The VisionAid kit is necessary in order to clean, maintain, and extend the operational life of your scanner. Cleaning and maintenance is recommended to be performed approximately every 1000 scans.
- 1 Bottle of Streak-Free De-Ionized Ceaning Solution
- 10 Lint-Free Dry Cleaning Cloths (white)
- 5 Dry Cleaning Cloths (blue)
- 3 Scan Through Staticide Wipes
- 10 Isopropyl Alcohol Pre-Moistened Cleaning Wipes
- 4 ADF Pad Assemblies
- 1 Roller Assembly
- Cleaning Instructions
Effortless maintenance
This scanner maintenance kit is designed to ensure your scanner operates efficiently, providing a straightforward solution to maintain optimal performance. -
PC compatibility
Designed to seamlessly integrate with PC systems, this maintenance kit ensures compatibility and enhances the functionality of your scanner.
