The Wyse S10 Thin Client is the most optimized solution for Citrix ICA (MetaFrame Presentation Server) and Microsoft RDP (Terminal Services) environments. It combines great performance, stateless operation, low power consumption, USB ports, remote management, and simple device setup and imaging. This small, lightweight, solid-state (all electronic, with no disk or fan) unit can be mounted out of the way, even on the back of a display, making the S10 ideal for any space-constrained environment.
- Wyse Winterm S10 Thin Client - DTS Geode GX 533@1.1W - 128 MB - flash 2 MB
- Thin client - DTS
- Processor
- 1 x AMD Geode GX 533@1.1W
- RAM
- 128 MB DDR SDRAM
- Hard Drive
- Flash 2 MB
- Optical Storage
- No optical drive
- Audio Output
- Stereo - integrated
- Networking
- 10Mb LAN, 100Mb LAN
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- Wyse Thin OS
- Software Included
- Citrix ICA, Microsoft RDP, Wyse Device Manager Workgroup Edition
- 17.7 cm x 12.1 cm x 3.4 cm
- 2.7 kg
- Limited warranty - 3 years
- Thin client
- Product Form Factor
- DTS
Processor / Chipset
- CPU
- AMD Geode GX 533@1.1W
- CPU Qty
- 1
- Max CPU Qty
- 1
RAM
- Installed Size
- 128 MB
- Technology
- DDR SDRAM
Hard Drive
- Flash
- Capacity
- 2 MB
Optical Storage
- No optical drive
Monitor
- Monitor Type
- None.
Graphics Controller
- Integrated
- Video Interfaces
- VGA
Audio Output
- Integrated
- Sound Output Mode
- Stereo
- Max Sampling Rate
- 48 kHz
Input Device
- Mouse
Mouse
- Interface
- PS/2
- Scroll
- Integrated
- Data Link Protocol
- Ethernet, Fast Ethernet
- Wake on LAN (WoL), DHCP support
- 4 x USB (2 in front) , 1 x serial , 1 x VGA , 1 x LAN , 1 x audio line-out (1 in front) , 1 x microphone (1 in front)
- Included Accessories
- Horizontal feet
- Theft/Intrusion Protection
- FCC Class B certified, TUV GS, VCCI, C-Tick, ISO 9241-3, ISO 9241-8, cUL, EN 60950, UL 60950
- Power adapter
- Voltage Required
- 5.6 Watt
Operating System / Software
- OS Provided
- Wyse Thin OS
- Software
- 17.7 cm
- 12.1 cm
- 3.4 cm
- 2.7 kg
- 0 °C
- 40 °C
- 20 - 80%
