Xerox ColorQube 8570DN Colour Solid Ink Printer
Quicklinx: 78R8WS00 Mfr#: 8570_ADN?GB
Continuing the Xerox-exclusive tradition of advanced cartridge-free solid ink, the ColorQube 8570 color printer is a powerful, no-fuss and waste-conscious printing solution that's simple and highly productive with the advantage of superior color output.
The ColorQube 8570 solid ink printer helps you create documents with rich, vibrant color on all media, including recycled paper. And for those moments when you want to adjust the color after seeing your print, you can use Xerox's Color by Words technology to tweak the colors on the spot.
There's no reason to sacrifice efficiency for good looks. With the ColorQube 8570's fast output, you'll be picking up your pages by the time you can walk to the printer. And with print speeds up to 40 pages per minute for color or black and white, you'll be able to print last minute and still make the meeting on time.
Xerox thinks printers should last, and the ColorQube 8570's high monthly duty cycle means you'll have a reliable color printer for many years to come. This printer is built for a greener tomorrow. The ColorQube 8570DN is Energy Star certified.
  • ColorQube 8570
    Everyone wants colour. But no one needs expense or complexity. You want attention-grabbing documents. But not if it hurts the environment. So we introduced the ColorQube 8570. Not only does it produce brilliant colour (even on recycled paper) but it's astonishingly easy to use and economical - ideal for modern workgroups. And because it uses solid ink, you can be sure it's kinder to the environment, too. Less waste, intelligent energy use and our latest green technology all add up to colour with a clearer conscience. •Colour: up to 40 ppm • Black: up to 40 ppm • Unique solid ink colour technology • Xerox solid ink printers produce up to 90% less waste, and have up to 30% lower lifecycle energy demand and up to 30% smaller carbon footprint than comparable laser printers • First-page-out time as few as 5 seconds • Maximum paper size: A4 • Resolution: up to 2400 FinePoint • Standard paper capacity: 625 sheets • Maximum paper capacity: 2,200 sheets • Network connectivity standard on all models • True Adobe PostScript 3 • Duty cycle of 85,000 pages per month • Minimum dimensions (w x d x h): 406 x 521 x 368 mm • What comes in the box • Solid Ink Rainbow Pack plus a preloaded starter stick of each colour (total capacity: 3,000 per colour1) • Maintenance Kit (10,000 pages2) • Power cord • Software and documentation
  • Print Quality Features
    •Incredible detail and halftones thanks to 2400 FinePoint print resolution • Solid ink gives your documents rich, vibrant colours on all media, including recycled paper • Wide media range, including plain paper, labels, envelopes, card stock, business cards, and glossy media • True Adobe PostScript 3 and PCL 5c emulation print languages ensure your jobs are printed accurately every time • Consistent, vivid colour from the first page to the last – no colour degradation over time • PANTONE approved solid-colour simulations and Xerox colour correction technology deliver results that always match your expectations
  • Everyday Printing Features
    •Fast print speed gets your jobs out quickly – as quick as 40 ppm colour and black-and-white • Print when you're ready with a first-page out-time as fast as 5 seconds • Two-sided printing is just as fast as single-sided – and saves paper • Easy expandability lets you add memory to enable more time-saving features, as well as a paper capacity that's expandable to 2,200 sheets • Simplified driver management with Xerox Global Print Driver and Xerox Mobile Express Driver • Colour By Words colour correction lets you adjust the colours of your prints, ensuring you get the colours you want. Colour By Words now includes support for English, French, Italian, German and Spanish. • Feed heavy media through any tray • Its small footprint allows for easy integration within your work space, whether on your desk or in a central location • Full compatibility with Windows, Mac and Linux environments • Small ink stick boxes conserve storage space compared to bulky toner cartridges • High monthly duty cycle of up to 85,000 images means you'll get a reliable colour printer that will last for many years to come
  • Environmental Features
    •Solid ink printer and consumable technology mean up to 90% less waste, up to 30% lower lifecycle energy demand and up to 30% smaller carbon footprint than comparable laser printers • Typical electricity consumption on the ColorQube 8570 has been reduced by 40% from the Phaser 8560 • Bundled GreenPrint software helps you print only the pages you want, reducing paper and toner usage • EarthSmart print driver settings make it simple to save paper with easy access to two-sided and 2-up features for eco friendly colour printing • The Intelligent Ready feature learns your usage patterns to optimize power consumption and productivity • The ColorQube 8570 is Energy Star qualified 1 Average standard pages. Average Continuous Composite CMY Yield in accordance with ISO/IEC 24711. Yield will vary based on image, area coverage and print mode. 2 Approximate pages. Declared Yield on Drums based on an average job size of 3 pages A4 size. Declared Yield on Fusers based on A4 size 75 gsm pages. Drum and Fuser Yields will vary based on job run length, media type, size, weight, orientation, and usage patterns.
