Pursue relentlessly. Produce effortlessly.
That’s the way to build your business. Introducing the Xerox® Phaser® 6510DN Colour Printer – ready to work right out of the box. Fantastic image quality, easy connectivity, built-in productivity and reliability you can count on, at a price that won’t break the bank.
Spectacular Image Quality
Whatever your business, you’ll put your best face forward with our newest innovation in colour image quality.
Improved toner.
The Phaser 6510DN uses our new Xerox® EA Toner formulation, which has been reengineered for enhanced dot reproducibility and less toner waste. And because it melts at lower temperatures, it saves energy too.
Stunning resolution.
Smaller toner particles translate to finer details, and with 1200 x 2400 native dpi, your printed materials will capture attention and create greater impact.
Colour accuracy
PANTONE® Colour approved solid colour simulations and Xerox® colour correction technology ensure results that match your expectations.
Commanding Performance
Get a handle on day-to-day workloads with the powerful performance your business needs to grow and thrive.
Outstanding performance.
With print speeds up to 28 ppm, the 6510DN is perfectly positioned to support the demands of your growing business.
Print more for longer.
An optional second paper tray (not included) lets you load an extra 550 sheets at one time for extended interruption-free printing.
Time-Saving Taskmaster
Time is money, and these devices are purpose-built to save both by simplifying and automating costly, time-consuming tasks.
Easy management.
Our redesigned Embedded Web Server is easy to use and responsive, so you can easily manage your printer or multifunction printer at your desk or on the go.
Stay secure.
Keep your sensitive documents away from unintended recipients with the latest security features, including IPsec, SNMPv3, IP filtering and secure print.
Double sided printing.
With the convenience of double sided printing, the 6510DN can output up to 19 ppm in Colour and Black and White.
- Xerox Phaser 6510DN - printer - colour - laser
- Printer Type
- Workgroup printer - laser - colour
- 23.8 kg
- Media Size Class
- A4/Legal
- Max Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm)
- Min Media Size (Custom)
- 76 mm x 127 mm
- Max Media Size (Custom)
- 216 mm x 356 mm
- Max Resolution (B&W)
- 1200 x 2400 dpi
- Max Resolution (Colour)
- 1200 x 2400 dpi
- Automatic Duplexing
- Interface
- Gigabit LAN, USB 3.0
- AirPrint Enabled
- Processor
- 733 MHz
- RAM Installed (Max)
- 1 GB
- Language Simulation
- PCL 5E, PostScript 3, PCL 6, PDF, TIFF
- Media Type
- Envelopes, plain paper, bond paper, recycled paper, card stock, lightweight glossy card stock, glossy card stock, punched paper, preprinted paper
- Total Media Capacity
- 300 sheets
- Media Handling
- 250-sheet input tray, 50-sheet bypass tray
- Monthly Duty Cycle (max)
- 50000 pages
- Networking
- Print server
- System Requirements
- Microsoft Windows 2000 Server, HP-UX 11i v2, Microsoft Windows Server 2003, Red Hat Enterprise Linux, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2008, Oracle Solaris 10, IBM AIX 5, Microsoft Windows Server 2012, Red Hat Fedora Core 12 - 15, Oracle Solaris 9, Apple MacOS X 10.9 or later, Microsoft Windows 7 / 8 / 10
- 1-year warranty
- 42 cm x 48.3 cm x 34.7 cm
- Printer Type
Printer
- Connectivity Technology
- Wired
- Interface
- AirPrint Enabled
- 1200 x 2400 dpi
- 1200 x 2400 dpi
- PostScript Support
- Standard
- First Print Out Time B/W
- 7.5 sec
- First Print Out Time Colour
- 8.8 sec
- Fonts Included
- 136 x PostScript , 88 x PCL
- Media Handling
- Processor
- 733 MHz
RAM
- 1 GB
Media Handling
- Media Type
- Media Size Class
- A4/Legal
- Max Media Size
- 76 mm x 127 mm
- 216 mm x 356 mm
- Media Sizes
- Media Weight
- 60 g/m² - 220 g/m²
- 300 sheets
- Media Feeders
- 1 x automatic - 250 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m² , 1 x automatic - 50 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m²
- Max Media Capacity
- 850 sheets
- Output Trays Capacity
- 150 sheets
Duty Cycle
- 50000 pages
- Networking
- Print server
- Remote Management Protocol
- SNMP 3, HTTPS
- LDAP, Apple Bonjour, TLS, IPsec, 802.1x
- Connections
- 1 x USB 3.0 - 9 pin USB Type B , 1 x Gigabit LAN - RJ-45
- Power Device
- Power supply - internal
- Frequency Required
- 50 Hz
- 350 Watt
- Power Consumption Stand by
- 44 Watt
- Power Consumption Sleep
- 1 Watt
- Software Included
- Xerox CentreWare IS Embedded Web Server
- OS Required
- Limited warranty - 1 year - on-site
- 5 °C
- 32 °C
- 15 - 85% (non-condensing)
- Sound Emission (Idle)
- 24.9 dBA
- Sound Emission (Operating)
- 51.9 dBA
- 42 cm
- 48.3 cm
- 34.7 cm
- 23.8 kg
Xerox Cyan Standard Capacity Toner Cartridge (1000 Pages) | In Stock | £79.96 |
Xerox Magenta Standard Capacity Toner Cartridge (1000 Pages) | In Stock | £79.02 |
Xerox Yellow Standard Capacity Toner Cartridge (1000 Pages) | In Stock | £79.02 |
Xerox Black Standard Capacity Toner Cartridge (2500 Pages) | In Stock | £101.77 |
Xerox Black High Capacity Toner Cartridge (6000 Pages) | In Stock | £123.78 |
Xerox Cyan Extra High Capacity Toner Cartridge (4500 Pages) | In Stock | £158.63 |
Xerox Magenta Extra High Capacity Toner Cartridge (4500 Pages) | In Stock | £158.50 |
Xerox Yellow Extra High Capacity Toner Cartridge (4500 Pages) | In Stock | £158.50 |
