Xerox VersaLink C600V DN Colour Laser Printer
Quicklinx: G1LGWS00 Mfr#: C600V_DN
Type: Printer
Functionality: Printer
Wireless Capability: Wired
Max Paper Size: A4 (210 x 297 mm), Legal (216 x 356 mm)
£1,018.83 ex VAT
£1,222.59 inc VAT
The VersaLink C600 color printer represents the definition of exceptional performance and unbeatable reliability. Cloud-connected, mobile-ready, app-enabled, and easy to customize, the C600 is your modern workplace assistant - transforming the way you work today, while ensuring you'll stay one step ahead tomorrow.
  • Reliable productivity and peace of mind
    Right out of the box, you'll count on your VersaLink C600 to consistently and flawlessly perform the tasks that make your business work more efficiently. From IT-free installation wizards, to step-by-step configuration options, you're ready to go - hassle free. Completely re-engineered for superior reliability, the VersaLink C600 features a hardware design with fewer moving parts, and a more advanced Hi-Q LED print head. VersaLink devices are loaded with features and time-saving Xerox technologies designed to speed up information sharing and reduce inefficient workflows. Ensure information accuracy with Scan and Fax preview, and do more with scanned documents with built-in optical character recognition (OCR). When it comes to safeguarding critical information, VersaLink devices deliver a spectrum of stringent security features, including Secure Print and card authentication to control access. Count on superior print quality to make your work look its best. A print resolution of up to 1200 x 2400 dpi delivers sharp text and fine line detail, plus exceptional color vibrancy.
  • Easy and efficient
    With the customizable, capacitive 5-inch color touchscreen, you can tap, swipe and pinch your way through tasks and functions with mobile-like ease. Speed through tasks by saving common settings as presets for simple, single-touch job setup. With Simple ID, individual users and groups enter a user ID and password once, and then enjoy fast, secure, easy access to task-specific presets and commonly used apps on a personalized home screen.
  • Mobile freedom and app-based flexibility
    The VersaLink C600 color printer gives you the freedom to work where and how you want - with out-of-the-box connectivity to Google Drive, Microsoft OneDrive and Dropbox. The ability to connect and print from multiple devices is key for today's worker, and VersaLink devices meet the challenge with Apple AirPrint, Google Cloud Print, Xerox Print Service Plug-in for Android, Near Field Communication (NFC) Tap-to-Pair and Mopria, plus optional Wi-Fi and Wi-Fi Direct.
Xerox VersaLink C600V/DN - printer - colour - LED
Printer Type
Workgroup printer - LED - colour
29.4 kg
Media Size Class
A4/Legal
Max Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm)
Min Media Size (Custom)
76 mm x 127 mm
Max Media Size (Custom)
216 mm x 356 mm
Print Speed
Up to 55 ppm - B/W - ANSI A (Letter) (216 x 279 mm) , Up to 55 ppm - colour - ANSI A (Letter) (216 x 279 mm) , Up to 53 ppm - B/W - A4 (210 x 297 mm) , Up to 53 ppm - colour - A4 (210 x 297 mm) , Up to 45 ppm - B/W - Legal (216 x 356 mm) , Up to 45 ppm - colour - Legal (216 x 356 mm) , Up to 52 ppm - B/W duplex - ANSI A (Letter) (216 x 279 mm) , Up to 52 ppm - colour duplex - ANSI A (Letter) (216 x 279 mm) , Up to 50 ppm - B/W duplex - A4 (210 x 297 mm) , Up to 50 ppm - colour duplex - A4 (210 x 297 mm) , Up to 26 ppm - B/W duplex - Legal (216 x 356 mm) , Up to 26 ppm - colour duplex - Legal (216 x 356 mm)
Max Resolution (B&W)
1200 x 2400 dpi
Max Resolution (Colour)
1200 x 2400 dpi
Max Resolution Class (B&W)
1200 x 2400 dpi
Max Resolution Class (Colour)
1200 x 2400 dpi
Automatic Duplexing
Gigabit LAN, USB host, NFC, USB 3.0
AirPrint Enabled
Preview Screen Size
5"
1.05 GHz
RAM Installed (Max)
2 GB
Language Simulation
PCL 5E, PostScript 3, PCL 6, HP GL, PDF, XPS, TIFF, JPEG
Media Type
Envelopes, labels, plain paper, bond paper, recycled paper, card stock, punched paper, preprinted paper
Total Media Capacity
700 sheets
Media Handling
150-sheet bypass tray, 550-sheet input tray
Monthly Duty Cycle (max)
120000 pages
Recommended Monthly Volume
15000 pages
Print server
Linux, Microsoft Windows 2000 Server, Microsoft Windows Server 2003, Red Hat Enterprise Linux, Microsoft Windows Server 2008 R2, HP-UX 11i v3, Microsoft Windows Server 2008, Microsoft Windows Server 2012, Apple MacOS X 10.10, Microsoft Windows 7 / 8 / 10, Apple MacOS X 10.11, Oracle Solaris 11.3, IBM AIX 7.2, Red Hat Fedora Core 24, SUSE Linux 13.2, Apple macOS 10.12
Pricing Type
Sold
42.74 cm x 46.55 cm x 44.34 cm
Printer Type
Printer
Print Speed
Built-in Devices
Touch screen
Preview Screen Size
5"
Wired
AirPrint Enabled
1200 x 2400 dpi
1200 x 2400 dpi
1200 x 2400 dpi
1200 x 2400 dpi
Automatic Duplexing
PostScript Support
Standard
First Print Out Time B/W
4.7 sec
First Print Out Time Colour
5.1 sec
Language Simulation
Fonts Included
136 x PostScript , 83 x PCL
Media Handling
1.05 GHz
RAM
RAM Installed (Max)
2 GB
Media Handling
Media Type
Media Size Class
A4/Legal
Max Media Size
76 mm x 127 mm
216 mm x 356 mm
Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm)
Media Weight
60 g/m² - 220 g/m²
Media Weight (lbs)
16 lbs (Bond) - 43 lbs (Cover)
700 sheets
Media Feeders
Input tray: 1 x automatic - 150 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m² - (16 lbs (Bond) (min) - 43 lbs (Cover) (max)) , Input tray: 1 x automatic - 550 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m² - (16 lbs (Bond) (min) - 43 lbs (Cover) (max))
Max Media Capacity
3250 sheets
Output Trays Capacity
500 sheets
Duty Cycle
120000 pages
15000 pages
Print server
Remote Management Protocol
SNMP 3, HTTP, HTTPS
Security Protocols & Features
LDAP, Secure Print, SSL, Apple Bonjour, TLS, IP filtering, port blocking
USB 3.0 , Gigabit LAN - RJ-45 , USB host
Consumables Included
1 x toner cartridge (black) , 1 x toner cartridge (cyan) , 1 x toner cartridge (magenta) , 1 x toner cartridge (yellow)
FIPS 140-2
Pricing Type
Sold
Power supply - internal
Frequency Required
50/60 Hz
800 watt
Power Consumption Stand by
85 watt
Power Consumption Sleep
0.7 watt
Software Included
Drivers & Utilities
10 °C
32 °C
15 - 85%
Sound Emission (Idle)
33.5 dBA
Sound Emission (Operating)
57.4 dBA
42.74 cm
46.55 cm
44.34 cm
29.4 kg
Width (Shipping)
58 cm
Depth (Shipping)
63.4 cm
Height (Shipping)
60.7 cm
Weight (Shipping)
35 kg
Type: Printer
Brand: Xerox
Price Range Ex VAT: £1000 - £1500
