Wyse Thin Client
Wyse Thin Client
Quicklinx: 7BT1WS00 Mfr#: 909531-02L
  • Sempron
When you need optimized performance, connectivity and simplicity, choose Wyse R10L based on the ultra-fast Wyse ThinOS. Created with power and performance in mind, the Wyse R10L thin client features the best option for dual digital scenarios and rotation or "L-shape" desktop scenarios.
Finally, the Wyse R10L thin client contributes - quietly and coolly - to lowering your organization's carbon footprint, with power usage and emissions that are a fraction of traditional PC desktops.
  • Instant-on, simple deployment
    With class-leading boot-up times, users are ready to login in seconds. Avoid the "double desktop drama" of users having to navigate local menus to reach their remote environment.
  • Automated management
    Wyse ThinOS enables simple, scalable device management from day one. Its easy FTP-based configuration and automatic update facility allows for time-saving 'hands-off' device management.
  • Security
    Featuring an unpublished API and no file system, Wyse ThinOS is inherently secure providing maximum security from malware and viruses. Smartcard support for leading vendors is built-in, including CAC smartcards.
Dell Wyse R10L Thin Client - DTS Sempron 1.5 GHz - 512 MB - flash 128 MB
Thin client - DTS
1 x AMD Sempron 1.5 GHz
RAM
512 MB
Hard Drive
Flash 128 MB
Optical Storage
No optical drive
Audio Output
Integrated
1GbE
OS Provided
Wyse Thin OS 7
25 cm x 22.5 cm x 5.3 cm
Limited warranty - 3 years
Thin client
Product Form Factor
DTS
Built-in Devices
Speaker
Processor / Chipset
CPU
AMD Sempron
Clock Speed
1.5 GHz
CPU Qty
1
Max CPU Qty
1
Chipset Type
AMD M690E
RAM
Installed Size
512 MB
Hard Drive
Flash
128 MB
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Integrated
Video Interfaces
DVI
Max Monitors Supported
2
Audio Output
Integrated
Input Device
Mouse, keyboard
Mouse
Optical
Integrated
1 x DVI-I , 2 x serial , 1 x DVI-D , 6 x USB 2.0 (2 in front) , 1 x LAN (Gigabit Ethernet) , 1 x microphone , 1 x audio line-out , 1 x PS/2 mouse , 1 x PS/2 keyboard
Vertical stand
Theft/Intrusion Protection
VESA Mounting Interface
Power adapter
Power Provided
65 Watt
Operating System / Software
OS Provided
Wyse Thin OS 7
25 cm
22.5 cm
5.3 cm
10 °C
20 - 80%
