The value of enhancing your company's image is immeasurable. And with the value-packed Phaser 6600 color printer, today's busy workgroups can easily make important business communications stand out from the competition with exceptional color printing.
Print Quality Features
- A print resolution of up to 600 x 600 x 4 dpi (1200 x 1200 enhanced image quality) makes your printed communications stand out and grab attention.
- Photo Mode makes your images and graphics look exceptional, producing deeper, richer colours for lifelike vibrancy.
- Unique Xerox EA Toner fuses at a much lower temperature, and reduces power consumption by up to 20% and C02 emissions by up to 35%, compared to conventional toner. It's also oil-free, delivering brilliant, glossy output, even on ordinary or recycled paper.
- Pantone® Colour calibrated solid-colour simulations and Xerox colour correction technology ensure results that match your expectations.
- True Adobe® PostScript® 3™ ensures your print jobs are consistently accurate, with the brightest, truest colours and superior graphics.
Productivity and Reliability Features
- A fast print speed of up to 35 ppm means your documents are always ready when you need them.
- Automatic duplex printing on the Phaser 6600DN configuration makes saving paper easy, and gives your documents a professional appearance.
- Print directly from Apple iOS-based devices with support for Apple AirPrint. (Requires firmware level 201301301313.)
- The main 550-sheet paper tray holds a full ream of paper. An optional 2nd tray increases total capacity up to 1,250 sheets for even longer periods of uninterrupted productivity.
- Keep your sensitive documents away from unintended recipients with available secure print*. *Requires Productivity Kit (with 512 MB RAM) or Productivity Kit (with 160 GB Hard Drive).
- A monthly duty cycle of up to 80,000 prints means heavy duty production.
Ease-of-use Features
- The Phaser 6600 is simple to install on your office network, getting you up and running in minutes. And with Xerox® CentreWare® IS, remote device administration is handled with ease right from any networked computer's browser.
- Place the Phaser 6600 anywhere in the office with optional Wi-Fi.
Prints that sell your business
A print resolution of up to 600 x 600 x 4 dpi (1200 x 1200 enhanced image quality) makes your printed communications stand out and grab attention. -
Enhanced output
Photo mode makes your images and graphics look exceptional, producing deeper, richer colors for lifelike vibrancy. -
Unique Xerox EA toner
Fuses at a much lower temperature, and reduces power consumption by up to 20%, compared to conventional toner. It's also oil-free, delivering brilliant, glossy output, even on ordinary or recycled paper. -
Always the right color
Pantone color calibrated solid-color simulations and Xerox color correction technology ensure results that match your expectations. -
Consistent precision
True Adobe PostScript 3 ensures your print jobs are consistently accurate, with the brightest, truest colors and superior graphics. High-power capabilities the Phaser 6600 and delivers a host of capabilities and powerful options made affordable for small work teams. -
Reduce your paper usage
Automatic two-sided printing on the DN configurations makes saving paper easy, and gives your documents a professional appearance. Plus, N-up printing lets you output multiple pages on one sheet, which is particularly useful when printing presentations. -
Less to replace
High-capacity toner cartridges allow longer periods of uninterrupted productivity, and help you reduce your total cost of operation over time. -
Stay secure
Keep your sensitive documents away from unintended recipients with available secure print, and protect access to device features with front-panel PIN code authentication. -
Print and go
The Phaser 6600 works quickly, with color and black-and-white print speeds of up to 36 ppm. -
Load paper less often
The main 550-sheet paper tray holds a full ream of paper - no more half-empty packages taking up valuable storage space. The total capacity up to 1250 sheets for even longer periods of uninterrupted productivity.
- Xerox Phaser 6600DN - printer - colour - laser
- Printer Type
- Workgroup printer - laser - colour
- 25.5 kg
- Media Size Class
- A4/Legal
- Max Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm)
- Min Media Size (Custom)
- 76.2 mm x 127 mm
- Max Media Size (Custom)
- 216 mm x 356 mm
- Print Speed
- Up to 35 ppm - B/W - A4 (210 x 297 mm) , Up to 35 ppm - colour - A4 (210 x 297 mm)
- Max Resolution (B&W)
- 1200 dpi
- Max Resolution (Colour)
- 1200 dpi
- Automatic Duplexing
- Interface
- USB, Gigabit LAN
- Processor
- 533 MHz
- RAM Installed (Max)
- 256 MB (768 MB)
- Language Simulation
- PCL 5, PostScript 3, PCL 6, XPS
- Media Type
- Plain paper
- Total Media Capacity
- 700 sheets
- Media Handling
- 150-sheet multipurpose tray, 550-sheet input tray
- Monthly Duty Cycle (max)
- 80000 pages
- Networking
- Print server - Ethernet, Fast Ethernet, Gigabit Ethernet
- System Requirements
- UNIX, Linux, Microsoft Windows XP or later, Apple MacOS X 10.5 or later
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- EPEAT Silver
- 1-year warranty
- 43 cm x 48.8 cm x 38.4 cm
- Printer Type
Printer
- Print Speed
- Connectivity Technology
- Wired
- Interface
- USB, Gigabit LAN
- 1200 dpi
- 1200 dpi
- PostScript Support
- Standard
- First Print Out Time B/W
- 9 sec
- First Print Out Time Colour
- 10 sec
- Colour Management Features
- PANTONE Digital Color
- Media Handling
- Processor
- 533 MHz
RAM
- 256 MB / 768 MB (max)
Media Handling
- Media Type
- Plain paper
- Media Size Class
- A4/Legal
- Max Media Size
- 76.2 mm x 127 mm
- 216 mm x 356 mm
- Media Sizes
- Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm)
- 700 sheets
- Media Feeders
- 1 x automatic - 150 sheets - Legal (216 x 356 mm) , 1 x automatic - 550 sheets - Legal (216 x 356 mm)
- Max Media Capacity
- 1250 sheets
- Output Trays Capacity
- 250 sheets
Duty Cycle
- 80000 pages
- Networking
- Print server
- Data Link Protocol
- TCP/IP
- Remote Management Protocol
- SNMP 3
- Apple Bonjour, IPsec, IP filtering
- IEEE 802.1x
- Connections
- 1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45
- Power Device
- Power supply - internal
- Frequency Required
- 50/60 Hz
- 535 Watt
- Power Consumption Stand by / Sleep
- 65 Watt
- Software Included
- Drivers & Utilities, Xerox Global Print Driver, Xerox Mobile Express Driver
- OS Required
- EPEAT Compliant
- EPEAT Silver
- ENERGY STAR
- Limited warranty - 1 year - on-site
- 10 °C
- 32 °C
- 10 - 85% (non-condensing)
- Sound Emission (Idle)
- 29 dBA
- Sound Emission (Operating)
- 53 dBA
- 43 cm
- 48.8 cm
- 38.4 cm
- 25.5 kg
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £3.52 |
