Wiz Home White and Colour Ambiance E14 Bulbs Twin Pack
Quicklinx: GRTZWS00 Mfr#: 929002448832
Type: Light bulb
Compatible With: Siri, Google Assistant, Alexa
£17.79 ex VAT
£21.34 inc VAT
Add smart light to your candelabra fittings with a WiZ full-colour candle bulb with an E14 base. Use with the WiZ app or your voice to dim and brighten or use preset light modes on Wi-Fi setups.
WiZ Colors - LED light bulb - shape: C37 - frosted finish - E14 - 4.9 W - multicolour/daylight to warm white light - 2200-6500 K (pack of 2)
Light Source Type
LED light bulb
Packaged Quantity
2 (specifications are for single item)
Shape
C37
Bulb Finish
Frosted
Socket Type
E14
Wattage
4.9 W
Wattage Equivalent
40 W
Energy Efficiency Class
F
Colour of Illumination
Multicolour/daylight to warm white light
Colour Temperature
2200-6500 K
Luminous Power
470 lumens
Dimmable
Intelligent Assistant
Siri, Google Assistant, Alexa - indirect
Platform
SmartThings
Communications Technology
Bluetooth, Wi-Fi
AC 220 - 240 V
Frequency Required
50 - 60 Hz
Packaged Quantity
Light Source
LED light bulb
Shape
C37
Bulb Finish
Frosted
Socket Type
E14
Wattage
4.9 W
Wattage Equivalent
40 W
F
Energy Consumption per 1000h
5 kWh
Power Factor
0.51
Lamp Current
40 mA
Colour Temperature
2200-6500 K
Colour Rendering Index
90
Colour Code
922-965
Luminous Power
470 lumens
Luminous Efficacy
95 lm/W
Starting Time
0.5 sec
Dimmable
Lifetime
15000 hours
Switch Cycles
50000
Indoor usage, app-controlled, 16 million changeable colours, controlled via Bluetooth
Power Requirements
AC 220 - 240 V
Frequency Required
50 - 60 Hz
Internet of Things (IoT)
Hub
Not needed
Platform
SmartThings
Compatible Application
WiZ app
Bluetooth, Wi-Fi
Compatible Services
IFTTT
Voice Controlled
Indirect
Product Material
Plastic
Package
Hanging box
Warranty
2 years
Diameter
39 mm
Length
116 mm
45 g
10.5 cm x 7 cm x 16 cm / 151 g
Type: Light bulb
Compatible With: Alexa
Brand: Wiz Home
