Xerox VersaLink B605V XL Mono Laser Multifunction Printer
Quicklinx: G1LWWS00 Mfr#: B605V_XL
For a black-and-white printer or multifunction printer, the VersaLink B605 is anything but basic. In fact, VersaLink sets a standard for what you can expect in workgroup productivity from Xerox. Home or away, this highly configurable, cloud-connected workplace assistant delivers amazing capabilities that go far beyond the competition - at a competitive price.
  • Easy, smart and secure
    Right out of the box, you'll count on your VersaLink B605 to consistently and flawlessly perform the tasks that make your business work more efficiently. Completely re-engineered for superior reliability, the VersaLink B605 features an advanced hardware design with fewer moving parts, strengthened paper-path components, and a more advanced print head.
  • Customizable, app-based functionality
    With the customizable, capacitive color touchscreen, you can tap, swipe and pinch your way through tasks and functions with mobile-like ease.
Xerox VersaLink B605V_XL - multifunction printer - B/W
Multifunction printer
Fax Type
Super G3 - plain paper
Printing Technology
LED (monochrome)
Monthly Duty Cycle (max)
250000 pages
Recommended Monthly Volume
20000 pages
Max Copying Speed
Up to 58 ppm
Max Copying Resolution
Up to 600 x 600 dpi
Max Copying Resolution Class
Up to 600 x 600 dpi
Max Printing Speed
Up to 55 ppm
Max Printing Resolution
Up to 1200 x 1200 dpi
Max Printing Resolution Class
Max Fax Transmission Speed
33.6 Kbps
Data Compression System
MH, MR, MMR, JBIG
Fax Resolutions
300 x 300 dpi, 200 x 200 dpi, 200 x 100 dpi, 600 x 600 dpi, 400 x 400 dpi
Scanning
600 x 600 dpi
Display
7"
Original Size
Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
100 sheets
Media Size
76 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Envelopes, plain paper, labels, recycled paper, bond paper, card stock, punched paper, preprinted paper
Standard Media Capacity
700 sheets
Max Media Capacity
3250 sheets
Bypass Feeder Capacity
150 sheets
Automatic Duplexing
Yes (copying) Yes (printing) Yes (scanning)
Connection Availability
Gigabit LAN, USB host, NFC, USB 3.0
AirPrint Enabled
Office Machine Features
Scan to e-mail, scan to network, scan to FTP, scan to SMB, scan to USB host, finisher and mailbox capable
AC 230 V (50/60Hz)
47 cm x 50.28 cm x 84.37 cm
32.5 kg
Pricing Type
Sold
Environmental Standards
ENERGY STAR Qualified
1-year warranty
Fax Type
Plain paper
Printing Technology
LED - monochrome
250000 pages
20000 pages
Display Diagonal Size
7"
Display Colour Support
Display Features
Touch screen
AirPrint Enabled
Standard Memory
2 GB
Hard Disk Drive
250 GB
Copying
Max Copying Speed
Up to 58 ppm
Up to 600 x 600 dpi
Up to 600 x 600 dpi
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
999
Automatic Duplexing
Copying Features
ID Card Copy, collation copy, Edge Erase, Book Copy, Auto Background Suppression
Printing
Max Printing Speed
Up to 55 ppm
Printer Drivers / Emulations
PCL 5e, PCL 6, PostScript 3, PDF, TIFF, HPGL, XPS, JPEG
Automatic Duplexing
First Print Out Time B/W
4 sec
Scanning
Automatic Duplexing
Optical Resolution
600 x 600 dpi
Grayscale Depth
8-bit
Colour Depth
24-bit
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
MH, MR, MMR, JBIG
Fax Resolutions
Fax Machine Features
Speed Dialing
2000 station(s)
Fax forwarding, LAN fax
Document & Media Handling
Max Original Size
Original Type
Sheets
100 sheets
Min Media Size
76 x 127 mm
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
220 g/m²
Min Media Weight (lb)
16 lbs (Cover)
Max Media Weight (lb)
80 lbs (Cover)
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm)
700 sheets
Max Media Capacity
3250 sheets
150 sheets
RADF - 100 sheets size: 140 x 140 mm - Legal (216 x 356 mm) weight: 60 g/m² - 128 g/m²; weight (lbs): 16 lbs (Bond) - 32 lbs (Bond) , Bypass tray - 150 sheets size: 76 x 127 mm - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m²; weight (lbs): 16 lbs (Cover) - 80 lbs (Cover) , Input tray - 550 sheets size: 76.2 x 190 mm - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m²; weight (lbs): 16 lbs (Cover) - 80 lbs (Cover)
Speed Details
Printing: up to 55 ppm (A4) - B/W , Printing: up to 49.3 ppm (A4) - B/W duplex , Copying: up to 58 ppm (A4) - B/W , Copying: up to 52.2 ppm (A4) - B/W duplex , Scanning: up to 58 ipm (A4) - B/W , Scanning: up to 55 ipm (A4) - colour , Scanning: up to 58 ipm (A4) - B/W duplex , Scanning: up to 55 ipm (A4) - colour duplex
USB host - 4 pin USB Type A , USB 3.0 - 9 pin USB Type B , Gigabit LAN - RJ-45
Security Protocols & Features
Secure Print, SSL, TLS, Secure Fax, IP filtering, port blocking, AES-256, Secure Scan, Secure Email
Operating System Support
Linux, MS Windows Server 2003, HP-UX 11i v3, MS Windows 7, MS Windows 2000 Server, MS Windows Server 2008, MS Windows Server 2008 R2, MS Windows Server 2012, Windows 8, Apple Mac OS X 10.10, Windows 10, Apple Mac OS X 10.11, macOS 10.12, SuSe Linux 13.2, Red Hat Enterprise Linux, IBM AIX 7.2, Oracle Solaris 11.3, Fedora 24
AC 230 V (50/60Hz)
950 watt
Power Consumption Standby
79 watt
Power Consumption Sleep
1.1 watt
Warm-Up Time
47 sec
First Copy Out Time B/W
5.2 sec
FIPS 140-2
Pricing Type
Sold
ENERGY STAR Certified
Limited warranty - 1 year - on-site
47 cm
50.28 cm
84.37 cm
32.5 kg
Shipping Width
59.4 cm
Shipping Depth
65.5 cm
Shipping Height
99.6 cm
Shipping Weight
43 kg
Sound Emission
29 dBA (idle) / 58.3 dBA (operating)
10 °C
32 °C
15 - 85%
Functionality: Printer
Functionality: Scanner
Functionality: Copier
Functionality: Fax
Max Paper Size: A4 (210 x 297 mm)
Brand: Xerox
Price Range Ex VAT: £1500+
