Wiz Home White and Colour 60W E27 Smart Bulb
Quicklinx: GRTYWS00 Mfr#: 929002383602
Type: Light bulb
Compatible With: Alexa, Google Assistant
£9.95 ex VAT
£11.94 inc VAT
The WiZ LED A60 full-color bulb brings smart lighting for your daily living. Retrofit into any lamp shade to create the ambience of your choice with 16 million colors as well as warm to cool white light. You can set schedule to turn lights on and off according to daily or weekly routines, control with your smartphone or your voice and have remote access to your lights even when you're away. WiZ lights connect to your existing Wi-Fi, no additional hardware is needed.
WiZ - LED light bulb - shape: A60 - E27 - 8 W - 16 million colours - 2200-6500 K
Light Source Type
LED light bulb
Shape
A60
Socket Type
E27
Wattage
8 W
Wattage Equivalent
60 W
Energy Efficiency Class
F
Colour of Illumination
16 million colours
Colour Temperature
2200-6500 K
Luminous Power
806 lumens
Communications Technology
Wi-Fi
AC 220 - 240 V
Frequency Required
50 - 60 Hz
Light Source
LED light bulb
Shape
A60
Socket Type
E27
Wattage
8 W
Wattage Equivalent
60 W
F
Energy Consumption per 1000h
8 kWh
Lamp Current
70 mA
16 million colours
Colour Temperature
2200-6500 K
Colour Rendering Index
90
Luminous Power
806 lumens
Lifetime
25000 hours
Switch Cycles
50000
Indoor usage, light scheduling, retrofit design
Power Requirements
AC 220 - 240 V
Frequency Required
50 - 60 Hz
Power Consumption Stand by
0.5 Watt
Internet of Things (IoT)
Compatible Application
WiZ app
Wi-Fi
Warranty
2 years
Diameter
60 mm
Length
122 mm
65 g
Type: Light bulb
Brand: Wiz Home
