Save big when you bring your workgroup's diverse and high-volume color printing in house. The Phaser 7500 sports plenty of features that make it a perfect fit for the office on-demand print environment.
Produce brilliant, accurate color right "out of the box". The Phaser 7500 printer delivers the tools to make you look like a color expert.
Running complex jobs doesn't have to be complicated. The Phaser 7500 offers superior printer management capabilities and innovative features that make it especially easy to use.
Phaser 7500
Professional-level colour your entire office can enjoy. The Phaser 7500, our new, robust, network-ready printer will fit right in with your busy office, handling professional-quality print jobs with ease. You'll get inspired colour control features, simplified print management tools and the power to do more than ever before. All at a price that's sure to leave you smiling. -
Quick Facts
Colour: up to 35 ppmBlack: up to 35 ppmFirst-page-out-time: As fast as 7 seconds colour / 7 seconds black and whiteProcessor: 1 GHz Freescale PowerGUICC IIINetwork connectivity standardPrint resolution: up to 1200 x 1200 dpiMaximum duty cycle: up to 150,000 pages/monthMaximum paper size: 320 x 1,200 mmMinimum dimensions (w x d x h): 640 x 665 x 770 mmWhat comes in the boxColour toner cartridges (capacity: 9,600 pages each1)Black toner cartridge (capacity: 19,800 pages1)Power cordSoftware and documentation -
On-demand productivity
Fast print speeds (up to 35 ppm and first-page-out as fast 7 seconds) mean you don't have to wait, even for complex colour jobsBuilt-in networking is standard so all users-Microsoft Windows, Apple Macintosh and Linux-can tap into the fast Gigabit EthernetIncrease accountability and reduce costs with features that track and analyze colour and black-only printing, and help you accurately charge back billing for individuals or departmentsScale to fit your workgroup's space from a low-profile desktop model to a highly productive floor-standing model with three additional oversize media ready 500-sheet traysPrint in-house with Phaser 7500 instead of sending jobs out to commercial printers or quick copy shops, saving time and money -
Quality colour you can count on
Up to 1200 x 1200 dpi image resolution gives you sharp, detailed prints on the Phaser 7500Precise colour matching with Pantone -approved colour tables and true Adobe PostScript 3 mean your prints will look exactly as you intendedXerox Emulsion Aggregate (EA) Toner produces the smallest toner particles in the market, resulting in finer lines, higher contrast and sharper image quality. It requires less energy to manufacture and less toner per page.Consistent output print after print is ensured thru advanced automatic colour calibration requiring no user interventionColor By Words colour correction lets you select desired colour modifications from a simple drop-down list -
Easy to use and manage
Easily manage, configure and troubleshoot the Phaser 7500 from any computer using CentreWare Internet Services network web administration toolsEasy-open access is in front so you don't need to rotate or move the Phaser 7500 to change toner or add paperGet immediate updates on your print job status, toner supply levels and troubleshooting tips via the front panel, your desktop or the webStore frequently printed files on the built-in hard drive (standard on 7500DX) for fast, easy, walk-up printingPrivate data stays secure with Secure Print, which holds the job in the queue until a PIN is entered at the printer, and Hard Drive overwrite "shreds" data after every job or requestBuilt-in support for security protocols, including IPv6, 802.1x and IPSec, makes the Phaser 7500 a good network citizen 1 Average standard pages. Declared Yield in accordance with ISO/IEC 19798. Yield will vary based on image, area coverage and print mode.
