The Xerox DocuMate 4830 is an effective way to index stacks of large-sized documents and import them to a content management solution in a single step. The DocuMate 4830 is an affordable, entry-level A3 scanner that offers outstanding performance and exceptional reliability for corporate workgroups/departments and small or medium-sized businesses.
The DocuMate 4830 has a friendly interface that allows the user to simply insert their document and press one of the buttons on the front panel of the scanner to initiate scanning and automatically email, print, convert or share the file. The buttons are preset at the optimal resolution, color depth, file format and paper size for common scanning tasks, but of course can be easily changed at any time. Ultrasonic Double Feed Detectionis built into the DocuMate 4830 so you'll never miss a page due to a misfeed or a stapled document going through the scanner.
Ideal for document management, the DocuMate 4830 includes software tools to edit, crop and retouch scanned images and organize the files into folders. With the touch of a button, users are able to scan and automatically upload their documents to popular cloud destinations such as Google Docs, Evernote, Dropbox.net and others.
- Xerox DocuMate 4830 - document scanner - desktop - USB 2.0
- Document scanner - desktop
- Interface Type
- USB 2.0
- Scanning Sensor Type
- Contact Image Sensor (CIS)
- Max Supported Document Size
- 297 x 2997 mm
- Input Type
- Grayscale / Color Depth (External)
- 8-bit (256 grey levels) / 24-bit (16.7 million colours)
- Optical Resolution
- 600 dpi
- Max Document Scan Speed
- 50 ppm (mono) / 30 ppm (colour)
- Max Document Size
- 297 mm x 2997 mm
- Automatic Duplexing
- Supported Document Type
- Plain paper
- Document Feeder Type
- Automatic
- Document Storage Capacity
- 75 sheets
- Duty Cycle
- 3000 scans per day
- System Requirements
- Microsoft Windows Vista / XP / 7
- 58.1 cm x 49.9 cm x 19.4 cm
- 12 kg
- Environmental Standards
- ENERGY STAR Qualified
- 1-year warranty
- Interface Type
- USB 2.0
- 297 x 2997 mm
Scanner
- Input Type
- Grayscale Depth (External)
- Colour Depth (External)
- 24-bit (16.7 million colours)
- 600 dpi
- Scan Mode
- Single/duplex pass
- Max Document Scan Speed B/W
- 50 ppm
- Max Document Scan Speed Colour
- 30 ppm
- Duty Cycle
- Scanner Speed Details
- 30 ppm - colour - 300 dpi , 60 ipm - duplex - colour - 300 dpi , 50 ppm - black & white - 300 dpi , 100 ipm - duplex - black & white - 300 dpi
- Scanner Features
- Visioneer OneTouch Technology, Visioneer Acuity Technology
- TWAIN, ISIS, WIA
Media Handling
- Max Document Size
- 297 mm x 2997 mm
- Plain paper
- Supported Document Size Details
- ADF - up to 297 x 2997 mm , Flatbed - up to A3 (297 x 420 mm)
- Automatic
- 75 sheets
- Interfaces Details
- USB 2.0 - Type B
- Cables Included
- 1 x USB cable
- ENERGY STAR Certified
- Power Device
- External power adapter
- Software Included
- Nuance OmniPage Professional, Visioneer OneTouch, Visioneer Acuity, Visioneer DriverPLUS, Nuance PDF Converter Professional
- OS Required
- System Requirements Details
- Windows XP/Vista/7 - Pentium 4 RAM 2 GB - HD 350 MB (USB 2.0)
- 58.1 cm
- 49.9 cm
- 19.4 cm
- 12 kg
- Limited warranty - 1 year
