Information is the lifeblood of every business. In today's digital world, it's important to be able to manage paper documents and unlock business-critical data stored in documents. The Xerox DocuMate 6440 is a fast and user-friendly scanner. With its advanced paper handling technology, integrated image enhancing software and a small footprint, the DocuMate 6440 is packed with features that will change how you look at and manage paper documents and information.
Effective paper management
Information is the lifeblood of every business. In today's digital world, it's important to be able to manage paper documents and unlock business-critical data stored in documents. The Xerox DocuMate 6440 is a fast and user-friendly scanner. With its advanced paper handling technology, integrated image enhancing software and a small footprint, the DocuMate 6440 is packed with features that will change how you look at and manage paper documents and information. -
No industry left behind
Its versatility, combined with advanced features makes the DocuMate 6440 an attractive solution for banking, education, energy, financial, government, healthcare and manufacturing industries. Plastic ID and insurance cards, as well as paper documents, can be scanned through the automatic document feeder (ADF). -
Automated workflow with one easy touch
The DocuMate 6440 is powered by Visioneer OneTouch technology to scan documents instantly to one of nine preset, yet completely configurable destinations. Visioneer OneTouch takes control of your document management workflows and scans in data using the optimal settings for resolution, color, duplex, auto-crop, auto-straighten and file format, and then delivers it to virtually any application, folder or device at the touch of a button.
 - Xerox DocuMate 6440 - document scanner - desktop - USB 2.0
 - Document scanner - desktop
- Interface Type
 - USB 2.0
- Scanning Sensor Type
 - CCD
- Light Source
 - LED
- Max Supported Document Size
 - 241 x 2997 mm
- Input Type
- Grayscale / Color Depth (External)
 - 8-bit (256 grey levels) / 24-bit (16.7 million colours)
- Optical Resolution
 - 600 dpi
- Interpolated Resolution
 - 1200 dpi
- Max Document Scan Speed
 - 60 ppm (mono) / 60 ppm (colour)
- Max Document Size
 - 241 mm x 2997 mm
- Automatic Duplexing
- Supported Document Type
 - Plain paper, plastic card, photo
- Document Feeder Type
 - Automatic
- Document Storage Capacity
 - 80 sheets
- Duty Cycle
 - 6000 scans per day
- System Requirements
 - Microsoft Windows XP, Microsoft Windows 7, Microsoft Windows Vista, Windows 8, Windows 10
 - 31.6 cm x 16.8 cm x 19.1 cm
 - 4.2 kg
- Environmental Standards
 - ENERGY STAR Qualified
- Interface Type
 - USB 2.0
 - 241 x 2997 mm
Scanner
- Input Type
- Grayscale Depth (External)
- Colour Depth (External)
 - 24-bit (16.7 million colours)
 - 600 dpi
 - 1200 dpi
 - CCD
- Bulb / Light Source Type
 - LED
- Max Document Scan Speed B/W
 - 60 ppm
- Max Document Scan Speed Colour
 - 60 ppm
- Duty Cycle
- Scanner Speed Details
 - 60 ppm - black & white - 200 dpi , 60 ppm - colour - 200 dpi , 40 ppm - black & white - 300 dpi , 40 ppm - colour - 300 dpi
- Scan File Formats
 - TWAIN, ISIS, WIA
Media Handling
- Max Document Size
 - 241 mm x 2997 mm
- Supported Document Size Details
 - ADF - up to 241 x 2997 mm
 - Automatic
 - 80 sheets
- Interfaces Details
 - USB 2.0
- Cables Included
 - 1 x USB cable
- ENERGY STAR Certified
- Software Included
 - Drivers & Utilities, Nuance PaperPort, Visioneer OneTouch, Visioneer Acuity, Nuance Power PDF, Nuance OmniPage Ultimate
- OS Required
- System Requirements Details
 - Windows XP/Vista/7/8/10 - Pentium 4 RAM 2 GB - HD 350 MB (USB)
 - 31.6 cm
 - 16.8 cm
 - 19.1 cm
 - 4.2 kg