- Xerox Phaser 7500DX - printer - colour - LED
- Printer Type
- Workgroup printer - LED - colour
- 99 kg
- Max Media Size
- 320 x 1200 mm
- Min Media Size (Custom)
- 89 mm x 99 mm
- Max Media Size (Custom)
- 320 mm x 1200 mm
- Print Speed
- Up to 35 ppm - B/W , Up to 35 ppm - colour
- Max Resolution (B&W)
- 1200 dpi
- Max Resolution (Colour)
- 1200 dpi
- Automatic Duplexing
- Interface
- USB 2.0, Gigabit LAN
- Processor
- Power QUICC III 1 GHz
- RAM Installed (Max)
- 512 MB (2 GB) - DDR2 SDRAM - SO-DIMM 200-pin
- Hard Drive
- 40 GB
- Language Simulation
- PCL 5C, PostScript 3, PDF 1.4
- Media Type
- Envelopes, transparencies, labels, plain paper, banners, cards, cover paper, glossy paper
- Total Media Capacity
- 2100 sheets
- Media Handling
- 100-sheet multipurpose tray, 4x 500-sheet input trays
- Monthly Duty Cycle (max)
- 150000 pages
- Networking
- Print server - Ethernet, Fast Ethernet, Gigabit Ethernet
- System Requirements
- Microsoft Windows 2000, SunSoft Solaris 8, SunSoft Solaris 9, HP-UX 11i v2, Microsoft Windows Server 2003, Apple MacOS X 10.3 or later, SunSoft Solaris 10, Red Hat Fedora Core 1, Red Hat Fedora Core 2, HP-UX 11, Red Hat Fedora Core 4, SuSE Linux 10.0, IBM AIX 5L 5.3, Red Hat Fedora Core 3, Red Hat Fedora Core 5, Red Hat Linux 4, Microsoft Windows Vista / XP, Microsoft Windows Server 2008
- Microsoft Certification
- Works with Windows Vista
- Environmental Standards
- EPEAT Silver
- 1-year warranty
- 64 cm x 66.5 cm x 77 cm
- Printer Type
Printer
- Print Speed
- Connectivity Technology
- Wired
- Interface
- 1200 dpi
- 1200 dpi
- PostScript Support
- Standard
- First Print Out Time B/W
- 7 sec
- First Print Out Time Colour
- 7 sec
- Fonts Included
- 81 x PCL 5c , 139 x PostScript
- Colour Management Features
- PANTONE Digital Color
- Media Handling
- Processor
RAM
- 512 MB / 2 GB (max)
- Technology / Form Factor
- Slots Qty
- 2
- Empty Slots
- 1
Storage
- Hard Drive
- 40 GB
Media Handling
- Media Type
- Max Media Size
- 320 x 1200 mm
- 89 mm x 99 mm
- 320 mm x 1200 mm
- Media Sizes
- A3 (297 x 420 mm)
- Media Weight
- 67 g/m² - 280 g/m²
- 2100 sheets
- Media Feeders
- 1 x automatic - 100 sheets - 320 x 1200 mm weight: 67 g/m² - 280 g/m² , 1 x automatic - 500 sheets - 297 x 432 mm weight: 67 g/m² - 256 g/m² , 3 x automatic - 500 sheets - 330 x 457 mm weight: 67 g/m² - 256 g/m²
- Max Media Capacity
- 2100 sheets
- Output Trays Capacity
- 400 sheets
Duty Cycle
- 150000 pages
- Networking
- Print server
- Data Link Protocol
- TCP/IP, UDP/IP, LPR/LPD, FTP, DHCP
- Remote Management Protocol
- SNMP 3, IPP, HTTP, HTTPS, FTP
- Secure Print, IPsec, 802.1x
- IEEE 802.1x
- Connections
- 1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45
- Included Accessories
- Installation guide, user manual (on CD), power cable
- Consumables Included
- 1 x toner cartridge (black) - up to 19800 pages , 1 x toner cartridge (cyan) - up to 9600 pages , 1 x toner cartridge (magenta) - up to 9600 pages , 1 x toner cartridge (yellow) - up to 9600 pages
- Software and devices that carry the Works with Windows Vista logo have been tested for baseline compatibility with PC's running.
- FCC Class A certified, FCC Part 15, RoHS, UL 60950-1, CSA C22.2 No. 60950-1-03, Section 508
- Power Device
- Power supply - internal
- Frequency Required
- 50/60 Hz
- 670 Watt
- Power Consumption Stand by / Sleep
- 95 Watt
- Software Included
- Drivers & Utilities
- OS Required
- EPEAT Compliant
- EPEAT Silver
- ENERGY STAR
- Limited warranty - 1 year - on-site
- 10 °C
- 32 °C
- 10 - 80%
- Sound Emission (Operating)
- 51 dBA
- Sound Emission (Quiet Mode)
- 26 dBA
- 64 cm
- 66.5 cm
- 77 cm
- 99 kg
- Width (Shipping)
- 77.5 cm
- Depth (Shipping)
- 95.3 cm
- Height (Shipping)
- 76.2 cm
- Weight (Shipping)
- 118 kg
C2G 2m USB 2.0 A/B Cable - Black | In Stock | £4.05 |
