Wyse Thin Client V90L  XP embedded (512/512)
Quicklinx: 4V1BWS00 Mfr#: 902141-02L
The mid-range Wyse V90L thin client delivers the Windows XPe performance you need; dual-video support (with purchase of optional monitor splitter cable); plus serial, parallel, and USB ports. Using the same form-factor as the Wyse V90 thin client, the Wyse V90L thin client can fit easily into most work environments.
This unit does not have a PCMCIA slot.
Dell Wyse V90L Thin Client - DTS Eden 800 MHz - 512 MB - flash 512 MB
Thin client - DTS
1 x VIA Eden 800 MHz
RAM
512 MB (installed) / 1 GB (max) - DDR2 SDRAM - non-ECC - PC2-4300
Hard Drive
Flash 512 MB
Optical Storage
No optical drive
Audio Output
Stereo - integrated
10Mb LAN, 100Mb LAN
OS Provided
Microsoft Windows XP Embedded
Software Included
Wyse Device Manager Workgroup Edition
4.6 cm x 18 cm x 20.1 cm
Limited warranty - 3 years
Thin client
Product Form Factor
DTS
Processor / Chipset
CPU
VIA Eden
Clock Speed
800 MHz
CPU Qty
1
Max CPU Qty
1
RAM
Installed Size
Effective Memory Speed
533 MHz
Rated Memory Speed
533 MHz
Memory Specification Compliance
PC2-4300
SO-DIMM 200-pin
Slots
1 (Total) / 0 (empty)
Unbuffered
Configuration Features
1 x 512 MB
Hard Drive
Flash
512 MB / max 512 MB
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Integrated
Video Interfaces
DVI
Max Monitors Supported
2
Audio Output
Integrated
Sound Output Mode
Stereo
Max Sampling Rate
48 kHz
Keyboard
USB
Built-in PS/2 port
Mouse
PS/2
Integrated
Ethernet, Fast Ethernet
Wake on LAN (WoL), DHCP support
Slots
1 (total) / 0 (free) x SO-DIMM 200-pin
1 x DVI-I , 1 x serial , 1 x parallel , 3 x USB 2.0 (1 in front) , 1 x LAN , 1 x microphone , 1 x audio line-out
Vertical stand
DVI-VGA adapter
Theft/Intrusion Protection
FCC Class B certified, TUV GS, VCCI, C-Tick, ISO 9241-3, ISO 9241-8, EN 60950, UL 60950, RoHS, WEEE
Power adapter
Operating System / Software
OS Provided
OS Certified
Microsoft Windows NT Server 4.0 Terminal Edition, Microsoft Windows 2000 Server, Citrix Presentation Server, Microsoft Windows Server 2003
Software
4.6 cm
18 cm
20.1 cm
10 °C
