Xerox NetScan 3000 Network Adaptor UK
Quicklinx: C6TLWS00 Mfr#: 100N02966
Wired / Wireless: Wired
Protocol: Fast Ethernet, Ethernet, Gigabit Ethernet
Interface: USB 2.0
Compatibility: Mac, PC
£116.74 ex VAT
£140.08 inc VAT
The NetScan 3000 brings flexibility and productivity of document scanners to a whole new level in any environment including home, SOHO, school or business setting. The Visioneer NetScan 3000 is a scanner server designed to connect a certified Visioneer or Xerox DocuMate scanner directly to a network allowing it to be a shared resource. It is a 10/100/1000Base Ethernet port that can be connected to a wireless router for wireless USB device networking with two Hi-Speed USB 2.0 ports supporting up to one amp of USB bus power combined. Up to 15 scanners can be integrated with the Gigabit network and can be used as if they were attached locally.
When combined with a scanner utilizing Visioneer OneTouch technology, the NetScan 3000 creates an elegant solution that allows users to save time and resources by only having to make one trip to the scanner. Users simply open the NetScan 3000 utility on their desktop, walk up to the scanner, place their documents in the ADF, and press the OneTouch scan button. Their document will immediately be scanned and automatically sent to the specified location in one easy step.
The NetScan 3000 includes a utility that allows users to visually manage all of their networked scanners in one window and displays the availability of connected scanners on the network in real time.
  • Versatile compatibility
    Designed to seamlessly integrate with both Mac and PC environments, ensuring a broad compatibility range for diverse office setups.
  • High-speed connectivity
    Features a 1000Base-T RJ-45 connector, providing high-speed Ethernet connectivity that supports Ethernet, Fast Ethernet, and Gigabit Ethernet, making it ideal for fast-paced business environments.
  • Efficient power usage
    With an operational power consumption of just 5 W, it offers an energy-efficient solution for your networking needs, reducing overhead costs.
Visioneer NetScan 3000 - scanner server - USB 2.0 - Gigabit Ethernet
Scanner server
External
Interface (Bus) Type
USB 2.0
Ports
Gigabit Ethernet
6 cm x 10 cm x 2.8 cm
100 g
Cabling Type
Ethernet 10Base-T, Ethernet 100Base-TX, Ethernet 1000Base-T
10Mb LAN, 100Mb LAN, 1GbE
Network / Transport Protocol
TCP/IP
Microsoft Windows 2000, Microsoft Windows Server 2003, Microsoft Windows 7, Microsoft Windows Vista, Microsoft Windows Server 2008, Microsoft Windows XP (32/64 bits), Windows 8, Apple MacOS X 10.2.7 - 10.5.x, Apple MacOS X 10.4.3 - 10.6.x
WorkCentre 5325/C, 5325/CH, 5325/PH, 5325/PHXF, 5330/C, 5330/P, 5330/PH, 5330/PHXF, 5335/C, 5335/P, 5335/PH, 5865IV_F, 7220/PXF2I
Scanner server
External
USB 2.0
Ports
Gigabit Ethernet
Wired
Cabling Type
TCP/IP
1 x 1000Base-T - RJ-45
FCC, VCCI Class B
External
5 Watt
6 cm
10 cm
2.8 cm
100 g
Shipping Width
13.3 cm
Shipping Depth
15.2 cm
Shipping Height
5 cm
Shipping Weight
0.3 kg
Xerox WorkCentre 5325/C, 5325/CH, 5325/PH, 5325/PHXF, 5330/C, 5330/P, 5330/PH, 5330/PHXF, 5335/C, 5335/P, 5335/PH, 5865IV_F, 7220/PXF2I
Protocol: Ethernet
Protocol: Gigabit Ethernet
Interface: USB 2.0
Compatibility: Mac
Compatibility: PC
Brand: Xerox
