Xerox Documate 4830i Departmental Scanner
Quicklinx: C6XMWS00 Mfr#: 100N02943
The Xerox DocuMate 4830 is an effective way to index stacks of large-sized documents and import them to a content management solution in a single step. The DocuMate 4830 is an affordable, entry-level A3 scanner that offers outstanding performance and exceptional reliability for corporate workgroups/departments and small or medium-sized businesses.
The DocuMate 4830 has a friendly interface that allows the user to simply insert their document and press one of the buttons on the front panel of the scanner to initiate scanning and automatically email, print, convert or share the file. The buttons are preset at the optimal resolution, color depth, file format and paper size for common scanning tasks, but of course can be easily changed at any time. Ultrasonic Double Feed Detectionis built into the DocuMate 4830 so you'll never miss a page due to a misfeed or a stapled document going through the scanner.
Ideal for document management, the DocuMate 4830 includes software tools to edit, crop and retouch scanned images and organize the files into folders. With the touch of a button, users are able to scan and automatically upload their documents to popular cloud destinations such as Google Docs, Evernote, Dropbox.net and others.
  • Efficient duplex scanning
    The DocuMate 4830 offers automatic duplexing, allowing for fast and easy two-sided scanning, which enhances productivity and saves time.
  • High-capacity document feeding
    With a feeder capacity of 75 sheets, this scanner is designed for high-volume tasks, enabling continuous scanning without frequent interruptions.
  • Exceptional color accuracy
    Experience vivid image reproduction with 24-bit color depth, capturing 16.7 million colors, and an 8-bit grayscale depth for detailed grayscale images.
  • Versatile document handling
    Supports a wide range of document sizes up to 297 mm by 2997 mm through the ADF, accommodating various paper types and sizes for flexible scanning solutions.
Xerox DocuMate 4830 - document scanner - desktop - USB 2.0
Document scanner - desktop
Interface Type
USB 2.0
Scanning Sensor Type
Contact Image Sensor (CIS)
Max Supported Document Size
297 x 2997 mm
Input Type
Grayscale / Color Depth (External)
8-bit (256 grey levels) / 24-bit (16.7 million colours)
Optical Resolution
600 dpi
Max Document Scan Speed
50 ppm (mono) / 30 ppm (colour)
Max Document Size
297 mm x 2997 mm
Automatic Duplexing
Supported Document Type
Plain paper
Document Feeder Type
Automatic
Document Storage Capacity
75 sheets
Duty Cycle
3000 scans per day
Microsoft Windows Vista / XP / 7
58.1 cm x 49.9 cm x 19.4 cm
12 kg
Environmental Standards
ENERGY STAR Qualified
1-year warranty
Interface Type
USB 2.0
297 x 2997 mm
Scanner
Input Type
Grayscale Depth (External)
Colour Depth (External)
Optical Resolution
600 dpi
Scan Mode
Single/duplex pass
Automatic Duplexing
Max Document Scan Speed B/W
50 ppm
Max Document Scan Speed Colour
30 ppm
Duty Cycle
3000 scans per day
Scanner Speed Details
30 ppm - colour - 300 dpi , 60 ipm - duplex - colour - 300 dpi , 50 ppm - black & white - 300 dpi , 100 ipm - duplex - black & white - 300 dpi
Scanner Features
Visioneer OneTouch Technology, Visioneer Acuity Technology
TWAIN, ISIS, WIA
Media Handling
Max Document Size
297 mm x 2997 mm
Plain paper
Supported Document Size Details
ADF - up to 297 x 2997 mm , Flatbed - up to A3 (297 x 420 mm)
Automatic
75 sheets
Interfaces Details
USB 2.0 - Type B
1 x USB cable
ENERGY STAR Certified
External power adapter
Software Included
Nuance OmniPage Professional, Visioneer OneTouch, Visioneer Acuity, Visioneer DriverPLUS, Nuance PDF Converter Professional
System Requirements Details
Windows XP/Vista/7 - Pentium 4 RAM 2 GB - HD 350 MB (USB 2.0)
58.1 cm
49.9 cm
19.4 cm
12 kg
Limited warranty - 1 year
