Wiz Home White and Colour 60W B22 Smart Bulb
Quicklinx: GRTXWS00 Mfr#: 929002383802
Type: Light bulb
Compatible With: Alexa, Google Assistant, Siri
£9.99 ex VAT
£11.98 inc VAT
Use colourful shades of light in your interior spaces with the WiZ full-colour smart bulb with an B22 base. Use with the WiZ app or your voice to dim and brighten or use preset light modes on Wi-Fi setups.
WiZ - LED light bulb - shape: A60 - frosted finish - B22 - 8 W - full colour - 2200-6500 K
Light Source Type
LED light bulb
Shape
A60
Bulb Finish
Frosted
Socket Type
B22
Wattage
8 W
Wattage Equivalent
60 W
Energy Efficiency Class
F
Colour of Illumination
Full colour
Colour Temperature
2200-6500 K
Luminous Power
806 lumens
Dimmable
Intelligent Assistant
Siri, Google Assistant, Alexa
Communications Technology
Bluetooth, Wi-Fi
AC 220 - 240 V
Frequency Required
50 - 60 Hz
Light Source
LED light bulb
Shape
A60
Bulb Finish
Frosted
Socket Type
B22
Wattage
8 W
Wattage Equivalent
60 W
F
Energy Consumption per 1000h
8 kWh
Power Factor
0.51
Lamp Current
70 mA
Full colour
Colour Temperature
2200-6500 K
Colour Rendering Index
90
Colour Code
922-965
Luminous Power
806 lumens
Luminous Efficacy
100 lm/W
Starting Time
0.5 sec
Dimmable
Lifetime
25000 hours
Switch Cycles
50000
Instant full light, indoor usage, voice control, app-controlled, lighting schedules
Power Requirements
AC 220 - 240 V
Frequency Required
50 - 60 Hz
8 Watt
Power Consumption Stand by
0.5 Watt
Internet of Things (IoT)
Compatible Application
WiZ app
Bluetooth, Wi-Fi
Package
Hanging box
Warranty
2 years
Diameter
60 mm
Length
120 mm
63 g
7 cm x 7 cm x 16 cm / 120 g
Type: Light bulb
Compatible With: Siri
Brand: Wiz Home
