The Wyse C90LE Thin Client features a separate graphic accelerator for unparalleled performance in its class. The ultra low power media system processor delivers rich multimedia and video playback up to 1080p HD resolution.
The Wyse C90LE thin client draws just under 7 watts of power and creates very little heat. As a result, each Wyse C90LE Thin Client contributes to cooler working environments, greatly reduced carbon footprints and huge savings in energy costs when compared to equivalent PC desktops.
Higher and better video performance
The Wyse C90LE Thin Client features a separate graphic accelerator for unparalleled performance in its class. The ultra low power media system processor delivers rich multimedia and video playback up to 1080p HD resolution. -
Fast start-up
Powered by C7 processors, the Wyse C90LE diskless devices boot-up in seconds, provide secure user login to corporate networks. -
Saving energy
- Dell Wyse C90LE Thin Client - DTS C7 1 GHz - 1 GB - flash 1 GB
- Thin client - DTS - wall mountable
- Processor
- 1 x VIA C7 1 GHz ULV
- RAM
- 1 GB (installed) / 2 GB (max) - DDR2 SDRAM
- Hard Drive
- Flash 1 GB
- Optical Storage
- No optical drive
- Audio Output
- Integrated
- Networking
- 1GbE
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- Microsoft Windows XP Embedded
- Software Included
- Microsoft RDP, Citrix ICA 11.0, Wyse Device Manager Workgroup Edition, Wyse Remote Shadow, Microsoft Terminal Services Advanced Client (TSAC), Ericom PowerTerm, Microsoft Internet Explorer 7.0
- 17.7 cm x 12.1 cm x 3.4 cm
- Environmental Standards
- ENERGY STAR Qualified EPEAT Silver
- Limited warranty - 3 years
- Thin client
- Product Form Factor
- DTS
Processor / Chipset
- CPU
- VIA C7
- Clock Speed
- 1 GHz
- CPU Qty
- 1
- Max CPU Qty
- 1
- Power Efficiency
- Ultra Low Voltage (ULV)
- Chipset Type
- VIA VX855
RAM
- Installed Size
- Technology
- DDR2 SDRAM
Hard Drive
- Flash
- Capacity
- 1 GB / max 1 GB
Optical Storage
- No optical drive
Monitor
- Monitor Type
- None.
Graphics Controller
- Integrated
- Video Interfaces
- DVI
- Max Monitors Supported
- 2
Audio Output
- Integrated
Input Device
- Mouse, keyboard
Keyboard
- Interface
- PS/2
Mouse
- Technology
- Optical
- Interface
- PS/2
- Integrated
- Data Link Protocol
- Wake on LAN (WoL), DHCP support, PXE support
- 1 x DVI-I , 1 x PS/2 keyboard , 1 x PS/2 mouse , 4 x USB 2.0 (2 in front) , 1 x LAN (Gigabit Ethernet) , 1 x audio line-out (1 in front) , 1 x microphone (1 in front)
- Included Accessories
- Horizontal feet
- Cables Included
- DVI-VGA adapter
- Wall mountable
- Theft/Intrusion Protection
- FCC Class B certified, TUV GS, VCCI, C-Tick, ISO 9241-3, ISO 9241-8, EN 60950, UL 60950, RoHS, DDC, WEEE, cULus
- Power adapter
- Voltage Required
- 10 Watt
Operating System / Software
- OS Provided
- Software
Sustainability Information
- EPEAT Compliant
- EPEAT Silver
- ENERGY STAR Certified
- 17.7 cm
- 12.1 cm
- 3.4 cm
- 10 °C
- 40 °C
- 20 - 80%
