Wiz Home White and Colour 60W E27 Smart Bulb Twin Pack
Quicklinx: H666WS00 Mfr#: 929002383632
Type: Light bulb
Compatible With: Google Assistant, Alexa, Siri
£17.79 ex VAT
£21.34 inc VAT
The WiZ LED A60 full-color bulb brings smart lighting for your daily living. Retrofit into any lamp shade to create the ambience of your choice with 16 million colors as well as warm to cool white light. You can set schedule to turn lights on and off according to daily or weekly routines, control with your smartphone or your voice and have remote access to your lights even when you're away. WiZ lights connect to your existing Wi-Fi, no additional hardware is needed.
WiZ Colors - LED light bulb - shape: A60 - frosted finish - E27 - 8 W - 16 million colours/warm white to daylight - 2200-6500 K (pack of 2)
Light Source Type
LED light bulb
Packaged Quantity
2 (specifications are for single item)
Shape
A60
Bulb Finish
Frosted
Socket Type
E27
Wattage
8 W
Wattage Equivalent
60 W
Energy Efficiency Class
F
Colour of Illumination
Colour Temperature
2200-6500 K
Luminous Power
806 lumens
Dimmable
Intelligent Assistant
Siri, Google Assistant, Alexa - indirect
Platform
SmartThings
Communications Technology
Bluetooth, Wi-Fi
AC 220 - 240 V
Frequency Required
50 - 60 Hz
Packaged Quantity
Light Source
LED light bulb
Shape
A60
Bulb Finish
Frosted
Socket Type
E27
Wattage
8 W
Wattage Equivalent
60 W
F
Energy Consumption per 1000h
8 kWh
Lamp Current
70 mA
Colour Temperature
2200-6500 K
Colour Rendering Index
90
Luminous Power
806 lumens
Dimmable
Lifetime
25000 hours
Switch Cycles
50000
Indoor usage, app-controlled, lighting schedules
Power Requirements
AC 220 - 240 V
Frequency Required
50 - 60 Hz
Power Consumption Stand by
0.5 Watt
Internet of Things (IoT)
Hub
Not needed
Platform
SmartThings
Bluetooth, Wi-Fi
Compatible Services
IFTTT
Voice Controlled
Indirect
Package
Hanging box
Warranty
2 years
Diameter
60 mm
Length
122 mm
130 g
Type: Light bulb
Compatible With: Alexa
Compatible With: Siri
Brand: Wiz Home
