Wyse T10 Thin Client - 1 GB RAM - 1 GHz
Quicklinx: 881RWS00 Mfr#: 909566-02L
A great value from day one, the Wyse T10 sets the new standard for entry-level thin clients. Providing an exceptional user experience, the T10 features incredibly fast Wyse ThinOS, for environments in which security is critical - there's no attack surface to put your data at risk. Boot up in just seconds and log in securely to the network. The T10 delivers a superior Citrix, Microsoft and VMware VDI user experience, along with usability and management features found in premium thin clients. The T10 delivers outstanding performance based on its system-on-a-chip (SoC) design, and a built-in media processor delivers smooth multimedia, bi-directional audio and Flash playback. Flexible mounting options let you position the T10 vertically or horizontally on your desk, on the wall or behind your display. Using about 7 watts of power in full operation, the T10 creates very little heat for a greener, more comfortable working environment.
  • High performance
    Marvell ARMADA PXA 510 v7 1.0GHz system-on-a-chip (SoC) delivers unprecedented performance in an entry level thin client.
  • Fast and secure
    Features incredibly fast Wyse ThinOS, for environments in which security is critical.
  • Flexible mounting
    Mount horizontally or vertically on or under your desk, on the wall or behind your display.
  • Well-connected
    DVI-I interface with optional splitter cable, four USB ports, Gigabit Ethernet.
  • Affordable
    Great value from day one and lower TCO.
  • Green
    Uses less than 7 watts of power in full operation for cooler work environments and energy savings.
Dell Wyse T10 Thin Client - DTS ARMADA 510 1.2 GHz - 1 GB - no HDD
Thin client - DTS
1 x Marvell ARMADA 510 / 1.2 GHz
Cache Memory
512 KB
Cache Per Processor
512 KB
RAM
1 GB DDR3 SDRAM
Flash Memory
0 GB
Hard Drive
No HDD
Optical Storage
No optical drive
Graphics Controller
- up to
Audio Output
Stereo - integrated
1GbE
OS Provided
Wyse Thin OS
17.7 cm x 11.9 cm x 2.5 cm
450 g
Environmental Standards
ENERGY STAR Qualified EPEAT Silver
Limited warranty - 3 years
Thin client
Product Form Factor
DTS
Processor / Chipset
CPU
Marvell ARMADA 510
Clock Speed
1.2 GHz
CPU Qty
1
Max CPU Qty
1
Cache Memory
Installed Size
512 KB
Cache Per Processor
512 KB
RAM
Installed Size
1 GB
DDR3 SDRAM
Flash Memory
Flash Memory
0 GB
Hard Drive
No HDD
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Integrated
Video Interfaces
DVI
Max Monitors Supported
2
Audio Output
Integrated
Sound Output Mode
Stereo
Max Sampling Rate
48 kHz
Integrated
1 x DVI-I , 4 x USB 2.0 (2 in front) , 1 x LAN (Gigabit Ethernet) , 1 x microphone , 1 x audio line-out
Horizontal feet
Theft/Intrusion Protection
FCC Class B certified, TUV GS, VCCI, C-Tick, ISO 9241-3, ISO 9241-8, EN 60950, RoHS, WEEE, cULus
Power adapter
Operating System / Software
OS Provided
Wyse Thin OS
Sustainability Information
EPEAT Compliant
EPEAT Silver
ENERGY STAR Certified
17.7 cm
11.9 cm
2.5 cm
450 g
10 °C
35 °C
10 - 95% (non-condensing)
881R C2G 2m USB 2.0 A/B Cable - Black In Stock £4.20
881R C2G 5m USB 2.0 A/B Cable - Black In Stock £5.74
