Xerox VersaLink B615V XL Mono Laser Multifunction Printer
Quicklinx: G1LXWS00 Mfr#: B615V_XL?GB
£2,009.41 ex VAT
£2,411.29 inc VAT
The fast, full-featured and office-friendly VersaLink B615 is anything but your basic black and white device. In fact, VersaLink sets a new standard for what you can expect in work group productivity from Xerox. Home or away, this highly configurable, cloud-connected workplace assistant delivers completely new capabilities that go far beyond the competition - at a competitive price.
  • Easy, smart and secure
    Completely re-engineered for superior reliability, the VersaLink B615 feature a hardware design with fewer moving parts, strengthened paper-path components, and a more advanced Hi-Q LED print head.
  • Customizable, app-based functionality
    With the customizable, capacitive 7-inch color touchscreen, you can tap, swipe and pinch your way through tasks and functions with mobile-like ease. Preloaded Xerox ConnectKey Apps help optimize office efficiency.
  • Cloud and mobile connectivity
    The VersaLink B615 Multifunction Printer gives you the freedom to work where and how you want - with out-of-the-box connectivity to Google Drive, Microsoft OneDrive and Dropbox, and access to additional options through the Xerox App Gallery.
Xerox VersaLink B615V_XL - multifunction printer (B/W)
Fax / copier / printer / scanner
Fax Type
Plain paper
Printing Technology
LED (monochrome)
Max Copying Resolution
Up to 600 x 600 dpi
Max Printing Resolution
Up to 1200 x 1200 dpi
Max Printing Resolution Class
Scanning
600 x 600 dpi
Display
7"
Original Type
Sheets
Document Feeder Capacity
100 sheets
Media Size
76 x 127 mm (min)
Media Type
Envelopes, plain paper, labels, recycled paper, bond paper, card stock, punched paper, preprinted paper
Bypass Feeder Capacity
150 sheets
Automatic Duplexing
Yes (copying) Yes (printing) Yes (scanning)
PC Connection Availability
PC Connection
Gigabit LAN, USB host, NFC, USB 3.0
AirPrint Enabled
AC 230 V (50/60Hz)
Environmental Standards
ENERGY STAR Qualified
Fax Type
Plain paper
Printing Technology
LED - monochrome
Display Diagonal Size
7"
Colour Support
Display Features
Touch screen
PC Connection
AirPrint Enabled
Standard Memory
2 GB
Hard Disk Drive
250 GB
Copying
Up to 600 x 600 dpi
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
999
Automatic Duplexing
Printing
Printer Drivers / Emulations
PCL 5e, PCL 6, PostScript 3, PDF, TIFF, HPGL, XPS, JPEG
Automatic Duplexing
Scanning
Automatic Duplexing
Optical Resolution
600 x 600 dpi
Grayscale Depth
8-bit
Colour Depth
24-bit
Document & Media Handling
Original Type
Sheets
100 sheets
Min Media Size
76 x 127 mm
Min Media Weight
60 g/m²
Max Media Weight
220 g/m²
Supported Media Type
150 sheets
Security Protocols & Features
Secure Print, SSL, TLS, Secure Fax, IP filtering, port blocking, AES-256, Secure Scan, Secure Email
AC 230 V (50/60Hz)
ENERGY STAR Certified
10 °C
32 °C
15 - 85%
Brand: Xerox
Price Range Ex VAT: £1500+
