For a black-and-white printer or multifunction printer, the VersaLink B605 is anything but basic. In fact, VersaLink sets a standard for what you can expect in workgroup productivity from Xerox. Home or away, this highly configurable, cloud-connected workplace assistant delivers amazing capabilities that go far beyond the competition - at a competitive price.
Easy, smart and secure
Right out of the box, you'll count on your VersaLink B605 to consistently and flawlessly perform the tasks that make your business work more efficiently. Completely re-engineered for superior reliability, the VersaLink B605 features an advanced hardware design with fewer moving parts, strengthened paper-path components, and a more advanced print head. -
Customizable, app-based functionality
With the customizable, capacitive color touchscreen, you can tap, swipe and pinch your way through tasks and functions with mobile-like ease.
 - Xerox VersaLink B605V_X - multifunction printer - B/W
 - Multifunction printer
- Fax Type
 - Super G3 - plain paper
- Printing Technology
 - LED (monochrome)
- Monthly Duty Cycle (max)
 - 250000 pages
- Recommended Monthly Volume
 - 20000 pages
- Max Copying Speed
 - Up to 58 ppm
- Max Copying Resolution
 - Up to 600 x 600 dpi
- Max Printing Speed
 - Up to 55 ppm
- Max Printing Resolution
 - Up to 1200 x 1200 dpi
- Max Printing Resolution Class
- Max Fax Transmission Speed
 - 33.6 Kbps
- Data Compression System
 - MH, MR, MMR, JBIG
- Fax Resolutions
 - 300 x 300 dpi, 200 x 200 dpi, 200 x 100 dpi, 600 x 600 dpi, 400 x 400 dpi
- Scanning
 - 600 x 600 dpi
- Display
 - 7"
- Original Size
 - Legal (216 x 356 mm) (max)
- Original Type
 - Sheets
- Document Feeder Capacity
 - 100 sheets
- Media Size
 - 76 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
 - Envelopes, plain paper, labels, recycled paper, bond paper, card stock, punched paper, preprinted paper
- Standard Media Capacity
 - 700 sheets
- Max Media Capacity
 - 3250 sheets
- Bypass Feeder Capacity
 - 150 sheets
- Output Trays Capacity
 - 400 sheets
- Automatic Duplexing
 - Yes (copying) Yes (printing) Yes (scanning)
- Connection Availability
- Interface
 - Gigabit LAN, USB host, NFC, USB 3.0
- AirPrint Enabled
- Office Machine Features
 - Scan to e-mail, scan to network, scan to FTP, scan to SMB, scan to USB host
- Power
 - AC 230 V (50/60Hz)
 - 47 cm x 50.28 cm x 64.37 cm
 - 30.5 kg
- Pricing Type
 - Sold
- Environmental Standards
 - ENERGY STAR Qualified
 - 1-year warranty
- Fax Type
 - Plain paper
 - LED - monochrome
 - 250000 pages
 - 20000 pages
- Display Diagonal Size
 - 7"
- Display Colour Support
- Display Features
 - Touch screen
- Interface
- AirPrint Enabled
- Standard Memory
 - 2 GB
- Hard Disk Drive
 - 250 GB
Copying
- Max Copying Speed
 - Up to 58 ppm
- Max Document Enlargement
 - 400%
- Max Document Reduction
 - 25%
- Maximum Copies
 - 999
- Copying Features
 - ID Card Copy, collation copy, Edge Erase, Book Copy, Auto Background Suppression
Printing
 - Up to 55 ppm
- Printer Drivers / Emulations
 - PCL 5e, PCL 6, PostScript 3, PDF, TIFF, HPGL, XPS, JPEG
- First Print Out Time B/W
 - 4 sec
Scanning
- Optical Resolution
 - 600 x 600 dpi
- Grayscale Depth
 - 8-bit
- Colour Depth
 - 24-bit
Fax Machine
- Compatibility
 - Super G3
- Max Transmission Speed
 - 33.6 Kbps
 - MH, MR, MMR, JBIG
- Fax Resolutions
Fax Machine Features
- Speed Dialing
 - 2000 station(s)
 - Fax forwarding, LAN fax
Document & Media Handling
- Max Original Size
- Original Type
 - Sheets
 - 100 sheets
- Min Media Size
 - 76 x 127 mm
- Max Media Size
 - A4/Legal
- Min Media Weight
 - 60 g/m²
- Max Media Weight
 - 220 g/m²
- Min Media Weight (lb)
 - 16 lbs (Cover)
- Max Media Weight (lb)
 - 80 lbs (Cover)
- Supported Media Type
- Supported Media Sizes
 - ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm)
 - 700 sheets
 - 3250 sheets
 - 150 sheets
 - 400 sheets
 - RADF - 100 sheets size: 140 x 140 mm - Legal (216 x 356 mm) weight: 60 g/m² - 128 g/m²; weight (lbs): 16 lbs (Bond) - 32 lbs (Bond) , Bypass tray - 150 sheets size: 76 x 127 mm - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m²; weight (lbs): 16 lbs (Cover) - 80 lbs (Cover) , Input tray - 550 sheets size: 76.2 x 190 mm - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m²; weight (lbs): 16 lbs (Cover) - 80 lbs (Cover) , Output tray - 400 sheets
- Speed Details
 - Printing: up to 55 ppm (A4) - B/W , Printing: up to 49.3 ppm (A4) - B/W duplex , Copying: up to 58 ppm (A4) - B/W , Copying: up to 52.2 ppm (A4) - B/W duplex , Scanning: up to 58 ipm (A4) - B/W , Scanning: up to 55 ipm (A4) - colour , Scanning: up to 58 ipm (A4) - B/W duplex , Scanning: up to 55 ipm (A4) - colour duplex
 - USB host - 4 pin USB Type A , USB 3.0 - 9 pin USB Type B , Gigabit LAN - RJ-45
 - Secure Print, SSL, TLS, Secure Fax, IP filtering, port blocking, AES-256, Secure Scan, Secure Email
- Operating System Support
 - Linux, MS Windows Server 2003, HP-UX 11i v3, MS Windows 7, MS Windows 2000 Server, MS Windows Server 2008, MS Windows Server 2008 R2, MS Windows Server 2012, Windows 8, Apple Mac OS X 10.10, Windows 10, Apple Mac OS X 10.11, macOS 10.12, SuSe Linux 13.2, Red Hat Enterprise Linux, IBM AIX 7.2, Oracle Solaris 11.3, Fedora 24
- Voltage Required
 - 950 Watt
- Power Consumption Standby
 - 79 Watt
- Power Consumption Sleep
 - 1.1 Watt
- Warm-Up Time
 - 47 sec
- First Copy Out Time B/W
 - 5.2 sec
 - FIPS 140-2
- Pricing Type
 - Sold
- ENERGY STAR Certified
 - Limited warranty - 1 year - on-site
 - 47 cm
 - 50.28 cm
 - 64.37 cm
 - 30.5 kg
- Shipping Width
 - 59.4 cm
- Shipping Depth
 - 65.5 cm
- Shipping Height
 - 78.9 cm
- Shipping Weight
 - 38 kg
- Sound Emission
 - 29 dBA (idle) / 58.3 dBA (operating)
 - 10 °C
 - 32 °C
 - 15 - 85%
