Xerox Phaser 3330 Mono Laser Wifi Printer
Quicklinx: CM61WS00 Mfr#: 3330V_DNI
Type: Printer
Functionality: Printer
Output Type: Monochrome
Wireless Capability: Wireless, Wired
Technology: Laser
£177.08 ex VAT
£212.49 inc VAT
The Phaser 3330 is designed to boost productivity with easy connectivity, day-in, day-out dependability and transformative features - ready to work.
  • Wireless wonders
    Internal Wi-Fi connectivity comes standard for untethered mobility and the freedom to put your printer or multifunction device right where you need it. The Wi-Fi installation wizard and Wi-Fi Print Setup (WPS) make getting connected secure and simple. And, with Wi-Fi Direct, mobile devices can connect directly and securely.
  • Ready to pair
    Now workers can easily print from mobile phone and tablets with Near Field Communication (NFC) tap-to-pair.
  • Multifunction productivity
    The space-saving MFP helps you conserve energy and reduce supplies costs by combining the functions of a copier, printer, color scanner and fax into one affordable device.
  • Outstanding performance
    With hefty processing power and standard memory, you'll see your first print faster and get high print speeds.
  • See the difference
    Your documents will show exceptional sharpness with up to 1200 x 1200 DPI image quality.
Xerox Phaser 3330V_DNI - printer - B/W - laser
Printer Type
Workgroup printer - laser - B/W
9.9 kg
Media Size Class
A4/Legal
Max Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm)
Min Media Size (Custom)
76 mm x 127 mm
Max Media Size (Custom)
216 mm x 356 mm
Print Speed
Up to 40 ppm - B/W - A4 (210 x 297 mm)
Max Resolution (B&W)
1200 dpi
Automatic Duplexing
USB 2.0, Gigabit LAN, Wi-Fi
AirPrint Enabled
1 GHz
RAM Installed (Max)
512 MB (512 MB)
Language Simulation
PCL 5E, PostScript 3, PCL 6, PDF, TIFF
Media Type
Plain paper
Total Media Capacity
300 sheets
Media Handling
250-sheet input tray, 50-sheet bypass tray
Monthly Duty Cycle (max)
80000 pages
Print server
UNIX, Linux, Microsoft Windows Vista or later, Apple MacOS X 10.8 or later
1-year warranty
36.6 cm x 36.8 cm x 25.7 cm
Printer Type
Workgroup printer - laser - monochrome
Printer
Print Speed
Wireless
AirPrint Enabled
1200 dpi
Automatic Duplexing
PostScript Support
Standard
First Print Out Time B/W
6.5 sec
Language Simulation
Media Handling
1 GHz
RAM
RAM Installed (Max)
512 MB / 512 MB (max)
Media Handling
Media Type
Plain paper
Media Size Class
A4/Legal
Max Media Size
76 mm x 127 mm
216 mm x 356 mm
Media Sizes
300 sheets
Media Feeders
1 x automatic - 50 sheets - Legal (216 x 356 mm) , 1 x automatic - 250 sheets - Legal (216 x 356 mm)
Output Trays Capacity
150 sheets
Duty Cycle
80000 pages
Print server
Remote Management Protocol
SNMP 3, HTTPS
Security Protocols & Features
SSL, Apple Bonjour, WEP, TLS, WPA, IPsec, WPA2-PSK, AES, IP filtering, Wi-Fi Direct, WPA2-Enterprise
1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45
GOST, GS, Directive 1999/5/EC, FCC Part 68, R&TTE, UL 60950-1, IPv6 Ready, CSA C22.2 No. 60950-1-07 Second Edition, EMC 2004/108/EC, LVD 2006/95/EC, FCC Part 15 Class B
Power supply - internal
700 Watt
Power Consumption Stand by
50 Watt
Power Consumption Sleep
3.5 Watt
Software Included
Xerox CentreWare Web, Xerox CentreWare Internet Services
Environmental Standards
ENERGY STAR
Limited warranty - 1 year - on-site
10 °C
32 °C
20 - 80% (non-condensing)
Sound Emission (Idle)
26 dBA
Sound Emission (Operating)
54 dBA
36.6 cm
36.8 cm
25.7 cm
9.9 kg
CM61 Xerox Standard Capacity Black Toner Cartridge (2600 Pages) In Stock £93.06
CM61 Xerox High Capacity Black Toner Cartridge (8500 Pages) In Stock £161.10
CM61 Xerox Extra High Capacity Black Toner Cartridge (15000 Pages) In Stock £205.30
Type: Printer
Wireless Capability: Wired
Technology: Laser
Max Paper Size: A4 (210 x 297 mm)
Brand: Xerox
