When you need professional color, flawless reliability and superior productivity in a well-connected printer, count on the VersaLink C8000 printers. The feature-rich, app-enabled C8000 is ready to be customized as your workplace assistant.
                Intuitive user experienceAn entirely familiar way to interact that includes a tablet-like experience with gesture-based touchscreen controls and easy customization.
                Mobile and cloud readyInstant connectivity to cloud and mobile devices right from the user interface, with access to cloud-hosted services that let you work where, when and how you want.
                Superior securityFull multi-level protection for both documents and data, ready to guard against and eliminate emerging threats and meet or exceed regulatory compliance.
- Xerox VersaLink C8000V/DT - printer - colour - laser
- Printer Type
- Workgroup printer - laser - colour
- 80.8 kg
- Media Size Class
- A3
- Max Media Size
- 320 x 1320.8 mm
- Min Media Size (Custom)
- 88.9 mm x 98.4 mm
- Max Media Size (Custom)
- 320 mm x 1320.8 mm
- Print Speed
- Up to 45 ppm - B/W - A4 (210 x 297 mm) , Up to 45 ppm - colour - A4 (210 x 297 mm) , Up to 26 ppm - B/W - Legal (216 x 356 mm) , Up to 26 ppm - colour - Legal (216 x 356 mm) , Up to 22 ppm - B/W - A3 (297 x 420 mm) , Up to 22 ppm - colour - A3 (297 x 420 mm) , Up to 21 ppm - B/W - SRA3 (320 x 450 mm) , Up to 21 ppm - colour - SRA3 (320 x 450 mm) , Up to 40 ppm - B/W duplex - A4 (210 x 297 mm) , Up to 40 ppm - colour duplex - A4 (210 x 297 mm) , Up to 26 ppm - B/W duplex - Legal (216 x 356 mm) , Up to 26 ppm - colour duplex - Legal (216 x 356 mm) , Up to 22 ppm - B/W duplex - A3 (297 x 420 mm) , Up to 22 ppm - colour duplex - A3 (297 x 420 mm) , Up to 15 ppm - B/W duplex - SRA3 (320 x 450 mm) , Up to 15 ppm - colour duplex - SRA3 (320 x 450 mm)
- Max Resolution (B&W)
- 1200 x 2400 dpi
- Max Resolution (Colour)
- 1200 x 2400 dpi
- Max Resolution Class (B&W)
- 1200 x 2400 dpi
- Max Resolution Class (Colour)
- 1200 x 2400 dpi
- Automatic Duplexing
- Interface
- Gigabit LAN, USB host, NFC, USB 3.0
- AirPrint Enabled
- Preview Screen Size
- 5"
- Processor
- 1.6 GHz
- RAM Installed (Max)
- 4 GB
- Language Simulation
- PCL 5E, PostScript 3, PCL 6, HP GL, PDF, XPS, TIFF, JPEG
- Media Type
- Envelopes, labels, plain paper, bond paper, recycled paper, card stock, preprinted paper, postcards, glossy paper
- Total Media Capacity
- 1140 sheets
- Media Handling
- 100-sheet bypass tray, 2x 520-sheet input tray
- Monthly Duty Cycle (max)
- 205000 pages
- Recommended Monthly Volume
- 20000 pages
- Networking
- Print server
- System Requirements
- IBM AIX, HP-UX, SuSe Linux, Red Hat Enterprise Linux, Microsoft Windows 7, Microsoft Windows Server 2008 SP2, Microsoft Windows Server 2008 R2 SP1, Oracle Solaris, Windows 8, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Windows 8.1, Windows 10, Apple MacOS X 10.11, Microsoft Windows Server 2016, Apple macOS 10.12, Apple macOS 10.13
- 1-year warranty
- 62 cm x 72.3 cm x 80.93 cm
- Printer Type
Printer
- Print Speed
- Built-in Devices
- Touch screen
- 5"
- Connectivity Technology
- Wired
- Interface
- AirPrint Enabled
- 1200 x 2400 dpi
- 1200 x 2400 dpi
- 1200 x 2400 dpi
- 1200 x 2400 dpi
- PostScript Support
- Standard
- First Print Out Time B/W
- 9.7 sec
- First Print Out Time Colour
- 11 sec
- Fonts Included
- 136 x PostScript , 83 x PCL
- Media Handling
- Processor
- 1.6 GHz
RAM
- 4 GB
Media Handling
- Media Type
- Media Size Class
- A3
- Max Media Size
- 320 x 1320.8 mm
- 88.9 mm x 98.4 mm
- Media Sizes
- Legal (216 x 356 mm), A4 (210 x 297 mm), A3 (297 x 420 mm), 100 x 148 mm, SRA3 (320 x 450 mm), 297 x 431.8 mm
- Media Weight
- 64 g/m² - 300 g/m²
- 1140 sheets
- Media Feeders
- Bypass tray: 1 x automatic - 100 sheets - 320 x 1320.8 mm weight: 64 g/m² - 300 g/m² , Input tray: 1 x automatic - 520 sheets - 297 x 431.8 mm weight: 64 g/m² - 300 g/m² , Input tray: 1 x automatic - 520 sheets - 320 x 457.2 mm weight: 64 g/m² - 300 g/m²
- Max Media Capacity
- 5140 sheets
- Output Trays Capacity
- 500 sheets
Duty Cycle
- 205000 pages
- 20000 pages
- Networking
- Print server
- Remote Management Protocol
- SNMP 3, HTTP, HTTPS
- Secure Print, SSL, TLS, IPsec, IP filtering
- Connections
- 1 x USB 3.0 , 1 x Gigabit LAN - RJ-45 , USB host - 4 pin USB Type A
- FIPS 140-2
- Power Device
- Power supply - internal
- Frequency Required
- 50/60 Hz
- 2320 Watt
- Power Consumption Stand by
- 73.8 Watt
- Power Consumption Sleep
- 0.53 Watt
- OS Required
Environmental Standards
- ENERGY STAR
- Limited warranty - 1 year - on-site
- 10 °C
- 28 °C
- 15 - 85%
- Sound Emission (Idle)
- 15.4 dBA
- Sound Emission (Operating)
- 56.8 dBA
- 62 cm
- 72.3 cm
- 80.93 cm
- 80.8 kg
- Width (Shipping)
- 83.3 cm
- Depth (Shipping)
- 71.7 cm
- Height (Shipping)
- 85.2 cm
- Weight (Shipping)
- 95 kg
