The WiZ LED A60 full-color bulb brings smart lighting for your daily living. Retrofit into any lamp shade to create the ambience of your choice with 16 million colors as well as warm to cool white light. You can set schedule to turn lights on and off according to daily or weekly routines, control with your smartphone or your voice and have remote access to your lights even when you're away. WiZ lights connect to your existing Wi-Fi, no additional hardware is needed.
- WiZ - LED light bulb - shape: A60 - E27 - 8 W - 16 million colours - 2200-6500 K
- Light Source Type
- LED light bulb
- Shape
- A60
- Socket Type
- E27
- Wattage
- 8 W
- Wattage Equivalent
- 60 W
- Energy Efficiency Class
- F
- Colour of Illumination
- Colour Temperature
- 2200-6500 K
- Luminous Power
- 806 lumens
- Communications Technology
- Wi-Fi
- Voltage Required
- AC 220 - 240 V
- Frequency Required
- 50 - 60 Hz
Light Source
- LED light bulb
- Shape
- A60
- Socket Type
- E27
- Wattage
- 8 W
- 60 W
- F
- Energy Consumption per 1000h
- 8 kWh
- Lamp Current
- 70 mA
- 2200-6500 K
- Colour Rendering Index
- 90
- Luminous Power
- 806 lumens
- Lifetime
- 25000 hours
- Switch Cycles
- 50000
- Indoor usage, light scheduling, retrofit design
Power Requirements
- Voltage Required
- AC 220 - 240 V
- 50 - 60 Hz
- Power Consumption Stand by
- 0.5 Watt
Internet of Things (IoT)
- Internet of Things (IoT) Compatible
- Compatible Application
- WiZ app
- Wi-Fi
- Warranty
- 2 years
- Diameter
- 60 mm
- Length
- 122 mm
- 65 g
