Xerox VersaLink C7000V DN Colour Laser Printer
Quicklinx: G1LHWS00 Mfr#: C7000V_DN
Type: Printer
Functionality: Printer
Wireless Capability: Wired
Max Paper Size: 297 x 432 mm
£1,386.76 ex VAT
£1,664.11 inc VAT
When you need your work to stand out from the rest, count on the VersaLink C7000 color printer - featuring Xerox ConnectKey technology. Ready for the way you want to work, the C7000 is mobile-ready, app-enabled and ready to customize. Meet your challenges head-on with the VersaLink C7000 - your modern workplace assistant
  • Flawless reliability, superior performance
    Right out of the box, you'll count on your Xerox VersaLink C7000 color printer to consistently and flawlessly perform the tasks that make your business work more efficiently. From IT-free installation wizards, to step-by-step configuration options, you're ready to go - hassle free. Designed for superior reliability, the VersaLink C7000 color printer features a great hardware design with fewer moving parts, strengthened paper-path components, and advanced imaging system. VersaLink devices are loaded with features and time-saving Xerox technologies designed to speed up information sharing and reduce inefficient workflows. When it comes to safeguarding critical information, VersaLink devices deliver a spectrum of stringent security features, including Secure Print and card authentication to control access.
  • Cloud connected, personalized efficiency
    With the customizable capacitive 5-inch color touchscreen, you can tap, swipe and pinch your way through tasks and functions with mobile-like ease. With Simple ID, individual users and groups enter a user ID and password once, and then enjoy fast, secure access to manage jobs and commonly used apps on a personalized home screen. Whether your documents are color or black-and-white, letter-size or oversize, the VersaLink C7000 color printer has the power and features you need to handle even the most challenging print jobs.
  • Mobile freedom, ready for the way you work
    The VersaLink C7000 color printer gives you the freedom to work where and how you want. The ability to connect and print from multiple devices is key for today's worker, and VersaLink devices meet the challenge with Apple AirPrint, Google Cloud Print, Xerox Print Service Plug-in for Android, Near Field Communication (NFC) Tap-to-Pair and Mopria.
Xerox VersaLink C7000V/DN - printer - colour - laser
Printer Type
Workgroup printer - laser - colour
54.3 kg
Media Size Class
A3
Max Media Size
297 x 432 mm
Min Media Size (Custom)
88.9 mm x 98.4 mm
Max Media Size (Custom)
297 mm x 432 mm
Print Speed
Up to 35 ppm - colour , Up to 35 ppm - B/W
Max Resolution (B&W)
1200 x 2400 dpi
Automatic Duplexing
Gigabit LAN, NFC, USB 3.0
AirPrint Enabled
Preview Screen Size
5"
1.05 GHz
RAM Installed (Max)
2 GB (2 GB)
Language Simulation
PCL 5E, PostScript 3, PCL 6, HP GL, PDF, XPS, TIFF, JPEG
Media Type
Envelopes, plain paper
Total Media Capacity
620 sheets
Media Handling
520-sheet input tray, 100-sheet bypass tray
Monthly Duty Cycle (max)
153000 pages
Recommended Monthly Volume
10000 pages
Print server
Linux, Microsoft Windows Server 2003, Red Hat Enterprise Linux, Microsoft Windows 7, HP-UX 11i v3, Microsoft Windows Server 2008, Windows 8, Microsoft Windows Server 2012, Apple MacOS X 10.10, Windows 10, Apple MacOS X 10.11, Oracle Solaris 11.3, IBM AIX 7.2, Red Hat Fedora Core 24, SUSE Linux 13.2, Apple macOS 10.12
1-year warranty
59 cm x 67.08 cm x 63.7 cm
Printer Type
Printer
Print Speed
Built-in Devices
5 inch LCD touch screen
Preview Screen Size
5"
Wired
AirPrint Enabled
1200 x 2400 dpi
Automatic Duplexing
PostScript Support
Standard
First Print Out Time B/W
5.1 sec
First Print Out Time Colour
7.6 sec
Language Simulation
Fonts Included
136 x PostScript , 83 x PCL
Media Handling
1.05 GHz
RAM
RAM Installed (Max)
2 GB / 2 GB (max)
Media Handling
Media Type
Media Size Class
A3
Max Media Size
297 x 432 mm
88.9 mm x 98.4 mm
297 mm x 432 mm
Media Sizes
297 x 432 mm, 139.7 x 182 mm, 88.9 x 98.4 mm
Envelope Sizes
International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm)
620 sheets
Media Feeders
Input tray: 1 x automatic - 500 sheets - 297 x 432 mm , Bypass tray: 1 x automatic - 100 sheets - 297 x 432 mm
Max Media Capacity
2180 sheets
Output Trays Capacity
500 sheets
Duty Cycle
153000 pages
10000 pages
Print server
Remote Management Protocol
SNMP 3, HTTPS
Security Protocols & Features
Secure Print, SSL, Apple Bonjour, TLS, IPsec
1 x USB 3.0 , 1 x Gigabit LAN - RJ-45
WHQL, FIPS 140-2, IPv6 Ready, EcoLogo, MEDITECH
Power supply - internal
1600 Watt
Power Consumption Stand by
94 Watt
Power Consumption Sleep
1 Watt
Environmental Standards
Blue Angel
ENERGY STAR
Limited warranty - 1 year - on-site
10 °C
32 °C
10 - 85% (non-condensing)
59 cm
67.08 cm
63.7 cm
54.3 kg
Width (Shipping)
71 cm
Depth (Shipping)
77 cm
Height (Shipping)
94.5 cm
Weight (Shipping)
71 kg
Type: Printer
Brand: Xerox
Price Range Ex VAT: £1000 - £1500
