Xerox VersaLink B405V DN Mono Laser Multifunction Printer
Quicklinx: G1LSWS00 Mfr#: B405V_DN?GB
£620.45 ex VAT
£744.54 inc VAT
Whether stand-alone or as a part of your extended fleet, the Xerox VersaLink B405 multifunction printer take your team to high levels of productivity. Work the way you want - from any device - with maximum security and easy connectivity to and from both cloud and network-based locations.
  • Easy, optimized productivity
    Right out of the box, you'll count on your Xerox VersaLink B405 multifunction printer to consistently and flawlessly perform the tasks that make your business work more efficiently. From IT-free installation wizards, to step-by-step configuration options, you're ready to go - hassle free. And count on day in, day out reliability thanks to the paper path technology. VersaLink devices are loaded with features and time-saving Xerox technologies designed to speed up information sharing and reduce inefficient workflows. Ensure information accuracy with Scan and Fax preview, and do more with scanned documents with built-in optical character recognition (OCR). Print with total peace of mind knowing that VersaLink devices deliver a spectrum of stringent security features, including Secure Print and card authentication to control access.
  • An entirely advanced way to work
    With the customizable 5-inch color touchscreen, you can tap, swipe and pinch your way through tasks and functions with mobile-like ease. Preloaded Xerox ConnectKey apps help optimize office efficiency. Speed through tasks by saving common settings as presets for simple, single-touch job setup. With Simple ID, individual users and groups enter a user ID and password once, and then enjoy fast, secure, easy access to task-specific presets and commonly used apps on a personalized home screen.
  • Touch screen superiority
    The tiltable, 5-inch capacitive color touch screen is the user interface that sets a higher standard for customization, personalization and versatility. By presenting a familiar "mobile" experience - with support for gestural input and task-focused apps that share a common look and feel - fewer steps are needed to complete even the most complex jobs. A highly intuitive layout guides you through every task from start to finish, with a natural hierarchy placing critical functions near the top of the screen and commonly used options front and center.
Xerox VersaLink B405V/DN - multifunction printer - B/W
Multifunction printer
Fax Type
Super G3 - plain paper
Printing Technology
Laser (monochrome)
Monthly Duty Cycle (max)
110000 pages
Recommended Monthly Volume
12000 pages
Max Copying Speed
Up to 36 ppm
Max Copying Resolution
Up to 600 x 600 dpi
Max Printing Speed
Up to 45 ppm
Max Printing Resolution
Up to 1200 x 1200 dpi
Max Fax Transmission Speed
33.6 Kbps
Data Compression System
MH, MR, MMR, JBIG
Fax Resolutions
600 x 600 dpi
Scanning
600 x 600 dpi
Original Size
76.2 x 127 mm (min) - Legal (216 x 356 mm) (max)
Document Feeder Capacity
60 sheets
Media Size
76.2 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Envelopes, plain paper, labels, recycled paper, bond paper, card stock, punched paper, preprinted paper
Standard Media Capacity
700 sheets
Max Media Capacity
1250 sheets
Output Trays Capacity
250 sheets
Automatic Duplexing
Yes (copying) Yes (printing) Yes (scanning)
Connection Availability
Gigabit LAN, NFC, USB 3.0
AirPrint Enabled
Office Machine Features
Scan to e-mail, scan to network, scan to USB host
AC 230 V (50/60Hz)
49.5 cm x 49.5 cm x 55.1 cm
22 kg
Fax Type
Plain paper
Printing Technology
Laser - monochrome
110000 pages
12000 pages
AirPrint Enabled
Standard Memory
2 GB
Copying
Max Copying Speed
Up to 36 ppm
Up to 600 x 600 dpi
Max Document Enlargement
400%
Max Document Reduction
25%
Automatic Duplexing
Copying Features
ID Card Copy, Edge Erase, Book Copy
Printing
Max Printing Speed
Up to 45 ppm
Printer Drivers / Emulations
PCL 5e, PCL 6, PostScript 3, PDF, TIFF, HPGL, JPEG
Automatic Duplexing
First Print Out Time B/W
5.1 sec
Scanning
Automatic Duplexing
Optical Resolution
600 x 600 dpi
Grayscale Depth
8-bit
Colour Depth
24-bit
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
MH, MR, MMR, JBIG
Fax Resolutions
600 x 600 dpi
Document & Media Handling
Min Original Size
76.2 x 127 mm
Max Original Size
60 sheets
Min Media Size
76.2 x 127 mm
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
220 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm)
700 sheets
Max Media Capacity
1250 sheets
250 sheets
RADF - 60 sheets size: 139.7 x 139.7 mm - Legal (216 x 356 mm) weight: 60 g/m² - 125 g/m² , Bypass tray - 150 sheets size: 76.2 x 127 mm - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m² , Output tray - 250 sheets , Input tray - 550 sheets size: 148 x 210 mm - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m²
Speed Details
Printing: up to 45 ppm (Letter A) - B/W , Printing: up to 45 ppm (A4) - B/W
1 x USB 3.0 , 1 x Gigabit LAN
Security Protocols & Features
Secure Print, TLS, Secure Fax, Secure Scan, Secure Email
Software Included
Xerox CentreWare Web
AC 230 V (50/60Hz)
620 Watt
Power Consumption Standby
60 Watt
Power Consumption Sleep
4 Watt
First Copy Out Time B/W
6.2 sec
Consumables Included
1 x toner cartridge (black) - up to 5900 pages
FIPS 140-2
49.5 cm
49.5 cm
55.1 cm
22 kg
Shipping Width
61.8 cm
Shipping Depth
62.6 cm
Shipping Height
71.3 cm
Shipping Weight
27.1 kg
Sound Emission
52.3 dBA (idle) / 28.7 dBA (operating)
10 °C
32 °C
10 - 85%
G1LS Xerox Standard Capacity Black Toner Cartridge (6000 Pages) In Stock £153.84
G1LS Xerox Extra High Capacity Black Toner Cartridge (25000 Pages) In Stock £353.81
Functionality: Fax
Functionality: Scanner
Functionality: Copier
Functionality: Printer
Max Paper Size: A4 (210 x 297 mm)
Brand: Xerox
Price Range Ex VAT: £500 - £750
