Xerox DocuMate 152i Document Scanner Duplex Legal 600 dpi ADF
Quicklinx: C4NWWS00 Mfr#: 100N03144
The Xerox DocuMate 152i, color sheet-fed document scanner, now scans up to 50 images per minute (ipm) in duplex mode, includes a 50-page automatic document feeder and has the ability to automatically scan documents into searchable PDF files. The scanner also offers a more powerful suite of bundled software designed to help you organize and find the information important to you.
  • Efficient scanning
    The DocuMate 152i offers automatic duplexing, allowing for fast and easy two-sided scanning, enhancing productivity and efficiency in any office setting.
  • High-quality imaging
    With a color depth of 24-bit and a grayscale depth of 8-bit, this scanner produces high-quality images in full color or grayscale, capturing every detail with clarity.
  • Versatile document handling
    Equipped with a 50-sheet automatic document feeder and capable of scanning up to 2500 scans per day, the DocuMate 152i can handle a variety of document types and sizes, making it a versatile choice for busy environments.
  • Convenient connectivity
    Featuring a USB 2.0 interface, the DocuMate 152i offers easy connectivity to both Mac and PC systems, ensuring seamless integration into any workflow.
  • Compact and reliable
    Designed as a desktop form factor with an external power adapter, this document scanner is both compact and reliable, fitting easily into any workspace and supporting a high daily duty cycle.
Xerox DocuMate 152i - document scanner - desktop - USB 2.0
Document scanner - desktop
Interface Type
USB 2.0
Light Source
White LED
Max Supported Document Size
Legal (216 x 356 mm)
Input Type
Grayscale / Color Depth (External)
8-bit (256 grey levels) / 24-bit (16.7 million colours)
Optical Resolution
600 dpi
Max Document Size
216 mm x 356 mm
Automatic Duplexing
Supported Document Type
Plain paper
Document Feeder Type
Automatic
Document Storage Capacity
50 sheets
Duty Cycle
2500 scans per day
Microsoft Windows XP SP2, Microsoft Windows 7, Microsoft Windows Vista
Microsoft Certification
Compatible with Windows 7
30.9 cm x 16 cm x 14.1 cm
2.7 kg
Interface Type
USB 2.0
Scanner
Input Type
Grayscale Depth (External)
Colour Depth (External)
Optical Resolution
600 dpi
Automatic Duplexing
Bulb / Light Source Type
White LED
Duty Cycle
2500 scans per day
TWAIN, WIA
Media Handling
Max Document Size
216 mm x 356 mm
Plain paper
Supported Document Size Details
ADF - up to Legal (216 x 356 mm)
Automatic
50 sheets
Interfaces Details
USB 2.0
1 x USB cable
External power adapter
Software Included
Drivers & Utilities, Visioneer Acuity, Nuance Power PDF, Visioneer Scan Utility for Mac, Nuance PaperPort Professional, Nuance OmniPage Ultimate
System Requirements Details
Windows XP - Pentium 4 RAM 512 MB - HD 350 MB , Windows 7/Vista - Pentium 4 RAM 1 GB - HD 350 MB
30.9 cm
16 cm
14.1 cm
2.7 kg
