Wyse E01 Zero Client - DTS - no HDD - no graphics - Monitor : none
Quicklinx: 7VPNWS00 Mfr#: 920322-08L
Wyse E01 Zero Clients have been specifically designed to work with Windows MultiPoint Server 2010. They offer a truly low cost alternative for PC sharing technology through an innovative hardware design. Teachers can simply connect the E01 devices to the PC running Windows MultiPoint Server 2010 via USB cables and their system is up and running in a matter of minutes.
Wyse E01 Zero Client is also the only device capable of supporting USB peripherals such as keyboard, mouse, webcams, and USB flash drives in conjunction with Windows MultiPoint Server 2010 in order to provide a full rich Windows 7 desktop to students and maximum flexibility to teachers and administrators.
  • More desktops, for more students
    Up to 10 students are able to access a single PC running Windows Multipoint Server 2010 with no drop in their learning experience.
  • Easy to use and add students
    As a teacher you'll appreciate the simple plug-n-play nature of Wyse E01 zero clients. For additional desktops all you do is plug one into the server, and your students can login and be ready to learn in seconds.
  • Lower operational costs
    Schools only need to service and support one PC per 10-seat workgroup. And, combined with the easy set-up and management that's built into Windows MultiPoint Server 2010, student desktop down-time and support issues are all significantly reduced too.
  • Energy-efficient desktops
    As Wyse E01 zero clients draw a fraction of the power required to power full PC desktops, they'll have a dramatic effect on your energy budget as well helping to reduce your carbon footprint too.
Dell Wyse E01 - DTS - no CPU - no HDD
Terminal station - desktop slimline
Region: United Kingdom
No CPU
Hard Drive
No HDD
Optical Storage
No optical drive
Graphics Controller
No graphics
13.2 cm x 8.7 cm x 2.2 cm
Limited warranty - 3 years
Terminal station
Product Form Factor
Desktop slimline
Processor / Chipset
CPU
No CPU
Hard Drive
No HDD
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
No graphics
Video Interfaces
VGA
1 x VGA , 4 x USB 2.0 , 1 x microphone , 1 x audio line-out
FCC Class B certified, TUV GS, C-Tick, ISO 9241-3, ISO 9241-8, EN 60950, UL 60950, RoHS, WEEE
Power adapter
Installed Qty
1
13.2 cm
8.7 cm
2.2 cm
10 °C
20 - 80%
