Xerox Phaser 3250V Mono Laser Printer
Quicklinx: 9ZC0WS00 Mfr#: 3250V_DN
Whether supporting one user or a small work team, the Phaser 3250DN laser printer offers the ultimate combination of fast printing, office-friendly convenience and unbeatable overall value in a compact, space-saving design.
The Phaser 3250DN configuration includes CenterWare IS, an embedded web server that allows users and IT personnel to perform detailed status checks on the system and consumables, administer system settings, and manage access and accounting controls via any standard web browser. The Phaser 3250DN laser printer supports many common network protocols including TCP / IP, HTTP 1.1, SNMP 1-2 and EtherTalk.
  • Phaser 3250
    This powerful little printer is ready to support a single user or a small workgroup with fast, automatic two-sided printing, office-friendly convenience and outstanding overall value.
  • Quick Facts
    •Two-sided printing standard on all configurations • First-page-out time of as fast as 8.5 seconds • Maximum paper size: A4 • Standard paper capacity: 250 sheet tray plus one-sheet multipurpose tray • Maximum paper capacity: 501 sheets • Up to 1200 image quality • 400 MHz processor • 32 MB memory standard, 160 MB maximum • Windows (including Vista), Mac, and Linux compatible • One-year On-site warranty • Maximum duty cycle of 30,000 pages per month • Minimum dimensions (w x d x h): 364 x 370 x 239 mm • What comes in the box: •Print cartridge (capacity: 2,000 pages1) • Power cord • USB cable • Software and documentation • NOTE: Some contents may be shipped separately
  • Value Features
    •Get your work done fast with print speeds up to 28 ppm and as fast as 8.5 seconds to first page • Automatic two-sided printing is standard on all configurations, saving you time and paper • Network connectivity on Phaser 3250/DN helps more users get more work done • Toner save mode extends the life of your cartridge and reduces your cost per page without a significant reduction in print quality • Power save mode helps you spend less on electricity • N-up feature prints multiple pages on a single sheet, saving paper, ink, and money
  • Convenience Features
    •Small footprint can fit almost anywhere you need it • Up to 160 MB of memory enhances your performance, especially when printing large files • Optional 250-sheet tray increases your paper capacity to 500 sheets and allows the Phaser 3250 to print with fewer interruptions • Media flexibility lets you print on custom paper sizes, media types and weights to help you meet your diverse printing needs • PC, Mac, and Linux drivers let you easily print in mixed environments • Booklet printing feature automatically arranges your documents into booklet format
  • Quality Features
    •1200 image quality resolution delivers exceptional print quality without slowing down the powerful performance of the Phaser 3250 • Powerful 400 MHz processor prints even complex graphics quickly and accurately • Adobe PostScript 3 compatibility (on Phaser 3250VDN model only) and PCL 6 emulation ensure your print jobs are always accurate • High duty cycle of 30,000 pages per month ensures you can regularly handle big print volumes with ease • One-year on-site warranty gets you back to work fast if problems arise 1 Average standard pages. Declared Yield in accordance with ISO/IEC 19752. Yield will vary based on image, area coverage and print mode.
Xerox Phaser 3250DN - printer - B/W - laser
Printer Type
Workgroup printer - laser - B/W
11.9 kg
Media Size Class
A4/Legal
Max Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm)
Min Media Size (Custom)
76 mm x 127 mm
Max Media Size (Custom)
216 mm x 356 mm
Print Speed
Up to 30 ppm - max speed - ANSI A (Letter) (216 x 279 mm) , Up to 28 ppm - max speed - A4 (210 x 297 mm) , Up to 14.5 ppm - B/W duplex - ANSI A (Letter) (216 x 279 mm) , Up to 14 ppm - B/W duplex - A4 (210 x 297 mm)
Max Resolution (B&W)
1200 dpi
Image Enhancement Technology
1200 IQ
Automatic Duplexing
USB, LAN
400 MHz
RAM Installed (Max)
32 MB (160 MB)
Language Simulation
PCL 5E, PostScript 3, PCL 6, IBM ProPrinter, Windows GDI driver, EPSON
Media Type
Envelopes, transparencies, labels, plain paper, cards, bond paper, recycled paper
Total Media Capacity
250 sheets
Media Handling
250-sheet input tray, 1-sheet multipurpose tray
Monthly Duty Cycle (max)
30000 pages
Print server - Ethernet, Fast Ethernet, EtherTalk - internal
Microsoft Windows 2000, Microsoft Windows XP, Microsoft Windows XP 64-bit Edition, Microsoft Windows Server 2003, Microsoft Windows Vista, Microsoft Windows Server 2003 x64 Edition, Microsoft Windows Vista (64-bit versions), Apple MacOS X 10.3 - 10.5, Mandrake Linux 9.2 - 10.1, Red Hat Fedora Core 1 - 4, Red Hat Linux 8 - 9, SuSE Linux 8.2 - 9.2
Microsoft Certification
Works with Windows Vista
1-year warranty
36.4 cm x 36.9 cm x 23.9 cm
Printer Type
Workgroup printer - laser - monochrome
Printer
Print Speed
Wired
USB, LAN
1200 dpi
1200 IQ
Automatic Duplexing
PostScript Support
Standard
First Print Out Time B/W
8.5 sec
Language Simulation
Fonts Included
1 x bitmapped , 45 x scalable , 136 x PostScript
Media Handling
400 MHz
RAM
RAM Installed (Max)
32 MB / 160 MB (max)
Slots Qty
1
Empty Slots
1
Media Handling
Media Type
Media Size Class
A4/Legal
Max Media Size
76 mm x 127 mm
216 mm x 356 mm
Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), Folio (216 x 330 mm), JIS B5 (182 x 257 mm), 76 x 127 mm, Oficio (216 x 343 mm)
Media Weight
60 g/m² - 163 g/m²
250 sheets
Media Feeders
1 x manual - 1 sheet - Legal (216 x 356 mm) weight: 60 g/m² - 163 g/m² , 1 x automatic - 250 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 105 g/m² , 1 x automatic (optional) - 250 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 105 g/m²
Max Media Capacity
500 sheets
Output Trays Capacity
150 sheets
Duty Cycle
30000 pages
Print server - internal
Network / Transport Protocol
TCP/IP, BOOTP, DHCP
Remote Management Protocol
SNMP 1, SNMP 2, HTTP
1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45
1 x USB cable
Consumables Included
1 x toner cartridge (black) - up to 2000 pages
Software and devices that carry the Works with Windows Vista logo have been tested for baseline compatibility with PC's running.
EMC, UL 60950-1, CSA C22.2 No. 60950-1-03
Power supply - internal
Frequency Required
50/60 Hz
400 Watt
Power Consumption Stand by / Sleep
70 Watt
Software Included
Driver, Xerox CentreWare IS Embedded Web Server, Xerox Installer, Xerox Printer Setting Utility
Environmental Standards
ENERGY STAR
Limited warranty - replacement - 1 year - shipment - response time: next day
10 °C
32 °C
20 - 80%
Sound Emission (Idle)
29 dB
Sound Emission (Operating)
54 dB
36.4 cm
36.9 cm
23.9 cm
11.9 kg
