The fast, full-featured and office-friendly VersaLink B615 is anything but your basic black and white device. In fact, VersaLink sets a new standard for what you can expect in work group productivity from Xerox. Home or away, this highly configurable, cloud-connected workplace assistant delivers completely new capabilities that go far beyond the competition - at a competitive price.
                Easy, smart and secureCompletely re-engineered for superior reliability, the VersaLink B615 feature a hardware design with fewer moving parts, strengthened paper-path components, and a more advanced Hi-Q LED print head.
                Customizable, app-based functionalityWith the customizable, capacitive 7-inch color touchscreen, you can tap, swipe and pinch your way through tasks and functions with mobile-like ease. Preloaded Xerox ConnectKey Apps help optimize office efficiency.
                Cloud and mobile connectivityThe VersaLink B615 Multifunction Printer gives you the freedom to work where and how you want - with out-of-the-box connectivity to Google Drive, Microsoft OneDrive and Dropbox, and access to additional options through the Xerox App Gallery.
- Xerox VersaLink B615V_XL - multifunction printer (B/W)
- Fax / copier / printer / scanner
- Fax Type
- Plain paper
- Printing Technology
- LED (monochrome)
- Max Copying Resolution
- Up to 600 x 600 dpi
- Max Printing Resolution
- Up to 1200 x 1200 dpi
- Max Printing Resolution Class
- Scanning
- 600 x 600 dpi
- Display
- 7"
- Original Type
- Sheets
- Document Feeder Capacity
- 100 sheets
- Media Size
- 76 x 127 mm (min)
- Media Type
- Envelopes, plain paper, labels, recycled paper, bond paper, card stock, punched paper, preprinted paper
- Bypass Feeder Capacity
- 150 sheets
- Automatic Duplexing
- Yes (copying) Yes (printing) Yes (scanning)
- PC Connection Availability
- PC Connection
- Gigabit LAN, USB host, NFC, USB 3.0
- AirPrint Enabled
- Power
- AC 230 V (50/60Hz)
- Environmental Standards
- ENERGY STAR Qualified
- Fax Type
- Plain paper
- LED - monochrome
- Display Diagonal Size
- 7"
- Colour Support
- Display Features
- Touch screen
- PC Connection
- AirPrint Enabled
- Standard Memory
- 2 GB
- Hard Disk Drive
- 250 GB
Copying
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 999
Printing
- Printer Drivers / Emulations
- PCL 5e, PCL 6, PostScript 3, PDF, TIFF, HPGL, XPS, JPEG
Scanning
- Optical Resolution
- 600 x 600 dpi
- Grayscale Depth
- 8-bit
- Colour Depth
- 24-bit
Document & Media Handling
- Original Type
- Sheets
- 100 sheets
- Min Media Size
- 76 x 127 mm
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 220 g/m²
- Supported Media Type
- 150 sheets
- Secure Print, SSL, TLS, Secure Fax, IP filtering, port blocking, AES-256, Secure Scan, Secure Email
- Voltage Required
- ENERGY STAR Certified
- 10 °C
- 32 °C
- 15 - 85%