Xerox ColorQube 8570DN - printer - colour - solid ink
Printer Type
Workgroup printer - solid ink - colour
27.4 kg
Media Size Class
A4/Legal
Max Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm)
Min Media Size (Custom)
76 mm x 127 mm
Max Media Size (Custom)
216 mm x 356 mm
Print Speed
Up to 40 ppm - B/W , Up to 40 ppm - colour
Image Enhancement Technology
FinePoint 2400
Automatic Duplexing
USB, Gigabit LAN
1 GHz
RAM Installed (Max)
512 MB (2 GB) - DDR2 SDRAM - SO-DIMM 200-pin
Language Simulation
PCL 5C, PostScript 3
Media Type
Transparencies, greeting cards, labels, plain paper, photo paper, business cards, index cards, heavy-weight paper, cards, bond paper, recycled paper, cover paper, tri-fold brochure, coated paper, glossy paper
Total Media Capacity
625 sheets
Media Handling
100-sheet multipurpose tray, 525-sheet input tray
Monthly Duty Cycle (max)
85000 pages
Recommended Monthly Volume
8000 pages
Print server - Ethernet, Fast Ethernet, Gigabit Ethernet - internal
Linux, Microsoft Windows XP, Microsoft Windows XP Professional, HP-UX 11i, SunSoft Solaris 9, Microsoft Windows Server 2003, SunSoft Solaris 10, Microsoft Windows 7, HP-UX 11, Microsoft Windows Vista, Apple MacOS X 10.5 or later, Microsoft Windows Server 2008
Microsoft Certification
Compatible with Windows 7
40.6 cm x 52.1 cm x 36.8 cm
Printer Type
Printer
Print Speed
Built-in Devices
Status LCD
Wired
USB, Gigabit LAN
FinePoint 2400
Automatic Duplexing
PostScript Support
Standard
First Print Out Time B/W
5 sec
First Print Out Time Colour
5 sec
Language Simulation
Colour Management Features
PANTONE Digital Color
Media Handling
1 GHz
RAM
RAM Installed (Max)
512 MB / 2 GB (max)
Technology / Form Factor
Slots Qty
2
Empty Slots
1
Media Handling
Media Type
Media Size Class
A4/Legal
Max Media Size
76 mm x 127 mm
216 mm x 356 mm
Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), JIS B5 (182 x 257 mm), Statement (139.7 x 215.9 mm), A7 (74 x 105 mm)
Envelope Sizes
US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm)
Media Weight
60 g/m² - 220 g/m²
625 sheets
Media Feeders
1 x automatic - 100 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m² , 1 x automatic - 525 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m²
Max Media Capacity
2200 sheets
Output Trays Capacity
350 sheets
Duty Cycle
85000 pages
8000 pages
Print server - internal
Network / Transport Protocol
TCP/IP, SMTP, BOOTP, DHCP, RARP
Remote Management Protocol
SNMP 1, SNMP 2, SNMP 3, HTTPS
Security Protocols & Features
SSL, IPsec, 802.1x
1 x USB - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45
Consumables Included
1 x solid ink (black) - up to 3000 pages ISO/IEC 24711 , 1 x solid ink (cyan) - up to 3000 pages ISO/IEC 24711 , 1 x solid ink (magenta) - up to 3000 pages ISO/IEC 24711 , 1 x solid ink (yellow) - up to 3000 pages ISO/IEC 24711
GOST, EN55024, EN55022 Class A, RoHS, UL 60950-1, EN 60950-1, CSA C22.2 No. 60950-1-07, FCC Part 15 A
Power supply - internal
Frequency Required
50/60 Hz
252 Watt
Power Consumption Stand by / Sleep
104 Watt
Software Included
Drivers & Utilities
Environmental Standards
ENERGY STAR
10 °C
32 °C
10 - 80% (non-condensing)
Sound Emission (Idle)
24 dB
Sound Emission (Operating)
59 dB
40.6 cm
52.1 cm
36.8 cm
27.4 kg
Width (Shipping)
55.9 cm
Depth (Shipping)
67.3 cm
Height (Shipping)
54 cm
Weight (Shipping)
34 kg
