Xerox Duplex Mobile Scanner
Quicklinx: C44KWS00 Mfr#: 100N03205
Type: Sheetfed scanner
Form Factor: Portable
Max Paper Size: 216 x 813 mm
Interface: USB 2.0
Compatibility: PC, Mac
£104.33 ex VAT
£125.19 inc VAT
The Xerox Duplex Travel Scanner scans without the need of AC power because it is powered through the USB port. Now you can quickly scan, file and store all of your documents, plastic ID cards, photos, articles and brochures no matter where you are. Weighing a little more than a small bottle of water, the Xerox Duplex Travel Scanner includes robust PC and Mac TWAIN drivers, and scans cards as small as 1.5" (38 mm) and documents up to 8.5" (216 mm) wide and 32" (813 mm) long.
Main Features
  • Instantly scan duplex documents to searchable PDF for easy search and retrieval.
  • Improve quality and help organize the scans.
  • USB powered - no external power supply needed.
  • Continuous feed to create multipage PDFs.
  • Advanced features.
Visioneer OneTouch
OneTouch is an easy-to-use utility that connects the Xerox Duplex Travel Scanner with a powerful set of scanner settings to greatly improve the efficiency of your workflow - so that with one touch the document is scanned automatically to email, Microsoft Word, your printer, a file folder, or to one of many cloud destinations.
Visioneer DriverPLUS
DriverPLUS is a new generation of driver technology that is based on the TWAIN 2.3 specifications that provides advanced features and greater reliability for both users and system integrators. DriverPLUS combines the features of advanced 32- and 64-bit native Windows-based TWAIN and WIA drivers plus Acuity optimization software and a sophisticated, but easy to use, user interface.
Visioneer Acuity
Acuity, in combination with DriverPlus technology, enables your scanner to instantly improve the visual clarity of every document that you scan. Using advanced algorithms and technology, Acuity will intelligently correct documents containing imperfections, improve quality of scanned images for archiving, increase OCR accuracy, and save time.
Nuance PaperPort
Millions of professionals rely on PaperPort to save time and money by transforming paper documents into searchable digital documents. PaperPort combines the efficiency of document management, the convenience of superbly scanned documents and the power of creating PDF files, to bring a new level of operational proficiency to your organization.
Nuance PDF Converter
Nuance PDF Converter is the smarter PDF software choice for businesses. Combining powerful functionality, superior Microsoft Office support, built-in intelligence, DMS integration, and intuitive ease of use, Nuance PDF Converter provides everything you need to create, convert, edit, assemble, and securely share PDF files.
Mac TWAIN
The Mac TWAIN driver offers all of the features of Acuity Image cleanup built in. No 3rd party software needed. Blank Page Removal, Auto Color Detect, Auto Rotate are just a few of the standard features.
Visioneer Scan Utility
If there is no scanning application on your Mac, a simple but effective scan utility is included, allowing you to take full advantage of all of the drivers' features. Simply put, set your driver preferences, select an image format (BMP, JPG, Gif, PDF, MPDF, TIF and MTIF), choose where you want to save your images to, and start scanning.
  • Visioneer OneTouch
  • Visioneer DriverPLUS
  • Visioneer Acuity
  • Nuance PaperPort
  • Nuance OmniPage Pro
    OmniPage Pro provides a precise OCR and layout retention solution, quickly turning scanned documents into editable, formatted text. The text can then be used in virtually any word processing, desktop publishing or web publishing program.
  • Nuance PDF Converter
  • Mac TWAIN
  • Visioneer Scan Utility
Xerox Duplex Travel Scanner - sheetfed scanner - portable - USB 2.0
Sheetfed scanner - portable
Interface Type
USB 2.0
Scanning Sensor Type
Contact Image Sensor (CIS)
Light Source
LED
Max Supported Document Size
216 x 813 mm
Input Type
Grayscale / Color Depth (External)
8-bit (256 grey levels) / 24-bit (16.7 million colours)
Optical Resolution
600 dpi
Max Document Size
216 mm x 813 mm
Automatic Duplexing
Supported Document Type
Plain paper, plastic card, photo
Duty Cycle
100 scans per day
Microsoft Windows Vista / XP / 7, Apple MacOS X 10.6 or later, Windows 8 / 10
29.1 cm x 6.7 cm x 4 cm
500 g
Environmental Standards
ENERGY STAR Qualified
Interface Type
USB 2.0
216 x 813 mm
Scanner
Input Type
Grayscale Depth (External)
Colour Depth (External)
Optical Resolution
600 dpi
Automatic Duplexing
Bulb / Light Source Type
LED
Duty Cycle
100 scans per day
Scanner Speed Details
9 sec/scan - colour - A4 - 200 dpi , 9 sec/scan - black & white - A4 - 200 dpi
Scanner Features
Powered by USB port, Blank Page Removal, automatic colour detection, Auto Document Rotation, Visioneer Acuity Technology
TWAIN, WIA, ICA
Media Handling
Max Document Size
216 mm x 813 mm
Interfaces Details
USB 2.0 - Type B
Carrying case, calibration card, cleaning cloth, carrier sheet
1 x USB cable
ENERGY STAR Certified
Software Included
Drivers & Utilities, Nuance OmniPage Professional, Nuance PaperPort, Visioneer OneTouch, Visioneer Acuity, Visioneer DriverPLUS, Nuance Power PDF, Visioneer Scan Utility for Mac
System Requirements Details
Windows XP/Vista/7/8/10 - Pentium 4 RAM 2 GB - HD 350 MB , MacOS X 10.6 or later - Intel Core - 1.83 GHz - RAM 2 GB - HD 350 MB
29.1 cm
6.7 cm
4 cm
500 g
Interface: USB 2.0
Compatibility: PC
Compatibility: Mac
Brand: Xerox
