Xerox Phaser 3320V_DNI Mono Laser Multifunction Printer
Quicklinx: 8QNYWS00 Mfr#: 3320V_DNI
The convenient, value-packed Phaser 3320 printer delivers reliable, economical performance where you need it, helping you stay focused on what matters most: growing your business.
  • Standard duplexing
    Highly efficient, no-hassle two-sided printing can cut your paper consumption and cost in half.
  • Outstanding performance
    A fast print speed of up to 37 ppm and a first-page-out time as fast as 6.5 seconds mean your documents are always ready when you need them.
  • Go wireless
    The Phaser 3320 comes standard with internal Wi-Fi connectivity, giving you the freedom to choose the device that's right for you, and put it right where you need it.
  • Stay secure
    Keep your sensitive documents away from unintended recipients with the security features, including IPsec, SNMPv3, IP filtering and secure print.
  • Productivity where you need it
    It features a small footprint, which allows for easy integration within your work space, whether on your desk or in a shared location.
  • Economical efficiency
    Available high-capacity print cartridges reduce your total cost of ownership and demand less frequent replacement.
  • Easy management
    With Xerox CenterWare IS, remote device administration is handled with ease right from your computer's browser.
Xerox Phaser 3320V_DNI - printer - B/W - laser
Printer Type
Workgroup printer - laser - B/W
9.9 kg
Media Size Class
A4/Legal
Max Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm)
Min Media Size (Custom)
76 mm x 127 mm
Max Media Size (Custom)
216 mm x 356 mm
Print Speed
Up to 35 ppm - B/W - A4 (210 x 297 mm)
Max Resolution (B&W)
1200 dpi
Automatic Duplexing
USB, Gigabit LAN, Wi-Fi
600 MHz
RAM Installed (Max)
128 MB (384 MB)
Language Simulation
PCL 5E, PostScript 3, PCL 6, PDF
Media Type
Plain paper
Total Media Capacity
300 sheets
Media Handling
250-sheet input tray, 50-sheet multipurpose tray
Monthly Duty Cycle (max)
80000 pages
Print server - Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11 - internal
Printer Features
Fit-to-page
HP-UX, SuSe Linux, Microsoft Windows XP, SunSoft Solaris 9, Microsoft Windows Server 2003, Microsoft Windows 7, Red Hat Enterprise Linux 4, Red Hat Fedora Core, Microsoft Windows Vista, Apple MacOS X 10.5 or later, Microsoft Windows Server 2008, Oracle Solaris 10, IBM AIX 5
36.6 cm x 36.8 cm x 25.7 cm
Printer Type
Workgroup printer - laser - monochrome
Printer
Print Speed
Wireless
1200 dpi
Automatic Duplexing
PostScript Support
Standard
First Print Out Time B/W
6.5 sec
Language Simulation
Printer Features
Fit-to-page
Media Handling
600 MHz
RAM
RAM Installed (Max)
128 MB / 384 MB (max)
Media Handling
Media Type
Plain paper
Media Size Class
A4/Legal
Max Media Size
76 mm x 127 mm
216 mm x 356 mm
Media Sizes
Media Weight
60 g/m² - 163 g/m²
300 sheets
Media Feeders
1 x automatic - 50 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 163 g/m² , 1 x automatic - 250 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 105 g/m²
Output Trays Capacity
150 sheets
Duty Cycle
80000 pages
Print server - internal
Network / Transport Protocol
Bonjour
Remote Management Protocol
SNMP 3, HTTPS
Security Protocols & Features
LDAP, SSL, IPsec, 802.1x, IP filtering, MAC address filtering
Expansion Slots
1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45
Consumables Included
1 x toner cartridge (black)
GOST, GS, NOM, FCC Part 68, EMC, UL 60950-1, CSA C22.2 No. 60950-1-07
Power supply - internal
420 Watt
Power Consumption Stand by / Sleep
48 Watt
Software Included
Drivers & Utilities
Environmental Standards
Blue Angel
ENERGY STAR
10 °C
32 °C
20 - 80% (non-condensing)
Sound Emission (Idle)
26 dBA
Sound Emission (Operating)
52 dBA
36.6 cm
36.8 cm
25.7 cm
9.9 kg
8QNY C2G 2m USB 2.0 A/B Cable - Black In Stock £4.17
Resources
The following resources are available for the Xerox Phaser 3320V_DNI Mono Laser Multifunction Printer
