Xerox 6510V_DN Phaser 6510 Colour A4 Printer
Quicklinx: CHS8WS00 Mfr#: 6510V_DN?GB
Type: Printer
Functionality: Printer
Output Type: Colour
Wireless Capability: Wired
Technology: Laser
£215.91 ex VAT
£259.09 inc VAT
Pursue relentlessly. Produce effortlessly.
That’s the way to build your business. Introducing the Xerox® Phaser® 6510DN Colour Printer – ready to work right out of the box. Fantastic image quality, easy connectivity, built-in productivity and reliability you can count on, at a price that won’t break the bank.
Spectacular Image Quality
Whatever your business, you’ll put your best face forward with our newest innovation in colour image quality.
Improved toner.
The Phaser 6510DN uses our new Xerox® EA Toner formulation, which has been reengineered for enhanced dot reproducibility and less toner waste. And because it melts at lower temperatures, it saves energy too.
Stunning resolution.
Smaller toner particles translate to finer details, and with 1200 x 2400 native dpi, your printed materials will capture attention and create greater impact.
Colour accuracy
PANTONE® Colour approved solid colour simulations and Xerox® colour correction technology ensure results that match your expectations.
Commanding Performance
Get a handle on day-to-day workloads with the powerful performance your business needs to grow and thrive.
Outstanding performance.
With print speeds up to 28 ppm, the 6510DN is perfectly positioned to support the demands of your growing business.
Print more for longer.
An optional second paper tray (not included) lets you load an extra 550 sheets at one time for extended interruption-free printing.
Time-Saving Taskmaster
Time is money, and these devices are purpose-built to save both by simplifying and automating costly, time-consuming tasks.
Easy management.
Our redesigned Embedded Web Server is easy to use and responsive, so you can easily manage your printer or multifunction printer at your desk or on the go.
Stay secure.
Keep your sensitive documents away from unintended recipients with the latest security features, including IPsec, SNMPv3, IP filtering and secure print.
Double sided printing.
With the convenience of double sided printing, the 6510DN can output up to 19 ppm in Colour and Black and White.
Xerox Phaser 6510DN - printer - colour - laser
Printer Type
Workgroup printer - laser - colour
23.8 kg
Media Size Class
A4/Legal
Max Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm)
Min Media Size (Custom)
76 mm x 127 mm
Max Media Size (Custom)
216 mm x 356 mm
Max Resolution (B&W)
1200 x 2400 dpi
Max Resolution (Colour)
1200 x 2400 dpi
Automatic Duplexing
Gigabit LAN, USB 3.0
AirPrint Enabled
733 MHz
RAM Installed (Max)
1 GB
Language Simulation
PCL 5E, PostScript 3, PCL 6, PDF, TIFF
Media Type
Envelopes, plain paper, bond paper, recycled paper, card stock, lightweight glossy card stock, glossy card stock, punched paper, preprinted paper
Total Media Capacity
300 sheets
Media Handling
250-sheet input tray, 50-sheet bypass tray
Monthly Duty Cycle (max)
50000 pages
Print server
Microsoft Windows 2000 Server, HP-UX 11i v2, Microsoft Windows Server 2003, Red Hat Enterprise Linux, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2008, Oracle Solaris 10, IBM AIX 5, Microsoft Windows Server 2012, Red Hat Fedora Core 12 - 15, Oracle Solaris 9, Apple MacOS X 10.9 or later, Microsoft Windows 7 / 8 / 10
1-year warranty
42 cm x 48.3 cm x 34.7 cm
Printer Type
Printer
Wired
AirPrint Enabled
1200 x 2400 dpi
1200 x 2400 dpi
Automatic Duplexing
PostScript Support
Standard
First Print Out Time B/W
7.5 sec
First Print Out Time Colour
8.8 sec
Language Simulation
Fonts Included
136 x PostScript , 88 x PCL
Media Handling
733 MHz
RAM
RAM Installed (Max)
1 GB
Media Handling
Media Type
Media Size Class
A4/Legal
Max Media Size
76 mm x 127 mm
216 mm x 356 mm
Media Sizes
Media Weight
60 g/m² - 220 g/m²
300 sheets
Media Feeders
1 x automatic - 250 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m² , 1 x automatic - 50 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m²
Max Media Capacity
850 sheets
Output Trays Capacity
150 sheets
Duty Cycle
50000 pages
Print server
Remote Management Protocol
SNMP 3, HTTPS
Security Protocols & Features
LDAP, Apple Bonjour, TLS, IPsec, 802.1x
1 x USB 3.0 - 9 pin USB Type B , 1 x Gigabit LAN - RJ-45
Power supply - internal
Frequency Required
50 Hz
350 Watt
Power Consumption Stand by
44 Watt
Power Consumption Sleep
1 Watt
Software Included
Xerox CentreWare IS Embedded Web Server
Limited warranty - 1 year - on-site
5 °C
32 °C
15 - 85% (non-condensing)
Sound Emission (Idle)
24.9 dBA
Sound Emission (Operating)
51.9 dBA
42 cm
48.3 cm
34.7 cm
23.8 kg
CHS8 Xerox Cyan Standard Capacity Toner Cartridge (1000 Pages) In Stock £74.91
CHS8 Xerox Magenta Standard Capacity Toner Cartridge (1000 Pages) In Stock £74.22
CHS8 Xerox Yellow Standard Capacity Toner Cartridge (1000 Pages) In Stock £74.91
CHS8 Xerox Black Standard Capacity Toner Cartridge (2500 Pages) In Stock £95.58
CHS8 Xerox Magenta High Capacity Toner Cartridge (2500 Pages) In Stock £130.28
CHS8 Xerox Black High Capacity Toner Cartridge (6000 Pages) In Stock £116.26
CHS8 Xerox Cyan Extra High Capacity Toner Cartridge (4500 Pages) In Stock £150.23
CHS8 Xerox Magenta Extra High Capacity Toner Cartridge (4500 Pages) In Stock £150.23
CHS8 Xerox Yellow Extra High Capacity Toner Cartridge (4500 Pages) In Stock £150.23
Type: Printer
Output Type: Colour
Technology: Laser
Max Paper Size: A4 (210 x 297 mm)
Brand: Xerox
