Xerox DocuMate 4760 Scanner
Quicklinx: 9M4VWS00 Mfr#: 100N02794
The Xerox DocuMate 4760 delivers high-quality production scanning to any organization, at an affordable price. With its powerful combination of image quality, easy to use features and fast scanning speeds, it is the perfect solution for businesses looking to achieve high levels of flexibility within a low volume production scanning environment. The DocuMate 4760 scans documents at 60 ppm (simplex) and 120 ipm (duplex) at 300 dpi in color, grayscale, and black & white modes. It also includes a 150-page capacity Automatic Document Feeder (ADF), has the ability to scan a wide range of mixed document sizes (up to A3 / 11" x 17") and supports long document scanning up to 38" (965 mm).
  • Efficient scanning
    The DocuMate 4760 offers automatic duplexing, allowing for fast double-sided scanning, which maximizes productivity for any office setting.
  • High capacity
    With a feeder capacity of 150 sheets, this scanner is designed to handle large volumes of documents, making it ideal for busy environments.
  • Superior image quality
    A color depth of 24-bit and grayscale depth of 8-bit ensure that scanned documents have vivid colors and sharp grayscale, suitable for all professional needs.
  • Versatile document handling
    Capable of scanning documents up to 297 x 965 mm in size through the ADF, the DocuMate 4760 can accommodate a wide range of document types.
  • Advanced technology
    Features like Ultrasonic Double Feed Detection and Visioneer OneTouch with Kofax VRS Technology enhance the scanning process, ensuring efficiency and reliability.
Xerox DocuMate 4760 - document scanner - desktop - USB 2.0
Document scanner - desktop
Interface Type
USB 2.0
Scanning Sensor Type
Dual CCD
Max Supported Document Size
A3 (297 x 420 mm)
Input Type
Grayscale / Color Depth (External)
8-bit (256 grey levels) / 24-bit (16.7 million colours)
Optical Resolution
600 dpi
Max Document Scan Speed
60 ppm (mono) / 60 ppm (colour)
Max Document Size
297 mm x 965 mm
Automatic Duplexing
Supported Document Type
Plain paper
Document Feeder Type
Automatic
Document Storage Capacity
150 sheets
Duty Cycle
5000 scans per day
Microsoft Windows XP, Microsoft Windows 7, Microsoft Windows Vista
42.7 cm x 27.7 cm x 21.8 cm
9 kg
Environmental Standards
ENERGY STAR Qualified
1-year warranty
Interface Type
USB 2.0
A3 (297 x 420 mm)
Scanner
Input Type
Grayscale Depth (External)
Colour Depth (External)
Optical Resolution
600 dpi
Scan Mode
Single/duplex pass
Automatic Duplexing
Dual CCD
Max Document Scan Speed B/W
60 ppm
Max Document Scan Speed Colour
60 ppm
Duty Cycle
5000 scans per day
Scanner Speed Details
60 ppm - black & white - 200 dpi , 120 ipm - duplex - black & white - 200 dpi , 60 ppm - colour - 150 dpi , 120 ipm - duplex - colour - 150 dpi
Scanner Features
Ultrasonic Double Feed Detection, Visioneer OneTouch with Kofax VRS Technology
TWAIN, ISIS, WIA
Media Handling
Max Document Size
297 mm x 965 mm
Plain paper
Supported Document Size Details
ADF - up to 297 x 965 mm
Automatic
150 sheets
Interfaces Details
USB 2.0 - Type B
1 x USB cable
ENERGY STAR Certified
External power adapter
Power Consumption Operational (Standby)
39.5 Watt (11.4 Watt)
Software Included
Kofax VirtualReScan Basic, Nuance OmniPage Professional, Visioneer OneTouch with Kofax VRS Technology
System Requirements Details
Windows XP SP2 - Pentium 4 RAM 1 GB - HD 350 MB , Windows 7/Vista - Pentium 4 RAM 2 GB - HD 350 MB
42.7 cm
27.7 cm
21.8 cm
9 kg
Limited warranty - 1 year , Technical support - web support - 1 year , Technical support - phone consulting - 1 year
