Use colourful shades of light in your interior spaces with the WiZ full-colour smart bulb with an B22 base. Use with the WiZ app or your voice to dim and brighten or use preset light modes on Wi-Fi setups.
- WiZ - LED light bulb - shape: A60 - frosted finish - B22 - 8 W - full colour - 2200-6500 K
- Light Source Type
- LED light bulb
- Shape
- A60
- Bulb Finish
- Frosted
- Socket Type
- B22
- Wattage
- 8 W
- Wattage Equivalent
- 60 W
- Energy Efficiency Class
- F
- Colour of Illumination
- Full colour
- Colour Temperature
- 2200-6500 K
- Luminous Power
- 806 lumens
- Dimmable
- Intelligent Assistant
- Siri, Google Assistant, Alexa
- Communications Technology
- Bluetooth, Wi-Fi
- Voltage Required
- AC 220 - 240 V
- Frequency Required
- 50 - 60 Hz
Light Source
- LED light bulb
- Shape
- A60
- Bulb Finish
- Frosted
- Socket Type
- B22
- Wattage
- 8 W
- 60 W
- F
- Energy Consumption per 1000h
- 8 kWh
- Power Factor
- 0.51
- Lamp Current
- 70 mA
- Full colour
- 2200-6500 K
- Colour Rendering Index
- 90
- Colour Code
- 922-965
- Luminous Power
- 806 lumens
- Luminous Efficacy
- 100 lm/W
- Starting Time
- 0.5 sec
- Dimmable
- Lifetime
- 25000 hours
- Switch Cycles
- 50000
- Instant full light, indoor usage, voice control, app-controlled, lighting schedules
Power Requirements
- Voltage Required
- AC 220 - 240 V
- 50 - 60 Hz
- 8 Watt
- Power Consumption Stand by
- 0.5 Watt
Internet of Things (IoT)
- Internet of Things (IoT) Compatible
- Compatible Application
- WiZ app
- Bluetooth, Wi-Fi
- Package
- Hanging box
- Warranty
- 2 years
- Diameter
- 60 mm
- Length
- 120 mm
- 63 g
- Shipping Dimensions (WxDxH) / Weight
- 7 cm x 7 cm x 16 cm / 120 g
