Xerox WorkCentre 3315V_DN Mono Laser Multifunction Printer
Quicklinx: 8CB7WS00 Mfr#: 3315V_DN
The WorkCentre 3315 monochrome all-in-one printers' small footprint makes these products a good fit for any home office or small business.
  • Automatic two-sided printing
    Save time and paper with automatic double-sided printing, standard on both models. Choose the WorkCentre 3325 for two-sided scanning and copying.
  • Internal Wi-Fi connectivity
    The WorkCentre 3325 has built-in internal wireless connectivity. Put the printer anywhere you need it - no cables required.
  • Media flexibility and quality
    A variety of media sizes are supported from 8.5 x 12" legal size office paper to 3 x 5" greeting cards - at up to 1200 x 1200 dpi.
  • Speed matters
    Documents are ready when you are, with print speeds up to 37 pages per minute and a first-page-out time as fast as 6.5 seconds.
Xerox WorkCentre 3315V_DN - multifunction printer - B/W
Multifunction printer
Copier Type
Digital
Fax Type
Super G3 - plain paper
Printing Technology
Laser (monochrome)
Monthly Duty Cycle (max)
50000 impressions
Recommended Monthly Volume
3000 pages
Max Copying Resolution
Up to 600 x 600 dpi
Max Printing Speed
Up to 31 ppm
Max Printing Resolution
Up to 1200 x 1200 dpi
Max Fax Transmission Speed
33.6 Kbps
Data Compression System
MH, MR, MMR, JBIG, JPEG
Fax Resolutions
300 x 300 dpi
Original Size
142 x 148 mm (min) - Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
50 sheets
Media Size
76 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Envelopes, plain paper, cards, labels, recycled paper, thin paper, thick paper
Standard Media Capacity
300 sheets
Bypass Feeder Capacity
50 sheets
Output Trays Capacity
150 sheets
Automatic Duplexing
Yes (printing)
Connection Availability
USB 2.0, LAN, USB host
Office Machine Features
Print from USB flash drive, save to USB flash drive, scan to e-mail, scan to network
42.4 cm x 42.2 cm x 41.7 cm
14.4 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified, Blue Angel
Copier Type
Digital
Fax Type
Plain paper
Printing Technology
Laser - monochrome
50000 impressions
3000 pages
Standard Memory
128 MB 128 MB
Max Supported Memory
384 MB 384 MB
Copying
Up to 600 x 600 dpi
Copying Features
ID Card Copy
Printing
Max Printing Speed
Up to 31 ppm
Printer Drivers / Emulations
PCL 5e, PCL 6, PostScript 3, PDF
Automatic Duplexing
First Print Out Time B/W
6.5 sec
Scanning
Interpolated Resolution
4800 x 4800 dpi
Grayscale Depth
8-bit
Colour Depth
24-bit
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
Fax Resolutions
300 x 300 dpi
PC Faxing
Fax Machine Features
Speed Dialing
200 station(s)
Delayed Transmission
Fax forwarding, automatic redialing, e-mail function, colour faxing, group dialling, auto reduction
Document & Media Handling
Min Original Size
142 x 148 mm
Max Original Size
Original Type
Sheets
50 sheets
Min Media Size
76 x 127 mm
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
220 g/m²
Supported Media Type
Supported Media Sizes
300 sheets
50 sheets
150 sheets
ADF - 50 sheets size: 142 x 148 mm - Legal (216 x 356 mm) weight: 60 g/m² - 105 g/m² , Bypass tray - 50 sheets size: 76 x 127 mm - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m² , Input tray - 250 sheets size: 76 x 127 mm - Legal (216 x 356 mm) weight: 60 g/m² - 163 g/m² , Output tray - 150 sheets
Speed Details
Printing: up to 31 ppm (A4) - B/W
1 x USB 2.0 , 1 x USB host , 1 x LAN
Network Protocols
SNMP, HTTPS, Bonjour
Security Protocols & Features
LDAP, SSL, Apple Bonjour, IPsec, 802.1x, IP filtering, MAC address filtering
Operating System Support
MS Windows XP, SuSe Linux, HP-UX, MS Windows Server 2003, MS Windows Vista, Red Hat Enterprise Linux 4, MS Windows Server 2008, IBM AIX 5, Apple Mac OS X 10.5 or later, Oracle Solaris 10, Oracle Solaris 9
600 Watt
Power Consumption Standby
50 Watt
Power Consumption Sleep
8 Watt
Warm-Up Time
35 sec
First Copy Out Time B/W
12 sec
Consumables Included
1 x toner cartridge (black)
Supported Windows 7 Features
Windows HD Imaging
GOST, GS, NOM, Directive 1999/5/EC, FCC Part 68, UL 60950-1, CSA C22.2 No. 60950-1-07
ENERGY STAR Certified
Blue Angel Compliant
42.4 cm
42.2 cm
41.7 cm
14.4 kg
Sound Emission
26 dBA (idle) / 52 dBA (operating)
10 °C
32 °C
20 - 80% (non-condensing)
8CB7 C2G 5m USB 2.0 A/B Cable - Black In Stock £5.09
Resources
The following resources are available for the Xerox WorkCentre 3315V_DN Mono Laser Multifunction Printer
