The mid-range Wyse V90L thin client delivers the Windows XPe performance you need; dual-video support (with purchase of optional monitor splitter cable); plus serial, parallel, and USB ports. Using the same form-factor as the Wyse V90 thin client, the Wyse V90L thin client can fit easily into most work environments.
This unit does not have a PCMCIA slot.
- Dell Wyse V90L Thin Client - DTS Eden 800 MHz - 512 MB - flash 512 MB
- Thin client - DTS
- Processor
- 1 x VIA Eden 800 MHz
- RAM
- 512 MB (installed) / 1 GB (max) - DDR2 SDRAM - non-ECC - PC2-4300
- Hard Drive
- Flash 512 MB
- Optical Storage
- No optical drive
- Audio Output
- Stereo - integrated
- Networking
- 10Mb LAN, 100Mb LAN
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- Microsoft Windows XP Embedded
- Software Included
- Wyse Device Manager Workgroup Edition
- 4.6 cm x 18 cm x 20.1 cm
- Limited warranty - 3 years
- Thin client
- Product Form Factor
- DTS
Processor / Chipset
- CPU
- VIA Eden
- Clock Speed
- 800 MHz
- CPU Qty
- 1
- Max CPU Qty
- 1
RAM
- Installed Size
- Technology
- Effective Memory Speed
- 533 MHz
- Rated Memory Speed
- 533 MHz
- Memory Specification Compliance
- PC2-4300
- Form Factor
- SO-DIMM 200-pin
- Slots
- 1 (Total) / 0 (empty)
- Unbuffered
- Configuration Features
- 1 x 512 MB
Hard Drive
- Flash
- Capacity
- 512 MB / max 512 MB
Optical Storage
- No optical drive
Monitor
- Monitor Type
- None.
Graphics Controller
- Integrated
- Video Interfaces
- DVI
- Max Monitors Supported
- 2
Audio Output
- Integrated
- Sound Output Mode
- Stereo
- Max Sampling Rate
- 48 kHz
Keyboard
- Interface
- USB
- Built-in PS/2 port
Mouse
- Interface
- PS/2
- Integrated
- Data Link Protocol
- Ethernet, Fast Ethernet
- Wake on LAN (WoL), DHCP support
- Slots
- 1 (total) / 0 (free) x SO-DIMM 200-pin
- 1 x DVI-I , 1 x serial , 1 x parallel , 3 x USB 2.0 (1 in front) , 1 x LAN , 1 x microphone , 1 x audio line-out
- Included Accessories
- Vertical stand
- Cables Included
- DVI-VGA adapter
- Theft/Intrusion Protection
- FCC Class B certified, TUV GS, VCCI, C-Tick, ISO 9241-3, ISO 9241-8, EN 60950, UL 60950, RoHS, WEEE
- Power adapter
- Voltage Required
Operating System / Software
- OS Provided
- OS Certified
- Microsoft Windows NT Server 4.0 Terminal Edition, Microsoft Windows 2000 Server, Citrix Presentation Server, Microsoft Windows Server 2003
- Software
- 4.6 cm
- 18 cm
- 20.1 cm
- 10 °C
- 40 °C
