For a black and white printer or multifunction printer, the VersaLink B600 is anything but basic. In fact, VersaLink sets an advanced standard for what you can expect in work group productivity from Xerox. Home or away, this highly configurable, cloud-connected workplace assistant delivers great capabilities - at a competitive price.
Easy, smart and secure
Right out of the box, you'll count on your VersaLink B600 to consistently and flawlessly perform the tasks that make your business work more efficiently. From IT-free installation wizards, to step-by-step configuration options, you're ready to go - hassle free. Completely re-engineered for superior reliability, the VersaLink B600 features an advanced hardware design with fewer moving parts, strengthened paper-path components, and a more advanced Hi-Q LED print head. VersaLink devices are loaded with features and time-saving Xerox technologies designed to speed up information sharing and reduce inefficient workflows. -
Customizable functionality
With the customizable, capacitive color touchscreen, you can tap, swipe and pinch your way through tasks and functions with mobile-like ease. Preloaded Xerox ConnectKey Apps help optimize office efficiency, and on-screen access to the extensive Xerox App Gallery provides expanded functionality. Speed through tasks by saving common settings as presets for simple, single-touch job setup. With Simple ID, individual users and groups enter a user ID and password once, and then enjoy fast, secure, easy access to task-specific presets and commonly used apps on a personalized home screen. -
Intuitive user experience
An advanced - and yet entirely familiar way to interact that includes a tablet-like experience with gesture-based touchscreen controls and easy customization. -
Benchmark security
Full multi-level protection for both documents and data, ready to guard against and eliminate emerging threats and meet or exceed regulatory compliance.
 - Xerox VersaLink B600V_DN - printer - B/W - LED
- Printer Type
 - Workgroup printer - LED - B/W
 - 22.3 kg
- Media Size Class
 - A4/Legal
- Max Media Size
 - Legal (216 x 356 mm), A4 (210 x 297 mm)
- Min Media Size (Custom)
 - 76 mm x 127 mm
- Max Media Size (Custom)
 - 216 mm x 356 mm
- Print Speed
 - Up to 55 ppm - B/W - A4 (210 x 297 mm) , Up to 49.3 ppm - B/W duplex - A4 (210 x 297 mm)
- Max Resolution (B&W)
 - 1200 x 1200 dpi
- Max Resolution Class (B&W)
 - 1200 x 1200 dpi
- Automatic Duplexing
- Interface
 - Gigabit LAN, USB host, NFC, USB 3.0
- AirPrint Enabled
- Preview Screen Size
 - 5"
- Processor
 - ARM 1.05 GHz
- RAM Installed (Max)
 - 2 GB
- Hard Drive
 - 250 GB
- Language Simulation
 - PCL 5E, PostScript 3, PCL 6, HP GL, PDF, XPS, TIFF, JPEG
- Media Type
 - Envelopes, labels, plain paper, bond paper, recycled paper, card stock, punched paper, preprinted paper
- Total Media Capacity
 - 700 sheets
- Media Handling
 - 150-sheet bypass tray, 550-sheet input tray
- Monthly Duty Cycle (max)
 - 250000 pages
- Recommended Monthly Volume
 - 20000 pages
- Networking
 - Print server
- System Requirements
 - Linux, Microsoft Windows 2000 Server, Microsoft Windows Server 2003, Red Hat Enterprise Linux, Microsoft Windows Server 2008 R2, HP-UX 11i v3, Microsoft Windows Server 2008, Microsoft Windows Server 2012, Apple MacOS X 10.10, Microsoft Windows 7 / 8 / 10, Apple MacOS X 10.11, Oracle Solaris 11.3, IBM AIX 7.2, Red Hat Fedora Core 24, SUSE Linux 13.2, Apple macOS 10.12
 - 42.74 cm x 46.55 cm x 44.34 cm
- Printer Type
 - Workgroup printer - LED - monochrome
Printer
- Print Speed
- Built-in Devices
 - Touch screen
 - 5"
- Connectivity Technology
 - Wired
- Interface
- AirPrint Enabled
 - 1200 x 1200 dpi
 - 1200 x 1200 dpi
- PostScript Support
 - Standard
- First Print Out Time B/W
 - 6.3 sec
- Fonts Included
 - 136 x PostScript , 83 x PCL
- Media Handling
- Processor
 - ARM 1.05 GHz
RAM
 - 2 GB
Storage
- Hard Drive
 - 250 GB
Media Handling
- Media Type
- Media Size Class
 - A4/Legal
- Max Media Size
 - 76 mm x 127 mm
 - 216 mm x 356 mm
- Media Sizes
- Media Weight
 - 60 g/m² - 220 g/m²
 - 700 sheets
- Media Feeders
 - Input tray: 1 x automatic - 150 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m² , Input tray: 1 x automatic - 550 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m² , Output tray: 1 - 500 sheets
- Max Media Capacity
 - 3250 sheets
- Max Sheets in Multi-Part Form
 - 150
- Output Trays Capacity
 - 500 sheets
Duty Cycle
 - 250000 pages
 - 20000 pages
- Networking
 - Print server
- Remote Management Protocol
 - SNMP, SNMP 3, HTTP, HTTPS
 - LDAP, Secure Print, Apple Bonjour, TLS, IP filtering, port blocking
- Connections
 - USB 3.0 , Gigabit LAN - RJ-45 , USB host
- Consumables Included
 - 1 x toner cartridge (black)
 - FIPS 140-2
- Power Device
 - Power supply - internal
- Frequency Required
 - 50/60 Hz
 - 900 Watt
- Power Consumption Stand by
 - 72 Watt
- Power Consumption Sleep
 - 0.9 Watt
- OS Required
Environmental Standards
- ENERGY STAR
 - 10 °C
 - 32 °C
 - 15 - 85%
- Sound Emission (Idle)
 - 27.1 dBA
- Sound Emission (Operating)
 - 56.8 dBA
 - 42.74 cm
 - 46.55 cm
 - 44.34 cm
 - 22.3 kg
- Width (Shipping)
 - 58 cm
- Depth (Shipping)
 - 63.4 cm
- Height (Shipping)
 - 60.7 cm
- Weight (Shipping)
 - 28 kg
