1 x Male connector splitting into two female
DUAL-VGA-SPLIT CABLE, DVI-I to DVI-D plus VGA out Cable (REQUIRED FOR DUAL-VIDEO OPERATION V30L, V50L, V90L). Please note picture is for illustration only.
Wyse Technology helps customers maximize the benefits of server-centric computing. From the client, through the network, to the server - Wyse has the products, services and domain expertise to reduce the barriers to the benefits of server-centric computing for global enterprises. The company is building on its market dominance in the desktop thin-client market to integrate the industry's broadest hardware and software portfolio with unmatched professional expertise.
- Wyse DVI splitter
- DVI splitter
- Connectors
- DVI-I - male
- Connectors (Second End)
- DVI-D - female , HD-15 (VGA) - female
- Designed For
- Dell Wyse C00LE, C10LE, C30LE, C50LE, C90LE, C90LE7, D00D, D50D, D90D7, T10, T50, V00LE, V10LE, V30LE, V50LE, V90LE
- DVI splitter
- Connectors
- 24+5 pin combined DVI - male
- 24+1 pin digital DVI - female , 15 pin HD D-Sub (HD-15) - female
- Designed For
- Dell Wyse C00LE, C00LE Cloud PC, C00LE Thin Client, C10LE Thin Client, C30LE Thin Client, C50LE Thin Client, C90LE Thin Client, C90LE7 Thin Client, D00D Cloud PC, D50D Thin Clients, D90D7 Thin Client, T10 Thin Client, T50 Thin Client, V00LE, V00LE Cloud PC, V00LE Thin Client, V10LE Thin Client, V30LE Thin Client, V50LE Thin Client, V90LE Thin Client
