Xerox DocuMate 765/4790/4799 Imprinter Kit
Quicklinx: C6XZWS00 Mfr#: 003R98811
£1,081.48 ex VAT
£1,297.77 inc VAT
By installing the optional imprinter kit into the scanner, the user has the ability to print specific characters on to the document before or after scanning, depending on the scanner model. By printing serial numbers, the scanned data can be tracked, matched and/or indexed with the original document. The printed characters are read as front side image and function as pre-imprinter (front face of document only) for the DocuMate 765 and 4790, and pre- and/or post-imprinter (front/back side of document) for the DocuMate 4799.
Xerox Scanner Upgrade Kit - scanner imprinter
Scanner imprinter
DocuMate 765
Scanner imprinter
8.1 cm x 12.4 cm x 5.1 cm / 0.7 kg
Xerox DocuMate 765
Type: Scanner imprinter
Brand: Xerox
Price Range Ex VAT: £1000 - £1500
