                Comprehensive maintenanceThis scanner maintenance kit comes equipped with everything needed to keep your scanner in efficient condition, including a friction roller assembly, de-ionized cleaning solution, lint-free dry cleaning cloths, isopropyl alcohol pre-moistened cleaning wipes, heavy-duty cleaning cloths, and detailed cleaning instructions
                Easy compatibilityDesigned specifically for PC compatibility, this kit ensures a seamless fit and function with your computer scanner, enhancing its performance and longevity
- Xerox scanner maintenance kit
- Product Type
- Scanner maintenance kit
- Package Content
- 10 Lint-Free Dry Cleaning Cloths (white), 1 bottle of streak-free-de-Ionised cleaning solution, 10 isopropyl alcohol pre-moistened cleaning wipes, 5 Heavy-Duty Cleaning Cloths (blue), 1 ADF Friction Roller Assembly, Cleaning Instructions
- Designed For
- DocuMate 4760, 4760 VRS Pro
- Product Type
- Package Content
- Designed For
- Xerox DocuMate 4760, 4760 VRS Pro
