Xerox VersaLink B600V DN Mono Laser Printer
Quicklinx: G1LQWS00 Mfr#: B600V_DN
Type: Printer
Functionality: Printer
Wireless Capability: Wired
Max Paper Size: A4 (210 x 297 mm), Legal (216 x 356 mm)
£690.57 ex VAT
£828.68 inc VAT
For a black and white printer or multifunction printer, the VersaLink B600 is anything but basic. In fact, VersaLink sets an advanced standard for what you can expect in work group productivity from Xerox. Home or away, this highly configurable, cloud-connected workplace assistant delivers great capabilities - at a competitive price.
  • Easy, smart and secure
    Right out of the box, you'll count on your VersaLink B600 to consistently and flawlessly perform the tasks that make your business work more efficiently. From IT-free installation wizards, to step-by-step configuration options, you're ready to go - hassle free. Completely re-engineered for superior reliability, the VersaLink B600 features an advanced hardware design with fewer moving parts, strengthened paper-path components, and a more advanced Hi-Q LED print head. VersaLink devices are loaded with features and time-saving Xerox technologies designed to speed up information sharing and reduce inefficient workflows.
  • Customizable functionality
    With the customizable, capacitive color touchscreen, you can tap, swipe and pinch your way through tasks and functions with mobile-like ease. Preloaded Xerox ConnectKey Apps help optimize office efficiency, and on-screen access to the extensive Xerox App Gallery provides expanded functionality. Speed through tasks by saving common settings as presets for simple, single-touch job setup. With Simple ID, individual users and groups enter a user ID and password once, and then enjoy fast, secure, easy access to task-specific presets and commonly used apps on a personalized home screen.
  • Intuitive user experience
    An advanced - and yet entirely familiar way to interact that includes a tablet-like experience with gesture-based touchscreen controls and easy customization.
  • Benchmark security
    Full multi-level protection for both documents and data, ready to guard against and eliminate emerging threats and meet or exceed regulatory compliance.
Xerox VersaLink B600V_DN - printer - B/W - LED
Printer Type
Workgroup printer - LED - B/W
22.3 kg
Media Size Class
A4/Legal
Max Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm)
Min Media Size (Custom)
76 mm x 127 mm
Max Media Size (Custom)
216 mm x 356 mm
Print Speed
Up to 55 ppm - B/W - A4 (210 x 297 mm) , Up to 49.3 ppm - B/W duplex - A4 (210 x 297 mm)
Max Resolution (B&W)
1200 x 1200 dpi
Max Resolution Class (B&W)
1200 x 1200 dpi
Automatic Duplexing
Gigabit LAN, USB host, NFC, USB 3.0
AirPrint Enabled
Preview Screen Size
5"
ARM 1.05 GHz
RAM Installed (Max)
2 GB
Hard Drive
250 GB
Language Simulation
PCL 5E, PostScript 3, PCL 6, HP GL, PDF, XPS, TIFF, JPEG
Media Type
Envelopes, labels, plain paper, bond paper, recycled paper, card stock, punched paper, preprinted paper
Total Media Capacity
700 sheets
Media Handling
150-sheet bypass tray, 550-sheet input tray
Monthly Duty Cycle (max)
250000 pages
Recommended Monthly Volume
20000 pages
Print server
Linux, Microsoft Windows 2000 Server, Microsoft Windows Server 2003, Red Hat Enterprise Linux, Microsoft Windows Server 2008 R2, HP-UX 11i v3, Microsoft Windows Server 2008, Microsoft Windows Server 2012, Apple MacOS X 10.10, Microsoft Windows 7 / 8 / 10, Apple MacOS X 10.11, Oracle Solaris 11.3, IBM AIX 7.2, Red Hat Fedora Core 24, SUSE Linux 13.2, Apple macOS 10.12
42.74 cm x 46.55 cm x 44.34 cm
Printer Type
Workgroup printer - LED - monochrome
Printer
Print Speed
Built-in Devices
Touch screen
Preview Screen Size
5"
Wired
AirPrint Enabled
1200 x 1200 dpi
1200 x 1200 dpi
Automatic Duplexing
PostScript Support
Standard
First Print Out Time B/W
6.3 sec
Language Simulation
Fonts Included
136 x PostScript , 83 x PCL
Media Handling
ARM 1.05 GHz
RAM
RAM Installed (Max)
2 GB
Storage
Hard Drive
250 GB
Media Handling
Media Type
Media Size Class
A4/Legal
Max Media Size
76 mm x 127 mm
216 mm x 356 mm
Media Sizes
Media Weight
60 g/m² - 220 g/m²
700 sheets
Media Feeders
Input tray: 1 x automatic - 150 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m² , Input tray: 1 x automatic - 550 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m² , Output tray: 1 - 500 sheets
Max Media Capacity
3250 sheets
Max Sheets in Multi-Part Form
150
Output Trays Capacity
500 sheets
Duty Cycle
250000 pages
20000 pages
Print server
Remote Management Protocol
SNMP, SNMP 3, HTTP, HTTPS
Security Protocols & Features
LDAP, Secure Print, Apple Bonjour, TLS, IP filtering, port blocking
USB 3.0 , Gigabit LAN - RJ-45 , USB host
Consumables Included
1 x toner cartridge (black)
FIPS 140-2
Power supply - internal
Frequency Required
50/60 Hz
900 Watt
Power Consumption Stand by
72 Watt
Power Consumption Sleep
0.9 Watt
Environmental Standards
ENERGY STAR
10 °C
32 °C
15 - 85%
Sound Emission (Idle)
27.1 dBA
Sound Emission (Operating)
56.8 dBA
42.74 cm
46.55 cm
44.34 cm
22.3 kg
Width (Shipping)
58 cm
Depth (Shipping)
63.4 cm
Height (Shipping)
60.7 cm
Weight (Shipping)
28 kg
Type: Printer
Brand: Xerox
Price Range Ex VAT: £500 - £750
