The Phaser 3330 is designed to boost productivity with easy connectivity, day-in, day-out dependability and transformative features - ready to work.
Wireless wonders
Internal Wi-Fi connectivity comes standard for untethered mobility and the freedom to put your printer or multifunction device right where you need it. The Wi-Fi installation wizard and Wi-Fi Print Setup (WPS) make getting connected secure and simple. And, with Wi-Fi Direct, mobile devices can connect directly and securely. -
Ready to pair
Now workers can easily print from mobile phone and tablets with Near Field Communication (NFC) tap-to-pair. -
Multifunction productivity
The space-saving MFP helps you conserve energy and reduce supplies costs by combining the functions of a copier, printer, color scanner and fax into one affordable device. -
Outstanding performance
With hefty processing power and standard memory, you'll see your first print faster and get high print speeds. -
See the difference
Your documents will show exceptional sharpness with up to 1200 x 1200 DPI image quality.
- Xerox Phaser 3330V_DNI - printer - B/W - laser
- Printer Type
- Workgroup printer - laser - B/W
- 9.9 kg
- Media Size Class
- A4/Legal
- Max Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm)
- Min Media Size (Custom)
- 76 mm x 127 mm
- Max Media Size (Custom)
- 216 mm x 356 mm
- Print Speed
- Up to 40 ppm - B/W - A4 (210 x 297 mm)
- Max Resolution (B&W)
- 1200 dpi
- Automatic Duplexing
- Interface
- USB 2.0, Gigabit LAN, Wi-Fi
- AirPrint Enabled
- Processor
- 1 GHz
- RAM Installed (Max)
- 512 MB (512 MB)
- Language Simulation
- PCL 5E, PostScript 3, PCL 6, PDF, TIFF
- Media Type
- Plain paper
- Total Media Capacity
- 300 sheets
- Media Handling
- 250-sheet input tray, 50-sheet bypass tray
- Monthly Duty Cycle (max)
- 80000 pages
- Networking
- Print server
- System Requirements
- UNIX, Linux, Microsoft Windows Vista or later, Apple MacOS X 10.8 or later
- 1-year warranty
- 36.6 cm x 36.8 cm x 25.7 cm
- Printer Type
- Workgroup printer - laser - monochrome
Printer
- Print Speed
- Connectivity Technology
- Wireless
- Interface
- AirPrint Enabled
- 1200 dpi
- PostScript Support
- Standard
- First Print Out Time B/W
- 6.5 sec
- Media Handling
- Processor
- 1 GHz
RAM
- 512 MB / 512 MB (max)
Media Handling
- Media Type
- Plain paper
- Media Size Class
- A4/Legal
- Max Media Size
- 76 mm x 127 mm
- 216 mm x 356 mm
- Media Sizes
- 300 sheets
- Media Feeders
- 1 x automatic - 50 sheets - Legal (216 x 356 mm) , 1 x automatic - 250 sheets - Legal (216 x 356 mm)
- Output Trays Capacity
- 150 sheets
Duty Cycle
- 80000 pages
- Networking
- Print server
- Remote Management Protocol
- SNMP 3, HTTPS
- SSL, Apple Bonjour, WEP, TLS, WPA, IPsec, WPA2-PSK, AES, IP filtering, Wi-Fi Direct, WPA2-Enterprise
- Connections
- 1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45
- GOST, GS, Directive 1999/5/EC, FCC Part 68, R&TTE, UL 60950-1, IPv6 Ready, CSA C22.2 No. 60950-1-07 Second Edition, EMC 2004/108/EC, LVD 2006/95/EC, FCC Part 15 Class B
- Power Device
- Power supply - internal
- 700 watt
- Power Consumption Stand by
- 50 watt
- Power Consumption Sleep
- 3.5 watt
- Software Included
- Xerox CentreWare Web, Xerox CentreWare Internet Services
- OS Required
Environmental Standards
- ENERGY STAR
- Limited warranty - 1 year - on-site
- 10 °C
- 32 °C
- 20 - 80% (non-condensing)
- Sound Emission (Idle)
- 26 dBA
- Sound Emission (Operating)
- 54 dBA
- 36.6 cm
- 36.8 cm
- 25.7 cm
- 9.9 kg
Xerox Standard Capacity Black Toner Cartridge (2600 Pages) | In Stock | £117.32 |
Xerox High Capacity Black Toner Cartridge (8500 Pages) | In Stock | £216.79 |
Xerox Extra High Capacity Black Toner Cartridge (15000 Pages) | In Stock | £269.17 |
