you'll see your first print faster and get print speeds up to 42 ppm. -
Print more for longer
A second paper tray lets you load an extra 550 sheets at one time for extended interruption-free printing. -
Economic efficiency
Available high-capacity print cartridges reduce your total cost of ownership and demand less frequent replacement. -
Touch and go
The WorkCentre 3345 multifunction printer takes walkup simplicity to a new level, with a larger 4.3-inch color touchscreen interface. -
Wherever, whenever, and however
Scan to email, or scan-to and print-from from a USB memory drive right at the device. You can even print directly from the cloud with a few simple steps. -
Easy management
With Xerox CentreWare Internet services, remote device administration is handled with ease right from your computer's browser.
- Xerox WorkCentre 3335V_DNI - multifunction printer - B/W
- Multifunction printer
- Fax Type
- Plain paper
- Printing Technology
- Laser (monochrome)
- Monthly Duty Cycle (max)
- 50000 images
- Recommended Monthly Volume
- 2500 pages
- Max Copying Resolution
- Up to 600 x 600 dpi
- Max Printing Speed
- Up to 33 ppm
- Max Printing Resolution
- Data Compression System
- MH, MR, MMR, JBIG, JPEG
- Original Size
- Legal (216 x 356 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 50 sheets
- Media Size
- 76 x 127 mm (min) - Legal (216 x 356 mm) (max)
- Standard Media Capacity
- 300 sheets
- Automatic Duplexing
- Yes (copying) Yes (printing)
- Connection Availability
- Interface
- USB, LAN, Wi-Fi
- Office Machine Features
- Save to USB flash drive, scan to e-mail, scan to folder, scan to network
- 1-year warranty
- Fax Type
- Plain paper
- Laser - monochrome
- 50000 images
- 2500 pages
- Interface
- USB, LAN, Wi-Fi
- Hard Disk Drive
- 1.5 GB
Copying
- Copying Features
- Booklet creation, ID Card Copy, Poster Copy, Job Build, Edge Erase, photo mode, margin shift, Book Copy
Printing
- Up to 33 ppm
- Printer Drivers / Emulations
- PCL 5e, PCL 6, PostScript 3, PDF, XPS
Fax Machine
- PC Faxing
Fax Machine Features
- Fax forwarding, automatic redialing, colour faxing, junk fax barrier, auto reduction, delayed sending, secure receive
Document & Media Handling
- Max Original Size
- Original Type
- Sheets
- 50 sheets
- Min Media Size
- 76 x 127 mm
- Max Media Size
- Legal
- 300 sheets
- ADF - 50 sheets size: 142 x 148 mm , Input tray - 250 sheets size: 76 x 127 mm
- 1 x USB , 1 x LAN
- LDAP, Secure Print, SSL, IPsec, 802.1x, IP filtering, MAC address filtering
- Warm-Up Time
- 13 sec
- Limited warranty - 1 year
Xerox Standard Capacity Black Toner Cartridge (2600 Pages) | In Stock | £119.63 |
Xerox High Capacity Black Toner Cartridge (8500 Pages) | In Stock | £207.10 |
Xerox Extra High Capacity Black Toner Cartridge (15000 Pages) | In Stock | £272.74 |
