The fast, full-featured and office-friendly VersaLink B615 is anything but your basic black and white device. In fact, VersaLink sets a new standard for what you can expect in work group productivity from Xerox. Home or away, this highly configurable, cloud-connected workplace assistant delivers completely new capabilities that go far beyond the competition - at a competitive price.
Easy, smart and secure
Completely re-engineered for superior reliability, the VersaLink B615 feature a hardware design with fewer moving parts, strengthened paper-path components, and a more advanced Hi-Q LED print head. -
Customizable, app-based functionality
With the customizable, capacitive 7-inch color touchscreen, you can tap, swipe and pinch your way through tasks and functions with mobile-like ease. Preloaded Xerox ConnectKey Apps help optimize office efficiency. -
Cloud and mobile connectivity
The VersaLink B615 Multifunction Printer gives you the freedom to work where and how you want - with out-of-the-box connectivity to Google Drive, Microsoft OneDrive and Dropbox, and access to additional options through the Xerox App Gallery.
 - Xerox VersaLink B615V_XL - multifunction printer (B/W)
 - Fax / copier / printer / scanner
- Fax Type
 - Plain paper
- Printing Technology
 - LED (monochrome)
- Max Copying Resolution
 - Up to 600 x 600 dpi
- Max Printing Resolution
 - Up to 1200 x 1200 dpi
- Max Printing Resolution Class
- Scanning
 - 600 x 600 dpi
- Display
 - 7"
- Original Type
 - Sheets
- Document Feeder Capacity
 - 100 sheets
- Media Size
 - 76 x 127 mm (min)
- Media Type
 - Envelopes, plain paper, labels, recycled paper, bond paper, card stock, punched paper, preprinted paper
- Bypass Feeder Capacity
 - 150 sheets
- Automatic Duplexing
 - Yes (copying) Yes (printing) Yes (scanning)
- PC Connection Availability
- PC Connection
 - Gigabit LAN, USB host, NFC, USB 3.0
- AirPrint Enabled
- Power
 - AC 230 V (50/60Hz)
- Environmental Standards
 - ENERGY STAR Qualified
- Fax Type
 - Plain paper
 - LED - monochrome
- Display Diagonal Size
 - 7"
- Colour Support
- Display Features
 - Touch screen
- PC Connection
- AirPrint Enabled
- Standard Memory
 - 2 GB
- Hard Disk Drive
 - 250 GB
Copying
- Max Document Enlargement
 - 400%
- Max Document Reduction
 - 25%
- Maximum Copies
 - 999
Printing
- Printer Drivers / Emulations
 - PCL 5e, PCL 6, PostScript 3, PDF, TIFF, HPGL, XPS, JPEG
Scanning
- Optical Resolution
 - 600 x 600 dpi
- Grayscale Depth
 - 8-bit
- Colour Depth
 - 24-bit
Document & Media Handling
- Original Type
 - Sheets
 - 100 sheets
- Min Media Size
 - 76 x 127 mm
- Min Media Weight
 - 60 g/m²
- Max Media Weight
 - 220 g/m²
- Supported Media Type
 - 150 sheets
 - Secure Print, SSL, TLS, Secure Fax, IP filtering, port blocking, AES-256, Secure Scan, Secure Email
- Voltage Required
- ENERGY STAR Certified
 - 10 °C
 - 32 °C
 - 15 - 85%
