Add smart light to your candelabra fittings with a WiZ full-colour candle bulb with an E14 base. Use with the WiZ app or your voice to dim and brighten or use preset light modes on Wi-Fi setups.
 - WiZ Colors - LED light bulb - shape: C37 - frosted finish - E14 - 4.9 W - multicolour/daylight to warm white light - 2200-6500 K (pack of 2)
- Light Source Type
 - LED light bulb
- Packaged Quantity
 - 2 (specifications are for single item)
- Shape
 - C37
- Bulb Finish
 - Frosted
- Socket Type
 - E14
- Wattage
 - 4.9 W
- Wattage Equivalent
 - 40 W
- Energy Efficiency Class
 - F
- Colour of Illumination
 - Multicolour/daylight to warm white light
- Colour Temperature
 - 2200-6500 K
- Luminous Power
 - 470 lumens
- Dimmable
- Intelligent Assistant
 - Siri, Google Assistant, Alexa - indirect
- Platform
 - SmartThings
- Communications Technology
 - Bluetooth, Wi-Fi
- Voltage Required
 - AC 220 - 240 V
- Frequency Required
 - 50 - 60 Hz
- Packaged Quantity
Light Source
 - LED light bulb
- Shape
 - C37
- Bulb Finish
 - Frosted
- Socket Type
 - E14
- Wattage
 - 4.9 W
 - 40 W
 - F
- Energy Consumption per 1000h
 - 5 kWh
- Power Factor
 - 0.51
- Lamp Current
 - 40 mA
 - 2200-6500 K
- Colour Rendering Index
 - 90
- Colour Code
 - 922-965
- Luminous Power
 - 470 lumens
- Luminous Efficacy
 - 95 lm/W
- Starting Time
 - 0.5 sec
- Dimmable
- Lifetime
 - 15000 hours
- Switch Cycles
 - 50000
 - Indoor usage, app-controlled, 16 million changeable colours, controlled via Bluetooth
Power Requirements
- Voltage Required
 - AC 220 - 240 V
 - 50 - 60 Hz
Internet of Things (IoT)
- Internet of Things (IoT) Compatible
- Hub
 - Not needed
- Platform
 - SmartThings
- Compatible Application
 - WiZ app
 - Bluetooth, Wi-Fi
- Compatible Services
 - IFTTT
- Voice Controlled
 - Indirect
- Product Material
 - Plastic
- Package
 - Hanging box
- Warranty
 - 2 years
- Diameter
 - 39 mm
- Length
 - 116 mm
 - 45 g
- Shipping Dimensions (WxDxH) / Weight
 - 10.5 cm x 7 cm x 16 cm / 151 g
